mort stoll
Posts posted by mort stoll
Well done sailor. Very, very well done.
Mort
Hi Mark,
I use DAP Weldwood Contact Cement. It's not the same as the cement you would use on plastic models. Fact is I don't what it's used for. It's just contact cement. My mentor used it and whatever he said ALWAYS worked. I have been using it since 1986 with no longevity problems at all.
In fact I just had a new can delivered 2 weeks ago for my Victory. Same brand, it's supposed to be low odor except it takes about an hour to dry. If not I go back to the other contact cement.
Mort
- NewbyMark and chris watton
- 2
Hi Mark,
Meant to add that since there is cement on both the hull and plate there's no issue with the corners. Should a corner rise up I gently press it down.
Hi Mark,
I think I'm in the minority as I use contact cement when I copper a hull. I buy it in 3 ounce bottles, which keeps the fumes down and also apply it with the windows open. The bottle contains a small brush for application. I brush a thin covering onto the hull - a 3x3 or 4X4 area. I then apply it to each copper plate - yes it's time consuming. By then - approximately 15 minutes - the glue on the hull has begun to cure and I then copper the hull.
I like contact cement because I have a few minutes to reposition the plates after I apply them if necessary, as opposed to Ca which instantly dries. If any cement does adhere to a plate I simply and easily peel/rub it off. Finally should it be necessary to slightly adjust or remove a plate after they completely dry I heat the plate with a soldering iron on low heat adjust or replace it.
Any questions, don't hesitate.
Keep up the great work.
Hope this helps,
Mort
Great job. Can't thank you enough for sharing.
mort
very nice. very, very nice. you're doing a wonderful job.
keep up the great work.
mort
perfect. thank you very much my friend.
mort
impressive, very, very impressive.
mort
did you order the eyelets from cmb?
keep up the great work it's very very nice.
mort
well done sailor, very well done.
mort
- RGL, popeye the sailor and Canute
- 3
looks nice really nice. it's a delicate process but it's fine. i painted the preventer stays with elmers school glue - diluted white glue - and used a hair drier to accelerate the drying in order to make sure they stayed straight.
mort
glad to have you back. thanks very much for the reply
mort
very nice .very very nice.
mort
was worth waiting for. she looks great
mort
great job great job. an elegant build
mort
mort
try micro mark. they should have some.
mort
nice, very nice. thanks for sharing
mort
- Old Collingwood and flyer
- 2
looking through the beakhead bulkhead door, one is transported back to the day.......
great shot, great modeling.
mort
welcome home sailor. you were missed. welcome home.
mort
great job. if i didn't know, i would never know. keep up the great work.
mort
- flyer, Martin W and Old Collingwood
- 3
hi mark,
i used adhesive cooper tape my mamoli connie which i completed about 10 years ago and it worked out fine. i first coated a portion of hull with contact cement and after a few minutes applied the tape - which i cut into individual plates before hand - and all was well.
hope this helps,
mort
HMS Snake by Beef Wellington - FINISHED - Caldercraft - Scale 1: 64 - First wooden ship build
I bought 2 boats from CMB and mounted them on the stern quarters. worked out well.
Mort
