Everything posted by _SalD_
And interesting thought Elijah but.....I think the spars on this ship will stay right where they are, maybe next time.
- 659 replies
- syren
- model shipways
As always thanks for the kind words Dirk. Thanks for the advise Gary, the darner would definitely had helped, I should have asked sooner. and thanks for all the likes, much appreciated.
- 659 replies
- syren
- model shipways
Finished placing all the fore and main mast yards and moved onto running the lower braces. The instructions call for placing the lower braces in two pieces, one on the inboard side from the cleat to the pseudo sheave in the bulwark and the other on the outboard side from the pseudo sheave to the brace pendant. For my lines I deviated a little from the instructions seeing that I had gone to the trouble in the beginning to install working sheaves in the bulwarks for them. I did however follow Chuck’s advice to install these lines on the inboard side prior to starting the yard rigging. Main and fore brace and sheet lines coiled outboard. Block assembles for the lower course sheets, tacks and clew lines. Main lower course braces and sheets, tacks and clew lines Fore lower course sheets, tacks and clew lines These are the primary tools I used for rigging. The dowel has a sewing needle inserted into it with the eye cut in half. This came in very handy tying off the lines around the cleats and belaying pins. The yards added another whole new dimension to the ship and for me, needing a magnifying visor to see the smaller parts, I found it hard at times to get close enough without banging into them. Need miniature caution tape to hang from the yards. Another part of running the rigging that’s not really described in the instructions but is probably understood by those who have done this before is when you bring the lines down through the lubber holes. You need to pay close attention to how the lines run so they don’t wrap around and pull on the lines that are already there. I needed to rerun some lines three or four times to make them run without interfering with other lines.
- 659 replies
- syren
- model shipways
Thanks Elijah & Thomas. Yes Thomas I think I can see the light at the end of the tunnel, just hope it's not an oncoming train.
- 659 replies
- syren
- model shipways
Cutter Cheerful 1806 by rafine - FINISHED
_SalD_ replied to rafine's topic in - Build logs for subjects built 1801 - 1850
great job Bob looking forward to the next one- 525 replies
- cheerful
- Syren Ship Model Company
Thanks Dirk, Jack and Bob. Dirk it's nice that you take the time to look at my log and I appreciate your comments but I can't imagine you needing any help from me.
- 659 replies
- syren
- model shipways
Thanks Lawrence and Thomas and for all the likes. Well I've been busy, busy busy… Lower, topsail and topgallant yards are all rigged. I find rigging, as I mentioned before, to be a task I enjoy doing so once I start it’s hard to stop. The yards were rigged following Chuck’s directions and so far no problems. Well no real problems just one little glitch happened when I went to rig the starboard side topsail buntline which is supposed to be run through a block hanging from the aft most cross tree. When I went to run it though low and behold there was already a line in there. What had happened was when I rigged the topsail yard jeer which is run through the block below the cross tree right in front of the buntline’s block the holes in the two blocks must have lined up perfectly and I failed to notice that the jeer line went through both blocks. After a few WTF's and some deconstruction everything was put in order. Parrel added to the top sail yards Lower yards rigged and topsail yards added Braces rigged and topgallant yards added. As a side note, the more lines I add I start to understand why lions have a hard time hunting zebras. Looking through all these black and white lines it’s hard to tell which is in front of which.
- 659 replies
- syren
- model shipways
Beautiful work Bob, braces look fine and the anchor is great. Can you make me two?- 525 replies
- cheerful
Winds, good luck with your built ship looks interesting, like the crew too. I'd also love to see a picture of your aquarium.
Very nicely done Bob, your rigging looks great. I like the rope coils too. As for the braces I would do what's going to make you happy (personally I'd go with both fore and aft, but that's just my 2 cent). Or I guess you could install the fore braces see what it looks like and then install the aft ones.- 525 replies
- cheerful
Thanks Dirk, one down, eight to go, and thanks Lawrence and George for the kind words.
- 659 replies
- syren
- model shipways
Just small update. Finished all the yard arms and hopefully attached all the required blocks and pendants. And then.... raised my first yard!! I pinned the yard to the mast as described in the manual but only glued the pin to the mast so the yard is free to move, just not vertically. Tying the truss around the mast was, lets say, an exercise in patience. Should've of done this twenty years ago when the fingers could move a bit more without cramping up. One lesson learned was that I made the sling on the mast a little too long so there's not much of a lanyard between it and the thimble on the yard.
- 659 replies
- syren
- model shipways
US Brig Syren by Gahm - Model Shipways
_SalD_ replied to Gahm's topic in - Kit build logs for subjects built from 1801 - 1850
Great craftsmanship Thomas :im Not Worthy: -
Very clever, I like it.
Hi Jesse, I had thought about doing something similar before I took the easy way out and bought replacement cannonades from Bluejacket. I had thought about dipping the cannons in thinned black paint a number of times to build up their thickness, sort of like dipping candles in wax. I never tried it so I'm not sure if it would work. If you need extra cannonades to experiment on let me know I can send you the ones from the kit I didn't use. Not sure about the sails.
- 1,306 replies
- syren
- model shipways
Thanks Ken & Richard, appreciate the kind words. Richard , I just followed Chuck's directions on make the foot ropes and it worked out rather nicely.
- 659 replies
- syren
- model shipways
Thanks Elijah and you're right about the shine. I plan to paint them with some flat black paint.
- 659 replies
- syren
- model shipways
Started the yard construction and since all the yards basically follow the same 4 step construction procedure I decided to build all eight at the same time. All yards were cut and tapered following the plans using the appropriate size dowel. For the octagon shaped section of the yards I used some dimensional lumber from Midwest Products that I had purchased a while back. Using a caliper I measured the diameter of the lower mast (0.156”) then determined the circumference (3.14 * 0.156”=0.49”) and divided that number by 8 (0.49/8=0.061”) which very closely equaled the width of the Midwest lumber. The ends were rounded and glued in position. These pieces were also very thin so the edges didn’t need to be beveled. The gaps were filled with some Hobbylite filler and then sanded smooth. The topsail and topgallant yards were done the same way but with a different size wood strip. For the cleats I glued two rectangular pieces of 1/16" square wood stock to each yard. After the glue set for a day I sanded the the blocks to the shape shown on the drawings. For the lower notch I used a file that had teeth on its edges only. The yards were then painted. Foot ropes added. The 28 gauge wire was used for the footropes as described. Still need to add them to the topgallant and spritsail yard.
- 659 replies
- syren
- model shipways
Dave, I think we all are our own worst critics at times and I think your right about when build logs stop. It's good you keep moving forward and she's looking fine from what I can see. Nice work.
- 28 replies
- phantom
- model shipways
Thanks again Joe and to you too ole salt.
- 659 replies
- syren
- model shipways
Nils the ship looks awesome. Hope everything turns out okay at the doctors, in the meantime I hope you have a nice Fraulein masseuse
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
