Everything posted by hornet
Ulrich, because are only using sandpaper to reduce the diameter of the dowel, you may be able to fix the dowel into a collet after drilling it out and sand it back using your hobby drill clamped in a vice. I am assuming that you have a hobby drill that uses some form of collet.
On a recent build, drilled through the centre of a small diameter dowel using my drill press and then turned the dowel down to the desired diameter using sandpaper on my lathe. I then cut the parrel beads to length and carefully sanded the ends. It was fiddly but worked well. The beads were around 1.5 mm in length but could be made even smaller. See below Alternatively, you can buy beads in a range of sizes and colours from sewing shops. See below.
Steam tool for bending wood model ship planks?
hornet replied to mobile1's topic in Modeling tools and Workshop Equipment
I have been using an Aeropiccola heat/steam bender for over 30 years. Works well for me. See my post about it from another thread below. http://modelshipworld.com/index.php/topic/602-how-long-do-you-soak-the-planks/page-2?hl=%2Bplank+%2Bbender#entry216387 -
I have the Caldercraft Version 'On the Shelf'. I have been through the box. As with all Caldercraft kits fittings and plans are good. Walnut hull planking strips are so so. I anticipate doing quite a bit of scratch work as I have done with the Caldercraft 'Supply' but I'd be happy to recommend it.
I WOULDN'T recommend the Dremel Multivice (pictured below) I purchased one a while ago and am very disappointed in it. Adjustment is sloppy and the jaws are 'wishy washy' Steve
Jaager I have found a supply of old linen and cotton threads is available at antique and collectible stores. Apparently the actual wooden spools are now seen as collector's items. They are never more than a couple of bucks to buy. A few from my collection sure shown below.
Spend the extra and buy a compressor designed for airbrushing. They are small, portable and best of all very, very quiet. If I tried using my regular compressor for airbrushing, the Admiral would probably have me walk the plank. I have a Sparmax (see link) it is a ripper. http://www.air-craft.net/acatalog/Sparmax-TC-610H-Airbrush-Compressor.html
Least enjoyable - Corel Victory. I didn't have the skills to take on this beast at the time. In addition instructions were awful. Took me 20 years off and on to complete. Most enjoyable - current build Caldercraft 'Supply'. I have scratch built almost all of the fittings, learned how to use and airbrush and how to silver solder while working on her.
Proxxon 12v Pen Sander?
hornet replied to Landlocked123's topic in Modeling tools and Workshop Equipment
I have this sander. Yes, you do need to purchase a transformer for it - Proxxon make a couple which are fairly cheap. You can buy a single outlet transformer or one with multiple outlets just in case you invest in other 12 volt tools.. The pen sander comes with a variety of different shaped attachments. Sanding pads fit onto these attachments via an adhesive backing. From my experience, the pads don't last very long but they are inexpensive to replace. I don't use mine a lot, but it is good for getting an even sanding job done on hard to get at spots such as the edges of a deck. It is not a 'must have' but is inexpensive and handy at times. -
Better known for selling Caldercraft kits.
This thread may help. http://modelshipworld.com/index.php/topic/413-chamfer-a-plank/?hl=%2Bchamfer+%2Bplank
Gluing 101
hornet replied to CPT_D's topic in Building, Framing, Planking and plating a ships hull and deck
While coppering the hull of my HM Brig Supply, I came across this handy CA glue applicator from Squadron (just google Squadron glue applicator) The hooked end of the applicator traps a small amount of CA glue which is transferred to the copper plate as soon as the applicator touches it. Very clean and easy - no plates stuck to fingers The applicator is made of stainless steel and was quite inexpensive to buy The hooked end of the applicator holds a small drop of CA glue As I mentioned in a previous post on this thread, I use the concave end of a glass jar as a reservoir for my CA glue. Steve -
I use CA for gluing down copper plates, holding the end of hull planking down until quick dry PVA glue sets, making a pointy end on thread. Other than that I avoid CA glue. The flu like symptoms resulting from inhaling even a small amount of fumes from it is a real issue for me
Because the decks are on three different levels, the thickness of the planks may not be an issue. However, because the hull planks are three times as thick as the deck planks you may find that things like scuppers and ports may not line up properly. In addition, if your decking timber is different from the timber used on the hull - for example hull planking - basswood and decking timber - Ash, then using two different timbers on your deck will give an inconsistent finish. You may also find that your deck planking s a different width to your hull planking. I think your best bet is remove the planking and redo it with the supplied deck planking. In the overall scheme of things it s not a big job to remove and replace with the correct timber.
I have built he Corel version. I would not recommend it as the instructions are woeful. I am currently building the Caldercraft Supply and have the Caldercraft Bounty and Endeavour on the shelf Both instructions and fittings are very good - although I have done a lot of scratch work on the Supply. Timber used for the second layer of planking is of inconsistent quality but there is plenty of it. On the basis of my experience with these kits, if I were to build another Victory, I would seriously consider the Caldercraft version.
Double planking technique
hornet replied to Roubaix's topic in Building, Framing, Planking and plating a ships hull and deck
Hi Shaun. A while ago I posted a method of making planking screws using clothes pegs. They worked well for me. Check out the link to the thread if you are interested. http://modelshipworld.com/index.php/topic/3734-planking-screws-moved-by-moderator/ -
Looking for a Bench Top Drill Press
hornet replied to FlounderFillet5's topic in Modeling tools and Workshop Equipment
I'm with Grant. I too have the Proxxon drill press. Collets take very small diameter drill bits. I have teamed it up with the Proxxon XY table and it works very well.- 31 replies
- Drill Press
- Microlux
The Proxxon KS 230 is a bit more pricey, but still very reasonable. It is much more substantial than this 'toy' and does have safety features.
