Mike Dowling
Members-
Everything posted by Mike Dowling
Neat solution to the light bleed. Wow you are using heavy wire, I hope you can fit it in everywhere. I can't find any pictures under the transparent bit of that building either. It seems a message I added got lost in the ether but your lighting project looks amazing, far too clever for a guy like me. My lighting if it works after all the fairing/planking/ sanding will be an all or nothing job!
I don't know if this is what you mean. I found it on google images of the ship. Whilst I'm here, I have installed all my hull lighting but I am wondering how you have wired all the individual leds you have put on so far. If you are doing hull lighting how will you stop the light bleed from below? Sorry, so many questions for you.
Did you have to cut the upper bulwark shorter at the stern? Mine seem far too long.
- 208 replies
- kitbashing
- Woodcarving
(and 4 more)
Hello again and thank you for your reply to my PM. The reason I didn't ask you in your main log was because I thought my question related to a very early point in your build rather than being an up to date one. Anyway with relation to the bulwarks, did you find they sat slightly below deck level at the sides? And how did you glue them? Did you use CA or PVA and di you put them on wet or dry? A lot of questions I'm afraid.
- 208 replies
- kitbashing
- Woodcarving
(and 4 more)
Finding miniature bolts
Mike Dowling replied to Mark m's topic in Metal Work, Soldering and Metal Fittings
Try prime-minatures.co.uk they do tiny nots and bolts. -
I absolutely agree about the glue. I have always used pva with maybe a dab of ca at the bow just to hold it. Contact glue is ghastly stuff! Always goes where you don't want it and a real problem to remove. My six penny contribution for what it's worth.
You are quite right Jeff, I have just looked at mine again and it does run parallel with the centre line of the ship not angled right or left.
I think he means that the bowsprit is at the side of the foremast, not central on the hull. When I made mine I assumed the bowsprit came across from its seating in line with the figurehead.
I am currently building the same model and I simply have no idea how you managed to bend that curve in the wale at the stern. I have done a lot of bending before but this one is just defeating me. I know it is one huge lateral bend but the wood I have is just splitting. Any suggestions/advice?
- 62 replies
- amati
- greek bireme
