Posts posted by cobra1951
Looks like it will be a nice build
- zoly99sask and mtaylor
2
Great progress, you say you can live with it, personally i would be extremely proud of such a great result
Brian,
One thing about scanners.. they don't do exactly 100%. Some stupidity about counterfeiting money..
So... either buy a small ruler or make a small ruler on some paper and scan it with your plans/patterns. I pull the drawing into CorelDraw and adjust that the ruler is correct size, then print. Or... you just copy/print from the scanner/printer (assuming it's an all in one device) and adjust the size as you print.
Your foredeck came out great in spite of the problems.
This is an excellent idea and i for one will be using it
Hi Bob.
I like the sacks.
Very nice work. Nice details that sets the gundeck for realism.
Keep up the good work.
Regards Antony.
Thanks Antony
The sacks are one of the easier thing to make once you get your head around what the drawings are meant to be depicting
After looking at them for a while i didn't like the knots in the outer sacks so i removed and retied them, they look a lot better now
- Seventynet, WackoWolf, cristikc and 9 others
12
Nice work Bob. nearly there
The rest apart from the bowls ( which are the hardest due to size) is really easy.
I found that gluing the 4 edges of hammocks with PVA glue and then soaking them with a 50-50 pva solution stiffens them up nicely to work with.
The size for the hammocks as specified in the plans are correct in this instance.
Thanks Paul
Not having too much trouble with the tubs and bowls, mainly because i didn't use the Balsa as the main support pillar i changed to a more rigid wood made it a lot easier.
Thanks for the heads up on the hammock sizes. Don't want mine stiff i want them to hang naturally with a slight curve in them. Also i am going to fit them lower than recommended as the recommended place would have the poor sailor trying to sleep with the gun port lid rigging across his chest and a massive block smacking him in the head
And as this kit is only a representation and nowhere near accurate i have also altered the size and placement of the cannon ball racks, this allowed me to center the Bits with the gratings and fit regular sized planks not small filler ones as the instructions say
Better late than never. I just picked up this kit, but it might be a while before I dive in. Lead on Bob.
Hi Mike
Once you start it double check all measurement as the book and the plans give different ones for the same parts, and on some parts no measurements at all, the table and benches for example no measurements at all
Nice planking on the deck and the structures, also love those little doors
Awesomely neat work as usual Antony
- mtaylor, WackoWolf, Seventynet and 1 other
4
Looking at picture 2 from the instructions it is supposed to be slightly higher than center. Also if you check out the frontal view and rear view photo's in the PDF of the finished build you can see there it is slightly above center, but as yours is still in skeletal form it is hard to see how far out if any it is.
Paul and myself found out from our section builds that no matter what the measurements say they are often telling you lies. as you said before you are better going with the precut material sizes where possible
Also it looks like the early stages are also a balancing act as well as a Mensa test
Looking at it again I noticed that when fitting the uprights it gives the distances between them as being measured between the inner parts. But in picture 2 the distances are measured between the outer edges. Check where parts 4a are fitted. If that distance is really 5mm then your materials would be about 1mm thick which they obviously aren't. I think your problem is where they are depicting the measurements differently between the two pics. Check if measuring the hull uprights from the outer edges make it any better
Hope I'm making myself clear
Hi Bryan.
I had similar problems with my sections. Clearly what is depicted in the pics are the main hull side frames and the 5 gun port openings. I would start by checking the size of the supplied gun port lids this should give you an idea of what the actual size of those openings should be. Although I don't know the thickness of the material they might have mistakenly added the extra mm onto the larger measurements. I also notice they give you the measurement of how far back know to place the 4 uprights on the Base but do not give the measurement of how far in the 2 outer uprights fit, if they had there would at least be a better basis to help figure it out.
Sorry I can't be anymore helpful at this stage
Beautiful, and well deserving of pride of place in the center of the room
- Seventynet and Elijah
2
It looks like it will be really nice once built, it is very reasonably priced too considering it's pretty big for a section.
Here's a link to a PDF you can download with a lot more pictures of the completed model might help with the build
just click on the pictures to open them and then click again for bigger views
http://www.afizon.es/es/productos/disarmodel-navio-rayo-20148-detalle?tmpl=component&format=pdf
Glad this has turned up Bryan,
As you say getting half cut laser pieces out is a pain.
Minimal instructions make a mockery out of their advertising that it is done in the English language as matching part numbers doesn't need a language
However it's a nice looking kit and will make a good display piece and is going on top of my list of what to get next
Looks good, i like that last pic very atmospheric almost like being in the real thing
- mort stoll, fifthace and Seventynet
3
Sorry for your loss EJ
- EJ_L, Salty Sea Dog, Elijah and 1 other
4
Barque Stefano by donrobinson - MarisStella - 1:63
in - Kit build logs for subjects built from 1851 - 1900
Posted · Edited by Cobr@
Yes you are correct it is an Austro-Hungarian flag. Some info about the Stefano in the link
http://museum.wa.gov.au/maritime-archaeology-db/wrecks/stefano
Looks great Don. Like you say unusual way with the bulkheads but looks very sturdy![:)](https://modelshipworld.com/uploads/emoticons/default_smile.png)
