Everything posted by 72Nova
Thank you Jan, your compliment is much appreciated, I'm following your amazing SOS card build as well..stunning. John I really appreciate your gracious compliment, you have quite an array of completed builds, are any of them posted on the site?. Michael thank you for the kudos, that's very thoughtful of you, I do keep an eye out on your builds and see improvements with each one, keep up the good work. Michael D.
- 295 replies
- Sovereign of the Seas
- Airfix
No worries, Marc we all have more important things to do in life. Thanks for the compliment, it's been a while since I had to paint details with crisp lines etc. Michael D.
- 295 replies
- Airfix
Hi Maurice, This build is just fantastic on all levels, I've always admired all your builds and they just get better and better, Cheers🥂 Michael D.
- 648 replies
- Indefatigable
- Vanguard Models
The gun ports I opened up are trimmed out and painted along with the lower hull. once I complete the starboard side and the hull is glued together I'll finish modifying the stern/rudder post, rudder, pintles and gudgeons. Thanks for looking. Michael D.
- 295 replies
- Airfix
Those colors really pop Ian, nicely done. With it sitting on your table saw, it really put's into perspective of big she is, fantastic job👍 Michael D.
- 536 replies
- Quadrireme
- radio
Somewhat of a crowning moment, besides some minimal fine tuning, the gilding on the port side is more or less complete along with making the as cast lanterns look as good as possible, they'll suffice. Michael D.
- 295 replies
- Airfix
I competed the bow decorations, also I removed the existing center carving in the trailboard and replaced it with a grid design based on Payne. I scribed in the scarf joints on the stem/keel as well. Michael D.
- 295 replies
- Airfix
Thank you Ian, yes I'll be adding decorations at the bow also along with the side lantern area and above the gun ports, the only medium I've been using is Sulpey and I find the castings are too proud for these smaller areas so I just freehand them in with paint. Michael D.
- 295 replies
- Airfix
Thank you, Ian, means a lot coming from someone with a decerning eye. Knee deep into gilding the port side hull and adding decorations, I always apply a gold base before applying the leaf as any voids are not seen, honestly the gold leaf paint looks pretty good but doesn't quite have the luster I'm after with the leaf. The desert yellow on the hull is just base for the whitewash I'll be applying. Thanks for looking. Michael D.
- 295 replies
- Airfix
Making a little more progress on the port side hull, finished up the gallery window panes and made new timberheads, these little guys measure less then 2mm, while not 100% uniform they won't be too noticeable once all the rigging is in place, also started painting the bulwarks , I used Tuscan red. Michael D.
- 295 replies
- Airfix
Bill, I used a contour gauge, I think the one I had was 10" so I had to do it in a few sections, first attempt gets you real close then you fine tune the next template to where you want it then transfer to the Styrofoam. I'm not sure how far up from keel but that doesn't really matter, I used 1" foam basically to carry the weight of the model without flexing. I'd get the contour of the hull right at the bottom of lower wale at midships, mine sits up a little high so that would look about right. Hope that helps Bill. Michael D.
- 1,508 replies
- Le Soleil Royal
- Heller
Hey Bill, I too decided to set mine in a waterline after completion, unfortunately all my in-progress pics got lost through Photobucket but I traced the hull profiles in cardboard then transferred to 1" Styrofoam and set into the new base, fairly simple task. A couple of photos (if you don't mind) to show the result, somewhat generic for my only attempt. Michael D.
- 1,508 replies
- Le Soleil Royal
- Heller
I still had quite a bit of work left to do on the hull prior to gluing up so that's been my focus, I'm opening up some of gun ports and thickening the hull in those areas, also finished up putting in the last gunport beneath the gallery. I finished the added decorations, I used artists acrylic and hand painted them in, this left a raised surface to make it easier to gold leaf, I know they are just kind of random in their looks with no rhyme or reason but at this scale I think it looks okay, still need to work the leaf more and some touch up along with installing the window panes. Thank for looking. Michael D.
- 295 replies
- Airfix
I applaud your proficiency on this build, it's barely been a month since you started, just fantastic!! Michael D.
- 158 replies
- San Felipe
- Panart
Yes I did Ian, once muscle memory sets in though, production is much faster😁. Marc at this point I'm inclined to use option A for that reason plus I can make them more uniform as well. Michael D.
- 295 replies
- Airfix
Working on the channels and mocking up the chains, option A on the right is 28g brass wire with an eye formed on one end for the 2mm dead eye and fed thru the hull, option B on left using the same 28g wire with an eye formed on the end but flattened and a returned formed on the other end where a nail will be used to secure it to the hull, this option took considerably more time to fabricate and is more accurate but honestly they both look good at this scale, as with my Vasa build all the channels, chains and dead eyes with the exception of the Mizzen will be made up before hand and put away until after the hull is glued up, there is no Mizzen channel as the dead eyes are attached to the side of the hull. Michael D.
- 295 replies
- Airfix
Thanks Bill, I used a sheet of oak deck veneer from HisModel. This worked out great in forming the curved bulkheads also, thanks for stopping by. Michael D.
- 295 replies
- Airfix
The most striking Cutty Sark model I've seen!👍 Michael D.
- 399 replies
- cutty sark
- revell
It's good to see you're able to find some time to work on your masterpiece Marc. I've never noticed nor read about channels being raked like that, essentially a parallelogram, so I can't help there, it's such a subtle feature though that doesn't smack you in eye as it's only really noticeable from an overhead shot but I do like how you simulated the joints in the channels 👍 Michael D.
- 2,688 replies
- heller
- soleil royal
(and 9 more)
Thank you gentlemen, Marc adding another category does seem like a good idea and from I've seen, there really are a stagering amount of great modelers in each era, so how would one choose? plus the potential risk of over saturation of categories but certainly food for thought. Ian it's a pity I do not remember you from the Victory website days, were building yours around that time frame? Happy Modeling! Michael D
- 295 replies
- Airfix
The detailing of the bulkheads is finally complete, obviously a lot of artistic license used here, but looks like a decent representation, now I can get back to work on the hull prior to glueing it up then finally set the decks in place. Michael D.
- 295 replies
- Airfix
Thank you so much for the kind words, OC they are much appreciated. Michael D.
- 295 replies
- Airfix
Thank you, Frank and Kirill, the decking for the most part is completed along with the poop deck bulkhead.....whew!!!. The final railings and steps will be added at the Qtr and poop decks once the hull and decks are glued in. Yes, the windows at the Qtr deck bulkhead might be a tad too big but overall in the grand scheme of things will not stand out, using the existing upper Qtr deck bulkhead I fashioned it as close to McKay's plans as possible to include 2 cannons and some artistic license. At this scale there are going to be some compromises. I still need to add a bit more decorations to the prior bulkheads or tone down the bling on the poop deck bulkhead, thanks for looking . Michael D.
- 295 replies
- Airfix
Thank you Ian, regarding the ladders, all the reference material I've read does not show them, Payne, Van De Velde, McKay etc, the Culver model along with Wolfgang Rotter and others do show either, but some of those also show what appears to be grating or netting covering the main deck which would render ladders useless in that case, I could be wrong though. Besides some touch up the upper Qtr deck bulkhead railing is completed, this was quite fiddly to say the least and turned out ok. Michael D.
- 295 replies
- Airfix
