Littlebob
Everything posted by Littlebob
  1. Looks like another very nice build, I can see these type of kits doing very well for people who don't like planking, and would like to concentrate on adding more details.
  2. Thanks David, looking to get clean build and along the way I will add a few small upgrades.
  3. Time for an update, the first pic shows the area around the stern post planked as well as the outside of the transom, I also added the wood name plate backing and painted it black to receive the Virginia brass PE letters. The second pic shows the inside of the transom planked and I added a small piece of wood between the deck boards and the transom base (not sure what you call it) I also added the 2 ribs against the transom and I planked the inside of the bulwarks. All comments welcome.
  4. This looks like a good kit, I have their Alfred kit I really like their fittings and instructions. Good luck with your build.
  5. Thanks Geoff, thanks David I will make a few mods, the chain plates are just twisted wire I don't like that and the bow sprit will need some work to.
  6. Thanks Pete for the deck boards I used a very thin piece of steel wire in a pin vice give it a little twist and push at the same time and than I color in the indent with an 8B pencil. Thanks Russ I am surprised the Latina hull came out this good.
  7. Time for another update, I got a decent amount done this time, I installed the stem post, stern post, keel, transom and bulworks. Next I will plank the out side of the transom. All comments wecolme.
  8. Great work Danny on a very sad ship, and a heck of a nice thing to do. Amazing what you can do with so little.
  9. Thanks for the info, I just ordered the cd set, soon with some luck I will be able to start my first scratch build. I will still be checking your build for updates.
  10. Looking good, I was waiting for an update, I may have to get that cd set.
  11. Thanks Russ, there are a few small gaps in the planks but nothing big enough to effect the second layer of planks. Now I have to start trimming the planks for the false keel stem and stern post.
  12. Nice work on your build so far, the Constitution is always a welcome build log to me, great power tools.
  13. Time for another update, in the first 2 pics the first layer of hull planks are 100% installed, in the last pic most of the heavy sanding has been done by the dremel contour sander in the back round, love them power tools. All comments welcome.
  14. That is a nice kit, I to have never seen pre cut planks, it does appear to go together pretty nice.
  15. Time for an update, I am about 75% through the first layer of hull planks, with a little luck I will finish tonight, next filling gaps and lots of sanding. All comments welcome.
