As you say Allan it is a kit limitation; the keelson, such as it is, sits below the footwaling. Modification would entail messing with the provided part - a step too far given that little of it will be seen once the thwarts are in place. B.E.
- 644 replies
- Indefatigable
- Vanguard Models
Post One Hundred and Fifty- nine. Building the 32’ Pinnace (Part Two) Freed from its building frame and the centres removed the process of fitting out can begin. I have always been amazed that twisting away the mdf centres leaves the hull intact with little trace of their removal…. But not this time; - the planking partly disassembled, requiring careful re-fitting and use of diluted pva on the inside to stabilise the hull. How this will impact on the build remains to be seen, but it may be necessary to paint the inner bulwarks. 4008 I made a Styrene foam cradle to support the hull whilst attempting to clean up the inside. I used a combination of micro chisels, pen sander, and sheets to remove the glue adhesions and rough surfaces. This is quite a fraught operation and needed careful handling. I take notice of where areas will be covered by the footwaling, fore deck, benches and thwarts, and make pragmatic decisions how far to take the cleaning up in these areas, against risk of further damage. 4007 I wasn’t too keen on the set-up at the stern, so I installed a stern post. I dislike the brass etched rudder facings, supplied with these kits, convenient as they may be. The wooden rudder core was faced with 0.6mm pear and then sanded down to shape. The hanging arrangement will be modified to reflect the true set-up. 4020 Unlike my previous experience of Vanguard boats the Pinnace has Pearwood gratings and footwaling which I like. More convenient and natural looking than the brass etched versions which require painting and sticking with ca. At this stage there are a few additions one can make to the boats to add realism. Lifting ringbolts to the footwaling, and mast steps as shown in the above photo. 4016 I divert from the kit when it comes to fitting the thwart supports, I leave them extended to the stern to support the sternsheet benches. 4017 The benches are provided as a unit including the aftermost thwart. 4025 I prefer to cut this away, modify the benches and add the thwart as a separate item. I have added a panel below the aft seat which will double up as a compartment. When it comes to the cox’n seat there is a slight issue; a grating is provided, but it sits far too high to be a practical platform for the Cox’n ‘s feet. 4032 It is prevented going lower by a ledge forming part of the keel set-up. Careful paring away of this incumbrance allows the grating to sit at a more realistic level. A minor point maybe but the detail devil in me wouldn’t let it go. 4037 The bow platform comes as a pre-cut item which wasn’t a good fit on my build no doubt because of my failings. Fortunately, there is plenty of fret to re-make these items. 4028 Still very much w-i-p and a lot yet to do. B.E. 21/03/2024
- 644 replies
- Indefatigable
- Vanguard Models
Thanks for the links Allan, I agree the convention for Pinnaces was for a single banked set-up with the thole pins off-set port and starboard. There is 1:48 scale drawing of a 32’ Pinnace in the AotS book Diana which also shows a bench board running down the centre between the thwarts. This feature also shows on the Adm drawings. I will look to at least modifying the thole pin set-up on the kit Pinnace. B.E.
- 644 replies
- Indefatigable
- Vanguard Models
Post One Hundred and Fifty- eight. Building the 32’ Pinnace (Part One) This is the one boat example that I may include on the skids of my Indy. I think the Pinnace is the nicest looking boat type and my go to for display on a ship. I have built an example of every boat type in the Vanguard range, and my detailed logs are elsewhere on MSW, most recently on my Sphinx log. My approach in building the Pinnace will be as previously recorded, so I’ll include less detail with this log. There are a few areas of approach to building these bijou boats that may be of use to others. Setting up the frames. These are delicate parts and I like to protect the framing, and I add support pieces to protect the bow and stern. 3981 These slotted strips protect the very delicate stem by avoiding the risk of flex when fitting the first strakes. 3979 At the stern the transom is secured square. 3982 This is a weak part and support boards are added to reduce any risk of flex during fairing or attaching the planking strakes. The planking strips are nominally 2mm x 0.8mm and as I found with the Sphinx Pinnace, they have very little excess in length to accommodate edge bending which applies very near the bow end. 3984 Both lateral and edge bending and also a degree of taper is required to maintain the flow of planking. These features were applied once the first plank had been installed. 3988 The first four planks fit into the stem rabbet, followed by the addition of the Garboard plank. For the Garboard I used a wider 3mm strip. 3993 Planking continues to completion. The final spiled plank that sits below the round of the hull is traced onto Tamiya tape and cut out of the 0.8mm Pear fret. 3998 3999 Three days’ work and the planking is completed, albeit still in a rough state. This will be cleaned up before moving onto the next stage. B.E. 16/03/2024
- 644 replies
- Indefatigable
- Vanguard Models
Post One Hundred and Fifty- seven Mast Making. Starting with the Mainmast:- For the reduced height masts I firstly need to work out the relative positions of the wooldings, iron bands, and the point where the side cheeks and front fish terminate. 3967 I replaced the Pear laser cut cheeks and fish with Boxwood versions to better match the Ramin masts. The iron bands need to be fitted before the cheeks are put into place. With a 12mm ø mast my go to use of heat shrink tubing will not work, so it’s back to thin strips of black card. Once the cheeks are fitted the remaining iron bands need to be applied, they sit beneath the Front fish. I work the bands so that the join will also be beneath the Fish. 3970 The Fish is then fitted 3972 3973 3974 3976 3977 The saddle for the Driver Boom was also replaced with a Boxwood version. 3978 3971 The woolding remains to be done, but I am out of the correct line sizes. B.E. 12/03/2024
- 644 replies
- Indefatigable
- Vanguard Models
Ah, but where did they get them from😉 B.E.
- 644 replies
- Indefatigable
- Vanguard Models
Post One Hundred and Fifty- six Bits and pieces From this point on the comforting crutch of the glossy manual has ended. There are many small fittings to add and in this session I will mainly be referring to Plans 5 and 9. Working from in to out there is brass wire(0.8mmø) to be inserted thro the faces of the skid beams across the waist (plan5)- shown as belay pins on (Plan 9). 3955 The arrangement seems to have been taken from that of the Victory where one rigging source indicates that the triple aft three relate to the belay of the Staysail sheets and those on the second from forward beam for the Main Topmast Stunsail downhauls. Fortunately for me this has no practical application. 3946 The inner guide rope stanchions (PE59) are fitted along the waist gangboards followed by a wooden rail (2X1mm Pear) atop the inner hammock crane arms, the fit into the brass etched crutches is perfect. I have diverted from the plan by adding iron stanchions between the timberheads around the Fo’csle. 3953 Not provided in the kit I used spare items from the Sphinx kit- a slightly shorter stanchion. It seemed reasonable to me that given the low height of the rails, stanchions would have been fitted. The kit provides etched versions of the belay pins, they are a mere 8mm in length, and barely 0.8mm in width, but still have a visible shape, and I think they look quite good at the scale. 3947 3956 Blackened to give them some tooth and painted a bare wood colour I added a few to the pin rails for effect. 3949 There are quite a few eyebolts to add along the channels together with the iron work for the Main studding booms. I dare say I will find other little additions as I continue to re-check the plans but for now I am moving onto dressing the stump masts. B.E. 10/03/2024
- 644 replies
- Indefatigable
- Vanguard Models
Thankyou Yves, the drawings in the AoTS Bellona provide a good guide, and the given anchor dimensions for a Seventy-four are taken from Steele. If your anchors match the scale the arrangement looks ok to my eye, at least on paper. 'Indy' is more problematic, ideally the anchor arm should fit between the first and second deadeyes, to bring it as close to the hull as possible, but there is no room. This accords with the Adm plan. The aft bower is easier as it will fit as per the Bellona drawing. Victory had a different arrangement. 1834 Here, Billboards and linings are dispensed with and the anchor fluke sits in a heavy shoe. How they manipulated that 81cwt lump of iron into position without marring that pristine paintwork I can only wonder at.🤔 These of course are replicas. B.E.
- 644 replies
- Indefatigable
- Vanguard Models
Thank you Bug, glad to see work has restarted on your Pegasus.👍 Post One Hundred and Fifty- five I continued to fit the Port side billboards and linings. 3939 3936 3937 I think I have made a better job of the Port side, so off came the starboard side for a re-fit. 3941 Starboard side re-done, happier now. 3942 I have also taken the opportunity to replace the bow port lid and add double lifting lanyards. 3852 Small sections of telephone wire sleeving are used to represent the port lanyard tubes, but they did need drilling through to take the 0.30mm line which was stiffened with ca for the purpose. 3932 Another small job is to add the rudder chains. I used some Caldercraft Brass chain, 18 links /per inch. I will get around to trimming them at some point. B.E. 08/03/2024
- 644 replies
- Indefatigable
- Vanguard Models
Post One Hundred and Fifty- four This post follows on from Post 152 having a close relationship to anchors. One of the reasons I made up the anchors is that I have also been thinking about anchor linings and billboards. These do not feature with the kit and do not tend to appear on contemporary plans. Many contemporary models show them, as on Amazon above. They were an important feature on ships of the period to protect the hull from the anchor flukes. Chuck’s Winnie My go to reference, here you can see the lining running over the wale. 7396 I added billboards to my Sphinx build as above. 3906 Having an anchor made up is useful in that the arc made by the anchor as it is swung horizontal from the cathead for securing, determines the position of the lining and billboards. In considering Bolsters and Billboards for Indy I am hamstrung by the absence of specific sizes of timber to use. With Sphinx it was relatively easy having the TFFM book to refer to. I know where these fittings were placed so it is basically down to what looks good to my eye. I firstly made the Bolsters using some Boxwood square stock of 2.75mm. This was topped by some 3.5 x 0.7mm boxwood strip. 3910 The length of the bolster worked out at 26mm. Notches were cut out of the back side to fit over the first two preventer plates of the Fore channels and a slight curve was induced to match the curve of the bow. The bolster was fixed to the Black strake only with pins. 3913 With the bolsters in place the Billboards can be made. For this I use some 1mm Boxwood scrap inscribed with 3mm wide boards which reflect the topsides planking. The Linings 3914 These cover the main wale in the case of Indy and scribe an arc at the fore end that follows that of the anchor swing. I settled on using some 0.6mm Pearwood scrap which suits my eye. 3917 3919 3929 In fixing the linings I have used double sided tape. This gives me the option of easy removal if I decide I don’t like them, and the jury is still out on that. Altho’ I’m not fitting the anchors I don’t think it will be an easy fit to get the bowers to look right. 3923 3924 If the bill is to rest on the Fore channel there is little room between the deadeyes. 3930 A possible fixing with the arm atop the fore end of the channel secured with shank painters around the timberheads. I will be interested to see how others tackle the anchor rigging.🤔 B.E. 07/03/2024
- 644 replies
- Indefatigable
- Vanguard Models
Thankyou Guys for your comments and 'likes' @ Alistair - that shelf is going to need some heavy duty brackets.😉 B.E.
- 644 replies
- Indefatigable
- Vanguard Models
Thank you Walter and Nipper. @ Nipper - I used Syren 0.3mmø line which equates to 2½” circ. (Lavery comments that in the 1780’s port ropes were usually of 3” rope.) Cheers, B.E.
- 644 replies
- Indefatigable
- Vanguard Models
Post One Hundred and Fifty-three Anniversary Today marks twelve months since I started this log. I have worked several hours, mostly each day, over the period and have included many modifications to the basic kit, some obvious, some not so, and some now hidden. That such a large and detailed model can be constructed to this stage in such a relatively short time is all down to Chris’s planning and design and the quality of the fittings. Apart from a few minor additions, the hull is effectively completed. To mark the occasion, I cleaned up my workbench, and took some photo’s using my tripod rather than the usual handheld w-i-p shots. 3854 3899 3900 3901 3898 3863 3886 3876 3878 3889 3897 3895 3896 In the earlier stages of the build, I didn’t have the same sense of enjoyment I had with Sphinx, perhaps because it is a more difficult model to manoeuvre during building, it is large financial investment you don’t want to mess up, and it is a far testier challenge than Sphinx. More recently, with the build challenges mostly behind me, I have warmed to the task, and there’s no denying the ‘Indy’ model certainly has that WOW factor. Mrs W loves it, even if she is still asking where I’m going to put it.🫤 3905 Getting there Gov’nor, getting there. Cheers Gromit. B.E. 05/03/2024
- 644 replies
- Indefatigable
- Vanguard Models
Post One Hundred and Fifty-two Anchors As a change of scene, I thought I would make up a couple of the anchors. The kit includes the four main bower anchors, if the smaller stream and kedge anchors are required they are easily obtained using aftermarket suppliers. The kit provided anchors have a scale shank length of 77mm (16’ 2”) which equates to a weight of 43cwt This weight falls between the allocated anchor weights for 38-50-gun ships. The outer diameter of the ring is 29” which scales to 11.5mm. The thickness of the ring scales to 1.4mm. A 64-gun ship had 4 bowers at 57cwt plus stream at 15cwt and a kedge of 7cwt 2qrts. The kit anchors are 3d printed and very finely sculpted. All the subtle features are moulded into the shank and arms. I think the day of the white metal anchor is coming to a close. As with all resin stuff the parts need washing and priming. The stocks are pre-cut from Pearwood and are faced with a thinner veneer that contains the Trenails correctly positioned and with engraved markings for the iron retaining bands. 3831 The only modification I felt necessary was to taper the arms thickness a little from outside the central area towards the outer ends. This reflects a more authentic shape. Once primed, I used Vallejo black/grey, followed by dark brown /rust weathering powders. 3824 The anchors on the left have had the weathering treatment, those on the right as painted. 3830 Brass wire of 1.4mm ø was used to make the rings which have an outside ø of 11.5mm. 3835 The ends of the rings were reduced in size to fit the shank and chemically blackened to give a little tooth for the puddening. The stock halves have mortises cut into the inner sides to fit against the shank. There should be a gap between them but I thought it a tad too large so I deepened the mortice somewhat. Glued together the facings are then added. 3834 Those familiar with my stuff know that I favour heat shrink rubber tubing to represent iron hoops. The final part is to add the puddening to the anchor ring. I used Syren 0.45mm ø and Morope 0.1mm stuff for the seizings. 3838 In applying the puddening unless you glue the ring in place it needs to be held steady. As I work around the ring I apply pva to help keep it in place. 3842 3847 3849 Capt. Pellew is dwarfed by Indy’s anchors. I won’t be fitting or rigging the anchors but as far as I can see there is no reference to this in either manual or plans, so other sources will have to be found; fortunately there are many available. B.E. 02/03/2024
- 644 replies
- Indefatigable
- Vanguard Models
Post One Hundred and fifty-one All things brass A few days taken up with the fitting of deck eyebolts, stanchions, and hammock cranes. 3810 These items are beautifully crafted by Chris particularly the waist cranes with integral retaining hooks and eyes. Cranes also line the Qtr deck bulwark and are placed atop the Qtr deck breast rail. Before removal from the fret I clean with fine steel wool which aids the subsequent blackening process. 3813 Once removed the Qtr deck cranes needed careful cleaning up to remove all traces of the fret nubs and are then trial fitted to reduce handling later. They are given an acid bath, followed by the blackening procedure. 3818 3819 3814 I use 0.5mm ø brass tubing to maintain the line whilst progressively fitting the waist cranes. 3815 3816 3817 3823 I did notice that cranes or stanchions are not provided for the Fo’csle rails between the timberheads. Should there be, I don’t know. 🤔 Victory was equipped with cranes, and the Sphinx model has stanchions around the Fo’csle. The contemporary model of Amazon (32) 1773 had stanchions around the Fo’csle between the timberheads. I am inclined to think that 'Indy' may have had them for safety on the exposed Foc’sle, particularly as we know these razees were prone greater rolling. I’ll have a ferret thro’ my spares box and see how they look. B.E. 29/02/2024
- 644 replies
- Indefatigable
- Vanguard Models
I am impressed by your build Kurt, more so by the difficulties of creating a 1:96 scale build out of a solid hull. That it is your first venture into wooden ship modelling make it even more so. You have produced a fine model of which you should be justly proud. Well done.👏 B.E.
- 110 replies
- Bluejacket Shipcrafters
- Constitution
Thank you, Daniel, hope things are good with you. I have not seen any contemporary information regarding the lead of the pendant and I don’t know whether the knot is a modern convention simply to secure the line, or if a further line was eye spliced to the knot, and set up with a tackle. The arrangement on that wonderful Victory model would seem to fulfil most model making requirements. Harland (Seamanship in the age of Sail) covers various mishaps to wheel and rudder and courses of action to counter them. He mentions the pendants in relation to the loss of the rudder head and use for steering. He shows a tackle secured to a beam athwartships, and a jury rig to the wheel on a Frigate. Re: the leather tubes for the lid lanyards; I did the same as you for the stern ports, but for broadside ports, I am thinking of using the sleeves from telephone wire – if I can remember where I have put my supply.🤔 Regards, B.E.
- 644 replies
- Indefatigable
- Vanguard Models
Post One Hundred and fifty Completing the ports The two enclosed Qtr deck ports remained to be done. Usual top hinged lids into the Great cabin, and a pair of side opening doors into the Coach and Bed space. 3660 I thought I had done with queries about ports, but I’m not entirely convinced why side opening doors are shown in the position they are, constrained by Mizen chains which only allow them to open half way. They are a feature usually found in positions above the channels, or at the foremost bow port, where space is restricted. 2231 This shot onboard Victory taken when I blagged my way onto the Poop deck shows similar doors in place. The photo also has other interesting features. Note the tube thro’ which the port lid lanyard goes inboard, and that the port only has one lanyard presumably due it being of lightweight construction over a Qtr deck cabin. The final interesting feature for detail fans is the knot secured on the Mizen channel. This is the reason at the time I wanted to look over the Poop. The knot secures the Rudder pendant which attaches to the chains and is used to control the rudder should the tiller lines be shot away. Back to INDY.. Notwithstanding the above, the side doors do make a nice feature and provide additional interest to the build, more so if displayed closed. 1901a I used a normal port lid as it makes more sense to me. Stern Ports There are two stern ports engraved on the lower counter, the plans show use of provided hinges (PE47) over the patterns, but I didn’t seem to have sufficient to do this, but the Laser board Syren straps filled in nicely. 3794 This is not a very prominent area of the model but that is no reason not to enhance it. 3796 Addition of double lift rings and lanyards complete the effect. 3800 The trickiest part is securing the lanyards thro’ the lifting rings using a false splice. 3799 Getting the needle thro’ the 0.3mm line is a severe test of my aging eyesight. 1900a Still lot to do on this build. B.E. 26/02/2024
- 644 replies
- Indefatigable
- Vanguard Models
Chuck produces a lot of stuff useful to non Syren kits builders, and I see he now has working port lid hinges (Winchelsea) which may adapt to smaller scales. His Laser board rudder /pintle sets are my go to for use on the Vanguard kits I have built recently, and easily double for lid hinges. For 'Indy' Chris has supplied laser board straps for the Rudder, for me, brass etched rudder straps are a thing of the past. B.E.
- 644 replies
- Indefatigable
- Vanguard Models
Very nicely done Walter, excellent progress. 👍 B.E.
- 94 replies
- flirt
- vanguard models
Nice progress Andrew, and that subtle weathering of the lower hull has worked a treat.👍 Not too sure about those belay pins tho' ! Regards, B.E.
- 106 replies
Thank you Ron, and Allan for your input. 3787 Chris has done a great job on designing and producing the strops/chain link combinations to allow the fitting of these with the minimum of fuss, and with an excellent result. 3789 The trade-off is that the middle link chains of necessity have a tiny gap that is necessary for linking the strops to the lower chains and is a simplification much appreciated. The middle links should retain that elongated oval shape and personally I don’t think they are improved by either turning them into effectively an iron strap with eyes either end, or trying to squeeze the gap together that risks deforming that perfect oval shape. David Antcherl does indeed cover the making of chains from scratch very well, but in this case, and at this scale, even my inner pedant recognises that rejigging the chains is simply not worth the effort of messing with Chris’s excellent set-up. B.E.
- 644 replies
- Indefatigable
- Vanguard Models
