Posts posted by Chuck Seiler
- mtaylor, Elmer Cornish and tarbrush
3
I forgot to mention in the previous pic that while the interior planking is stained with GOLDEN PECAN, the exterior is PECAN. It provides a dirtier brown finish, giving the rustic color I am working for. I will endeavor to get a good exterior shot.
Another lengthwise shot of the completed hull. Thole pins bitts and cleats are mounted.
A close up shot of the bow section. Shot rack with 12lb shot is mounted. Note nail heads in the deck planking. Iron nails were a lot easier than traditional tree-nails to make and use. They were not too concerned about them rusting away since they didn't anticipate the ship being around long. Ironically (IRON-ically...get it) the nails still exist..a bit corroded...in the actual ship. (See early picture) A lot of nails were used to keep the thing from coming apart every time they fired the guns.
Close up shot of the stern. The arms locker hold spare shot and a few drill bits. Holes in the caprail are for awning stations.
Next step....the cook stove.
THAT LOOKS LIKE A MIGHTY FINE CARGO HAULIN' BATEAUX. ARE YOU SURE IT'S A GUNBOAT?
You have a keen eye my friend! the gunboats were pretty much designed after the bateaux used in the area. Allegedly, Arnold wanted the gunboats to be like the ones on the Delaware River but nobody had the plans and didn't have time to get them. He redesigned the boats because the shipwrights and carpenters available had been building bateaux for a year in order to ferry troops and supplies up and down Lake Champlain. It was more important to have hulls in the water than have masterpieces sometime in the future.
WOW!
Indeed.
- captainbob and Mike 41
2
Thanks David. I hope you enjoy the progress.
Not a whole lot got done between July and December. I took some pics in December and they came out blurry. They are the only ones I have, so.....
Forward gundeck in the process of planking. The 'slide' for the 12 pounder is in place. Note the large 2 foot wide planks here as well as the center deck.
A lengthwise shot showing all decks. Support stanchions for the center gundeck (heretofore called the POOP!!!!! deck) are taking shape. After most deck planking is narrower than other two decks...a mere foot and a half. Weapons lockers are marked out aft.
- mtaylor, Mike 41, Elmer Cornish and 1 other
4
It is almost at the end of the Fair....1 day to go. I have the interior planking done and stained. I did not go all the way down to the bottom with the interior planking because I wanted space to be able to work the exterior planking. The interior is stained with Minwax "Golden Pecan"
You see work on the middle deck planking progressing. On this model, this is the poop deck. I had the planking completed and I placed a prototype of the 9lb gun on it... "Poop" <I sez>. The muzzle did not clear the caprail. I had to add another layer of planking to make it work.
On the actual ship, the forward deck is the poop deck. When they loaded the 12 lb gun forward, "POOP!!!!!" it failed to clear the stem and caprail. They ended up having to cut away that portion of the caprail and a piece of the stem. Unless I tell you, you would never know I had an extra layer of planking. It is hard to miss the cut out stem.
Exterior planking takes shape. Planks are same size (scale wise) with the same buttjoints as the real ship. The upper three strakes are slightly different widths, but approximately 1/8" (6 scale inches). The lower 4 strakes are all 1 foots. except here narrowed. Interior planking is all 1/8 inch (6 inches).
Then what will I bring for the Wednesday meeting?
Check out BoBF's build log for the 18th Century Longboat. He discusses edge bending.
Another way to do it is to position the basswood blocks at the edges of the bulkheads so they overlap the edges. They would have to be sanded down to match the curve. The end result is not only a more stable frame but a better surface area for planking.
The previous stage was late May 2013. I was on a building binge so that the model was ready for me to take to the County Fair.
By early June I had the upper three strakes of exterior planking installed, the center cross supports are all raised to the correct level (I thought) and the middle two planks on the center gundeck. If they look overly wide, they are. They are about two scale feet wide...but that is what the plans call for...because that is what the ship has. Deck planking is holly. Exterior and ceiling (interior) hull planking is boxwood.
I took some basswood the thickness I wanted my frames and ran them between the bulkheads, attached to the exterior planking. I would then sand the bulkheads down to the proper thickness...making them frames. There are a little over twice the number of frames on the real gunboat as I have. Here you see the bulkhead sanding process almost complete. The master shipwright surveys his work.
A look from a different angle. Note the cross supports forward have not been fully raised. I want to complete he ceiling planking before I do that.
A look at the sternpost. Note 'wings' used to help anchor planks
A look at the stem. No wings.
The beastie is starting to take shape.
- BRiddoch, Mike 41, SawdustDave and 7 others
10
Ol' Salt,
Arnold was wounded twice. First time was during the failed assault on Quebec. The second was at Saratoga...same leg. After he had turned coat and was working for the British, he was a brigadier in the Carolinas. He allegedly asked a captured American officer what he thought his troops would do if they captured him (Arnold). The response was 'Bury his leg with military honors. Hang the rest of him from the nearest tree.
Next, I had to make and install the bulkheads. The plans had no good 2 dimensional diagram plan for bulkhead as some of the Model Expo plans do. Instead it had the 3D/from an angle diagrams. So I improvised. In the past I have build bulkheads using the line and sheer plan normally embedded on most plans. In this case, I would only make the sides and connect them using built up cross member pieces. As it turned out, all bulkheads except the forward 2 and aft 2 had the exact same curve. The only difference was height. Easy to make.
I installed cross supports at the bulkhead locations and eventually added the sides. Care was taken to ensure they did not tilt, thereby changing the curve. The bulkheads were made much wider than I would eventually need. This provided a more stable base for mounting and provided more meat for faring. This was particularly important in the bow and stern. Cross supports would eventually be built up to support decking.
Fore and aft cockpits have been planked. The "keel" is sticking up in aft cockpit (right).
Notice the Bailing Pit in aft cock pit (square dark colored wood). This was a cutout section that gave access to the bilge/bottom planking area in order to bail out water with a water scoop they had. Scoop to bucket-pour over the side. This might have been fine for day to day dewatering, but it failed when needed most. If you look at the picture of PHILADELPHIA sinking at the top of the thread, you will see it sinking by the bow as a result of (1) the hull being holed by a 24 shot in the bow and (2) the weight of the 12lb gun and related gear. They know it was a 24lb shot because it was still wedged in the hull when the wreck was brought up. It is also on display in the Smithsonian...wedged in the hull.
Solid basswood blocks placed for future use (to support pedestals).
Let's begin!!!
The model, like the gunboat itself, is pretty simple. Start off with a flat bottom and work your way up.
Using the Model Expo plans, I made two identical half bottoms and glued them to a center false keel. This was to provide me with a completely symmetrical hull. (yeah, so how did that work out?) The bulkhead locations were marked on the bottom to help line up the two pieces. As you can see from the photo date stamp, I started this project almost a year ago.
The two pieces were affixed to the false keel inside-side down. This allowed the wood to stick up and serve as a guide for bottom planking. Before planking the bottom, bulkhead locations were transferred to the inside side.
Once the bottom was planked, the whole shebang was sanded flat. I did this so the model would sit flat on the work surface. Eventually I will add the keel, which is only about 3 scale inches. It was more for structure than anything else and didn't contribute much to its sailing qualities. The PHILADELPHIA only sailed in one direction--directly downwind, but when you could, it was better than rowing.
- mtaylor, Elmer Cornish, tarbrush and 1 other
4
Ano,
I noticed you are building a 1:48 HMS FLY. It our County Fair, our of my Guild associates was building a 1:48 FLY as well. We would point out to the passers by that they were the same scale, same year but PHILADELHIA was much smaller but had larger guns.
From John Fox from one of the other discussion groups:
"Check this out!
http://3d.si.edu/explorer?modelid=47
Pan, zoom, top, bottom, P&S views of Philadelphia as she sits in the Smithsonian. There's a measuring tape you can use to find dimensions and spacing of chosen features, like beam and frame spacing.
Now that is truly a cool thing to view!"
It requires Internet Explorer 11 to view (which I don't have yet...but I see it in my Update queue to download).
- mtaylor and AnobiumPunctatum
2
The PHILADELPHIA 's sinking was it's eventual salvation. Having sunk in cold, fresh water, the hull and ironwork was saved from major deterioration for 160 years. In 1935 Colonel F. Hagglund, an experienced salvage engineer from New York, located and raised the PHILADELPHIA. After Hagglund's death, Philadelphia was donated to the Smithsonian's National Museum of American History, where she is on display to this day.
GUNBOAT PHILADELPHIA as it is today
I have no idea who these folks are, but it demonstrates proportion.
- mtaylor, harvey1847, Elmer Cornish and 6 others
9
As early as mid 1775 it was understood that Lake Champlain was a key highway between British controlled Canada and lower New York. Fort Ticonderoga and defense of the lake were critical. After a failed attempt to take Quebec from the British and effort to lure the people of Canada into the war on the side of the Yanks, American forces retreated south on the lake. Defense of the lake was about to begin.
Major General Philip Schulyler (commander of the northern department) had already started a 'ship building' industry on the site of a captured sawmill in Skenesborough (now Whitehall, NY). The site was used to build cargo batueax to transport troops and supplies up to Canada. The mission was quickly changed to the building of warships.
Construction began in August 1776 at a slow pace. Carpenters, riggers were reluctant to leave their lucrative businesses on the coast. Finally lured by higher wages, and despite the heat, mosquitoes, black flies, and long days, these craftsmen completed eight 54-foot gondolas, including PHILADELPHIA, and four 72-foot galleys in just over two months. The hulls were fitted out at Fort Ticonderoga. Across the lake at Mount Independence, they were moored at the foot of a shoreside cliff; spars and guns were lowered from the top of the cliff into position on board.
PHILADELPHIA carried three carriage guns, one 12-pounder, and two 9-pounders, and eight swivel guns. She had a single mast with a square-rigged mainsail and topsail. Her crew of 44 was captained by 25-year-old Benjamin Rue, from Pennsylvania. With little experience in boat handling and none in naval combat, Rue's men typified the troops described to Major General Horatio Gates, as "a wretched motley crew".
This fledgling fleet spent the majority of their time that late summer and early fall of 1776 patrolling the lake in anticipation of the completion of the British fleet in Canada. Finally, on October 11, 1776, the British were carried southwards on a north wind. The American fleet was moored in a protected bay between Valcour Island and the New York shore in anticipation. The British did not enter the Valcour Island passage from the north, but instead ran south to the east of Valcour Island, which meant that to engage the Americans, the British would have to sail into the wind, putting them at a disadvantage.
Despite this initial advantage, the British fleet was much more powerful than the Americans. At the end of the 6-hour battle, the schooner Royal Savage had been captured and burned, and the gunboat PHILADELPHIA sunk. Other vessels sustained damage, and sixty men were killed or wounded. The British decided to wait until morning to finish off this rebel fleet, which proved to be a poor decision. During the night, the cunning Benedict Arnold led his fleet in an escape, rowing silently right under the noses of the British. The British gave chase. Within a week the entire American fleet had been sunk, scuttled or captured.
REPLICA GUNBOAT PHILADELPHIA PLIES LAKE CHAMPLAIN
- Red, ElPasoMark, coxswain and 2 others
5
Mark,
I include Chuck P on my distro as well. I understand he is a busy guy.
Floyd, send me your email address in a personal message if you want to get our newsletter.
Floyd/Bob,
No, it is not done. I have made no further progress. Our club's Evil Guildmaster made me take over the club newsletter. Then he threatened us with all sorts of mayhem if we didn't get 12 models entered into the county fair this year. Oh the humanity!!!!!
Seriously though, I didn't like the way it was going and wanted to incorporate changes I had seen in other logs. I had acquired a kit from one of our members who wanted to build, but ended up not being able to. I am using the semi completed boat as a demo piece that people can hold and look at.
Meanwhile, build log for Gunboat Philadelphia has begun..........
Commentary on plans and references. My primary source document was/were the Model Expo plans; six sheets. I had them reduced from 1/24 to 1/48 at Kinkos, making several copies of the pages I knew I would have to cut up for templates, etc.
At first I was disappointed with the plans. While it provided excellent detail in some areas in 3D and exploded view, it did not provide diagrams of the bulkheads so they could be easily made. Since these plans were for a kit in which the bulkheads were already provided, NOT for scratch building, I should not be too harsh. In general, the plans were/are VERY good.
In addition to the ME plans, I acquired the following books for background and to fill in the holes regarding the ship/model/replica.
--Benedict Arnold's Navy by James Nelson. This is an excellent book which goes into the history of events leading up to the battle, the construction of the fleet, the battle and it's aftermath.
--The Gunboat PHILADELPHIA and the Defense of Lake Champlain in 1776 by Philip K. Lundeberg
--The Gondola PHILADELPHIA and the Battle of Lake Champlain by John Bratton. Provides info regarding the making of the replica gunboat. -
- coxswain and Elmer Cornish
2
Gunboat PHILADELPHIA 1776 by Chuck Seiler - Scale 1:48 - from Model Shipways plans
Posted · Edited by Chuck Seiler
Your job, Mr. MacGyver, is to build this with match sticks and chewing gum.
