Chuck Seiler
Posts posted by Chuck Seiler
  1. You don't indicate whether the bulwark will be planked or not.  I would be inclined to NOT use the bulwark provided but instead use 1/16" basswood (using the old bulwarks as templates) then plank over it, inside and out.  This would reinforce the basswood in the same manner as 2 ply lamination as suggested by James.  If the kit does not supply planking material, 1/32" basswood strips (if planking interior and exterior) or 1/16" BW strips will work.  That should be available from hobby shops like Michaels.
    Another alternative is Alaskan Yellow Cedar.  It is soft like basswood but I find it much better as a planking wood.  Hobby Mill EU (Europe) and Modelers Sawmill (US) bother carry AYC.  Both are MSW sponsors.
  2.     I have never used Vallejo.  As mentioned above, I like Windsor and Newton.  It mixes well with water and I can vary the consistency.  Because I paint small areas, I have come to like the "carriage process" outlined by Chuck Passaro in one of his builds.  Winchelsea, I believe.  I am told it is so named because that is how they painted fine carriages in days of old.  The paint is thinned to sightly thicker than water.  The paint is applied and allowed to dry, then buffed between coats. I have found the first 2 coats go on without buffing in between.  At first it is very transparent/translucent, but it gets better.  Six to eight coats.  Its marvelous!!!
        I have been searching for 'the perfect red' for years.  I sometimes will see a great 'barn red' barn while driving.  I will stop and take a pic.  Cadmium Red Deep and Red Ochre (or sometimes a mix of the two) are what I have settled on.
  3. 1 hour ago, hollowneck said:
    I just received a shipment of milled wood from Estonia by regular post (mail).
    You should have gone with Modeller's Sawmill.  I believe the tariff from New Jersey is much lower.  😁  :cheers:
  4. On 3/22/2025 at 5:34 PM, palmerit said:
    'm still a novice. I thought the garboard strake should not make a "smiley face" (curving up) but be flat with the keel. Not true?
    You are correct.  That was a poor representation of what I was trying to get at.  The updated drawing is probably better.  The key is dry fitting a plank or cardboard template so that it snugs into the curve of the stem.  As you say, the upper edge should be straight.  It will be a natural fit.
  5. 2 hours ago, acaron41120 said:
    Still having difficulty in figuring out how to cut the garboard strake curve at the bow.
        I had that problem as well.  I read alot about it and followed many build logs.  The light finally came on when I took what I had learned and started experimenting.  By taking a test plank and sanding the bow end as I go, I test fit the plank.  At one point, the plank fit snug with little or no problem  This was normally right at the curve of the keel up to the stem.  Working it out just from plans never worked.  Test plank or cardboard template in conjunction with the model ended up working for me.
