Everything posted by Mark Pearse
I've been paying around with alternative swages for the rigging wire. They aren't really needed for the model, but actual rigging would have them, & they - at a model level - join the wire (jewellery SS braid, nylon coated, thank you brains trust) to the chain plates or turnbuckles. There would be other ways of doing it but I wanted something neat & not fussy. I experimented with heat-shrink tubing, but it looked too old fashioned for this yacht; & settled on using some aluminium tube & brass rod. The tube replicates a swaged joint & the rod tries v hard to look like a neat eye joint. You can see below the parts (ends of swages are chamfered) & the heat-shrink results, which don't look mechanical enough. Glue is CA. Brass rod into a eyelet, the other end of the rod gets glued into the aluminium tube. The cranse iron : Bobstay chainplate: Whisker stay chainplate: The overall. I'm especially pleased with this photo, the rigging joints should not jump out at you, so I think it's more or less in scale visually. thank you
Yes, that's the process I used. Tamiya masking tape from a hobby shop (recommended, great quality), being careful to burnish the edges of the making tape down, especially for the final waterline (boot top line). I didn't thin the waterline paint, so that it was thicker & would hopefully bleed under the tape less. There were some bleeds & I scraped them off with the tip of a knife blade when it was all dry. On the topsides paint, I did multiple thin coats of paint - maybe 4 coats - not worrying about whether is was opaque or not. Sanded between using 000 steel wool, or v fine paper.
Hi Vaddoc I used both acrylic & enamel for my hull, but I've only done it the once to a model so that's not much experience. I got some brushing thinners for both & didn't have any wet edge issues. I used gloss enamel for topsides & matt acrylic for the antifouling paint. Happy with both, but was very impressed with the acrylic - but I'm not sure though how good their gloss level is. The only surprise I found was that the Humbrol enamel really needed to be mixed for 5 minutes or it took days to dry. My experience with painting the model & also full size hulls is that you are best to brush lengthwise along the hull, & try to brush towards the wet paint rather than both directions, although it might not be possible to do that 100%. good luck with it...
Hi Vaddoc that looks great - I would think the deck will be enough to brace it, but bulkheads would be even better. Hi Druxey, I hadn't realised shellac was nasty stuff. Could you explain this, thanks. Mark
sensational Keith, well done & thank you for showing us, it's been inspiring to see all the best, Mark
thanks, it's been great learning how to do metalwork & soldering & the interest is heartening. Art, thanks for that, but I feel that your work on your own current model is beautiful indeed. thanks also Harley, & I looked up what a Ranger 29 is, a new yacht type to me. They are very nicely proportioned & I hope that you did get to sail in one. This yacht will have a large mainsail by comparison, which is good & bad....a 28' gaffer is powerful but maybe getting close to a handful. Sailor, thank you, that's good information. I asked a friend who remembers well many yachts racing before WWII & confirmed that they all had some sort of gammon iron; but interestingly his father's yacht was built without whisker stays because it was easier to drop & retrieve the anchor. Ultimately they did put whisker stays on, as they did more racing & preferred the bowsprit in one piece. Mark
turnbuckle for the whisker stay done & coloured: I was in a quandary about the bobstay chainplate.... the type I want to use has the base part faired to the stem shape; or the alternative is that sometimes the fitting has two plates in a Y, surface mounted on the hull but I am not so keen on that type, I think it would be better to bolt through the stem timbers for this most significant fitting, than laterally through it & planking (maybe solid blocking was used). If the protruding flange was all I made (& pretend the rest was there but just painted over), then fixing it would be tricky as there would be some load on the model fitting. But the base part & flange all in one seemed tough. In the end I shaped it all, cut & shaped down from some brass flat bar about 2mm thick. Then fixed in place. The rivets are glued into holes, & when the glue is dried I will sand the heads down a bit, they stick out a bit too much. Then fill around the sides a bit & paint it, & do the bobstay itself. I haven't gone through it completely in my head yet but I think that then I can do the stays & shrouds. The actual fitting would have a central cast bolt also, behind the flange, but the two end ones must be loose because the three bolts would not be parallel. The fitting is about 20mm long, so 240mm actual, & about 25mm thick actual dimension.
yes, that's it - the fitting at the top of the stem - like this, in this case it also has some bow rollers - but I'm not sure it's needed to hold the bowsprit down in all cases, assuming the bowsprit is housed into the samson post thanks for clarifying - & what do you mean by "gammoning is the rope"?
thanks all. Keith, I stabbed myself with a piece of brass & was bleeding, (& I won't say what I was using as a hammer but it's right up there with using a chisel as a screwdriver). Sailor - thanks, yes that does sound familiar now. Do you recall what the name of the fitting at the top of the stem would be? Gammon....?
It still looks like canvas to me, painted canvas. Interestingly the patterns look like ecclesiastical architecture of the same period ie: gothic; & in some examples shown they have a cross at the peak. Also these last 2 pictures appear again to show the canvas open to the forward side. I wonder if they were an on-board chapel (or maybe just the nave part), & when the canvas was opened to expose the nave & altar - facing forwards - the deck became like the chapel interior. If the outside were painted using architectural imagery, that would also follow. The peak represented the tower....? Would these vessels have had a priest on board?
I managed a couple of hours today of happy modelling & made the whisker stay turnbuckle connections. And this time I thought I'd photograph how I made them, I doubt the technique is original but it is interesting to see how others do things & I've been a bit reluctant considering the refined techniques that others here are masters of - but it's time to be "out & proud" as they say....no more being sheepish about using mediaeval technology. The whisker stay chainplates were already made, & I had purchased some very nice - & well scaled - turnbuckles. The turnbuckles had previously had one end converted from an eyelet to a T end, to allow this junction. The point of the junction is to have the turnbuckle directly connected to the chainplate, similar to an actual rigging detail. The basic equipment - rod, think flat bar & a thicker flat bar for use as a spacer: Bend the thin flat bar, the rod is what I used for the T end of the turnbuckle so it's the correct diameter for the inside of the U: Drill the U bend in the flat bar, the turnbuckle shaft will go through here: Clean up the inside of the U (the sanding block is on 1.5mm styrene, with a rounded edge): Clamp the spacer & squeeze the U closed a bit more, the thickness of the spacer matches the width of the chain plate eyelet: Drill through both: Make a rivet, thicken the end with some gentle taps: Roughly assembled: Cleaned up & fully assembled: 15 seconds in the darkening solution, then installed on the hull by glueing the chainplate rivets into holes in the hull:
Hi Keith beautiful. Also, your techniques were very well thought out. On the prop, I agree with all you said except that you usually wouldn't need to remove the rudder to slip the shaft out: a scallop in the leading edge of the blade would give the space to slide it out with attached rudders like this. Mark
Hi Hakan for this model, are you doing the hull shape by eye - same as you described the actual builders did?
Yes from the picture I'd also guess some sort of fabric construction. I know nothing of these craft, but the artwork itself is interesting: they attempted accuracy, but it was before "scientific" art, "true" perspective etc so it does look a bit funny to us. They showed things in a stylised & perfected way, if it was fabric it was without breeze, dirt, disorder. I can't see the details well on the reproduction, but it possibly looks as if it can be open or closed on the bow side. A bit of shelter is always good on a boat & even better if it's adaptable, could it be as pragmatic as that?
the results with the sails is superb, it shows how much life it gives to a model to have the sails set like that Mark
Hi Vaddoc I bought some 2mm birch 5 ply for the deck (or maybe 7 ply), beautiful stuff made in Finland, it did the double curve well but I used tiny screws to hold it down instead of clamping. The ply curved more easily on one direction than the other, which was used across the hull. A cabin structure - if your model has it - would also act as a break in the stiffness of the plywood & allow it to be more flexible. However, you don't seem to be afraid of a challenge, so maybe planking & canvas....
Hi Hakan I was lucky enough to visit the Danish Roskilde viking museum & found myself chatting with one of their boatbuilders, as (you probably know) it's a living museum where they actively build replicas. I had heard that these boats are flexible & I asked him about it - he gave me a very graphic display of just how much these hulls are able to twist using one of the full sized replicas. If they are intentionally this flexible it is very hard to see how they could be carvel & keep the water out (just as you noted). The internal framing was so simple & light as well. all the best, very interesting & enjoyable build Mark
thanks Dick, very interesting stuff. The space shuttles of their day. One question & one thought: Would the mizzen halyard always be pulling straight downwards, or would the angle of loading vary? When I look at the vangs, I wonder if they were also used to adjust the sheeting angle...in a modern boat to change the shape of the sail the sheeting point is adjustable so you can change the sheeting angle, but you could achieve the same thing by adjusting the angle of the mizzen spar between the forward tackle & the vangs, & flatten the sail or have it full & rounded. Just a thought. Mark
looking good, & your house looks very nice too. I hope the older wooden houses are well insulated Mark
thank you Egen, I appreciate your interest. I'd previously thought the bowsprit looked good, but after looking longer it looked too thick - & also the entasis looked wrong. Rather than a straight taper it was a curved taper & thickest at the stem. So now it's looking better, but it doesn't really show in the photos. It's also finished now too, my usual technique of wiping with a rag dipped in varnish to give a satin finish. As with the other spars the timber is Kauri Pine. The bowsprit cap fitting (correct name anyone?) is done as well, & that photographs well. The drama of shiny brass is interesting but I feel it makes the part look larger, so darkening it will have it looking a little less noticeable & a little more like a practical fitting. The whisker stay chainplates are almost done as well. Simulated rivets, which will also help with fixing to the hull. thanks, Mark
Hi Keith that's an elegant & original design idea, I look forward to seeing it develop. Mark
