usedtosail
Everything posted by usedtosail
  1. Grant that sounds like the way to go. I just ordered a sliding bevel and will try it out. I also ordered a Digital protractor since I had no protractors in the shop or house.
  2. Welcome Grant and thank you for the likes. I guess I better get to it. I turned the barrel from a square length of boxwood on the lathe. Nothing too difficult here. I used a combination of the lathe cutting tool when I could fit it and files of various widths to get the final result. The middle part of the barrel is still too long in this shot but I turned it down to the correct length after I took it. Today I cut 10 wedges of pear wood that I will glue together to make the blank for the hub and rim. I had some trouble getting the 36 degree angle right on these pieces. I need to find a good tool for setting the angle of the bar on the Byrnes saw sliding table. Any suggestions would be welcome. Here they are along with the finished barrel. I think the hardest part of this project is going to be making the 10 identical spokes. I am working through the best way to turn them. There is a thread on this site that discusses lathe duplicators but it seems people haven't had much success with them. I will have to do some experimenting to see if I can get satisfactory results using a brass template.
  3. Thanks Justin. So I am planking the Duchess of Kingston but I find I have more time in the day between planks, so I have decided to try something along the lines of this capstan project. Have a look here. I hope this works out.
  4. I really enjoyed building the 1:16 capstan from the NRG plans and instructions, and the planking on the Duchess is a slow process, so I thought why not build another ships component in the same scale at the same time. There are very good instructions in TFFM vol. 2 for building a ships wheel, so I am going to use them to attempt to build a 1:16 ships wheel with a similar display as the capstan. I'll have three quarterdeck beams held together with some planking with the wheel between two of them and the hole for the mizzen mast between the middle beam and the other beam. I dimensioned out the drawings from the book for 1:16 scale and started cutting blanks of wood for the barrel, stanchions, beams, and planks, mostly from pear, except for boxwood for the barrel. I am thinking of using brass rings to cover the openings in the outer ring of the wheel but that is assuming I can cut good rings that big. I'll again mostly be using the lathe and the mill for this project, along with the bandsaw and Byrnes saw and thickness sander for cutting the blanks.
  5. I did adjust the dimensions of the grating pieces to fit into the coaming, which I made first.
  6. After I glued the first planks on each side I used a batten to find the run of the planks about mid way down on each side. I measured the distance from the bottom of the first planks to the top of the batten on each bulkhead using a tick strip, then divided those distances by the number of 5mm planks that would fit, which in this case was 9 planks exactly from bulkhead 9 to the transom. For the bulkheads from the bow to 9 there is a taper, although slight after bulkhead 3. I cut the next few planks to these tapers using a jig to hold the plank on edge while I planed in the taper. I soaked the next planks on each side and bent them to the frames, then glued them on when they had dried. I am using wood glue for most of the frames and CA at the transom. I then soaked and bent the next frame on the starboard side, which is where the planks have a severe bend at the transom. I was able to put the bend in as I clamped the plank to dry as you can see here. So now I will continue to plank to the batten line, then start planking up from the keel, starting with the garboard planks.
  7. I installed the capstan barrel and drum head, which completes the capstan project. This was a fun project and I especially enjoyed the scratch build aspect. I am not sure I am ready to tackle a whole ship as a scratch build project but it is not out of the question in the future. Thanks to the NRG and especially Toni Levine for her great instructions and plans, and her help during this build.
  8. I tapered the first planks on each side, soaked them in water and bent them for the bow using an electric plank bender. I clamped them to the bulkheads to dry. This morning I started gluing the port side plank to the frames, starting with the first three bulkheads at the bow.
  9. I gave all the assemblies a coat of wipe on poly then finished adding the pins to hold the bars in place. I glued the capstan base to the beams using the corner bolts to locate it to the holes I had already drilled. I used some weights to hold it down while the glue dried. This morning I started the assembly of the capstan model. I first trimmed the bolts for the capstan base and added them to the base. I then drilled the holes for the brakes and added the pins for them. I put the hatch into the coaming and glued the coaming to the base, again using weights to hold it down.
  10. Here is the jig I made to help taper the capstan bars. The two side pieces are glued to the base board at an angle with just enough room between them for the untapered bar to fit. The board at the top just keeps the bar from moving in the slot. I start by tapering two sides with a small plane, then put a brass shim at the stop to hold the bar a little higher when I plane the other two untapped sides. Then I put another shim over the first and sand all four sides with coarse sand paper, then finish with medium and fine paper. And here are all six bars tapered and ready to finish.
  11. Thanks guys. All good information. I had seen those washers in the Micro Mark catalog but didn't know how they would perform.
  12. Thank you GL and the likes. We are getting to the home stretch now. So I blackened all the brass parts and gave the wood pieces a coat of wipe on poly. I then added the little chain sections to the eyebolts and glued one eyebolt into the cap in the six positions for the capstan bars. I then started making the capstan bars. The instructions say to use a chisel to cut out the sections to fit in the square holes but I used a different method. I set up the table saw with the blade barely above the surface of the sliding table and a depth stop at the length of the section to be cut. I then used the blade like a dado blade and made a series of cuts on each of the four sides of the blank. BTW does anyone know of a small dado blade that would work with the Byrnes saw? Has anyone tried using multiple blades at the same time to get wider cuts? I then used a flat file to file down the excess, starting with the very end until the end fit into the hole. I then removed the excess from the rest until the whole length had a nice tight fit in the hole. I did this for all six holes so each bar is specific to a single hole. I now have to taper these bars and I am in the process of making a jig to help with that. More to come on that later.
  13. Those bulwark pieces turned out not to be too scary. I started with the port sidebar soaking the piece for a little over 30 minutes in hot water. I then wrapped the bow section around a Sanding Sealer can that seemed to be about the right diameter. I have had no success in the past trying to clamp something like this around the can so I can up with a jig using my drill press and some weights to hold the piece in place while it dried. I also used a hair dryer to dry the piece some but left it to dry overnight. This picture is actually the starboard piece in the jig, held upside down. When it was dry I started gluing and pinning it to the frames. I used the pins supplied in the kit which worked great. I used nail insertion pliers after drilling a small hole through the bulwark with a Dremel. I did this frame by frame instead of drilling all the holes before attaching. I had to redo the front two frames because my initial attempt didn't have the bulwark piece all the way into the slot in the bow piece. Once I got to the stern I used a clamp to pull the lower part of the bulwark piece tight to the transom piece. I did the same thing with the starboard side piece and attached it using glue and pins. You can see another clamp being used to pull both the starboard and port bulwark pieces tight to the third frame. Next is the first planking.
  14. I drilled through the holes in the brass rings into the drum head halves and glued in brass nails for the bolts. I filed the tops of the nails flat. As did Toni, I am going to leave the rings and bolt heads bright instead of blackening them. As for blackening, I cut all the bolts I will need for the beams, whelps and chocks and flattened one end of each by placing the rod in a metal vise and hammering it with a small ball pean hammer. I also made the eyebolts for the top of the drum head and cut lengths of chain for the capstan bar retaining pins. I cut the smallest chain I have which is 27 links per inch, which is a little over scale but really the smallest I can work with. Here are all the parts to be blackened, including the brakes that I made earlier. I glued the two drum head halves together last night. I used small pieces of 3/32" square basswood in the slots when I put the halves together to line up the slots but took them out before the glue set up so I wouldn't accidentally glue one into the hole. This morning I turned the cap from a round piece of boxwood I had left over from making the barrel. I first turned it round then faced the outer side on the lathe. I used a parting tool to cut about half way through the blank, then set up the mill with the rotary table and the chuck the blank was in to drill the six holes in the cap. I removed the blank from the mill and finished parting off the cap with a razor saw. I then sanded both sides of the cap to clean up the faces and thin it down. I did not get it down to half an inch actual size but it is pretty thin. I glued the cap to the top of the drum head. Here it is with the six blanks for the capstan bars. And here it is dry fit on the barrel. Once I blacken those parts and give everything some wipe on ploy I will add the eyebolts and chains to the drum head.
  15. I gave the Duchess a little love this morning, although I have been focusing on the capstan project to get that finished. I finished fairing the framing (I think) and glued on the bow piece. That piece fit like a glove and I didn't use any clamps a they tended to pull the bow piece away from the framing. Next up are the scary bulwark plywood pieces.
  16. I have spent this week working on the drum heads for the capstan. I milled the slots in the upper drum head to match those in the lower head. I held the drum heads together and marked the locations of the lower slots on the upper and used the marks to align the mill bit as I cut the slots. I cut each slot only close to the center not all the way through as I did the lower. This helped with any misalignment that may have been present to all the slots had a better chance of lining up at the edges. I also milled away the center part of the upper drum head to fit over the end of the square part of the barrel. This is necessary because the top of the barrel is 6" high actual and each half of the drum head is 4" high, so an extra 2" in the upper head is needed so the drum head sits flush to the tops of the whelps. This isn't shown in the plans. After this photo was taken I milled the square hole in the lower drum head to fit on the square part of the barrel. I then worked on the rings for the drum heads. I used Toni's alternate method and made the rings from 0.016" brass sheet, using the rotary table in the mill to drill the holes and cut the rings out of square pieces of the brass sheet. I screwed two squarish pieces of the brass sheet to a piece of wood and used the 4 jaw independent chuck to hold it to the rotary table. I drilled the 12 holes first with a starter bit then a regular drill bit. After I cut out the rings I cleaned them up with files and sand paper and glued them to the drum heads with medium CA. Here they are before I glued them down. I will add brass bolts in the holes and make the cap for the upper head next.
  17. Here are the completed whelps and chocks after sanding the lower chocks to be flush with the whelps and the bolt holes in the chocks have been drilled. I am pretty happy with the outcome but it could be a lot better, especially the positioning of the chocks. If I were to build this again I would find a way to mill all the grooves for the chocks at the same time so they would be more evenly lined up. Making a jig that would hold each whelp separately for milling would have worked better too I think. Oh well, this is a learning experience isn't it.
  18. Thanks for the tip Greg. My stack is actually two pieces glued together so I will be separating them and milling the slots in each half. They are not two semi circles though as per the instructions so I will be leaving the upper and lower halves as full circles at this point. I set up the mill with the rotary table and put the drum head blank in the vise. This was a little tricky as I had to make sure the rotary table was centered, then the vise on the rotary table, then the blank. Once I was happy with the centering process, I milled the three slots for one of the drum heads. I can use this for either the upper or lower drum head since I milled out the dimple from the live center. I have the blank soaking in isopropyl alcohol now to separate the upper and lower drum heads and the square block holder.
  19. I also started making the drum head pieces while waiting for the chocks to dry in the whelps. I glued up two square-ish pieces of 4" pear sheet with a square chunk of boxwood to hold them in the lathe. I let that dry overnight while clamped in a vise, then used the band saw to cut the corners off and square up the inner face of the holding block. I chucked the blank in a 4 jaw independent chuck and centered it using a live center. I then used a flat chisel on a steady rest to turn the blank to a circle, which only took about a quarter hour. I then used the lathe cutting tool and DRO to get the blank to the final diameter.
  20. After the whelps had dried on the barrel I fit the five upper chocks. The angles of the sides had to be adjusted a bit on the blanks which I did with the disk sander as I sanded in the bevel on the edges. Once I had a chock with a good fit I marked the location on the top where the edges intersected the whelps and drew an arc between the points. I trimmed off the excess close to the arc and glued that whelp in. Here is how it look with all five chocks glued in but not shaped yet. I then used a Dremel with a sanding drum to lightly shape the outside edges of the upper chocks, then s sanding block to get the edges flush with the whelps and curved to look like they are all part of a circle. I then shaped the lower chocks using the same procedure but with the thicker blanks. These have a shallower angle on the edges. I also marked an arc on these when I had a good fit but this time it was a concave arc. I cut a small piece of boxwood to the correct arc and used it to mark the tops of the lower chocks. When I had five chocks with a good fit I glued them in place. Here is how it looks now while I wait for the glue to dry to do the final shaping.
  21. Tom, I have been following your build with a lot of interest. It looks like something I may try to build sometime in the future. I don't know if you have seen this before but... https://www.google.com/maps/@42.3724294,-71.0563979,3a,75y,320.17h,95.15t/data=!3m6!1e1!3m4!1s6yRcVEMl1hYAAAQZLBJ9aQ!2e0!7i13312!8i6656 it allows you to take a virtual tour of the Constitution from a few years ago. I found it very helpful especially for gun deck details when I was building my Connie model.
  22. I glued the lower deck onto the frames and clamped the edges as it dried. I then wanted to test fit the upper deck and got it half way on by bending it pretty severely. At that point I didn't want to try taking it off, so I put glue on the frames and got it to sit the rest of the way on. It did snap nicely into place with no part of it away from the frames, but it is as scary as it seems. I did manage to break off one of the bulwark extensions so I glued it back on but it won't really be secure until I put the temporary beams across.
