Thistle17
Everything posted by Thistle17
  1. As I continue the fairing of the hull I spent some time on the bow on the starbaord side and was pleasantly surprised at how it turned out. Methodology was the key for me and the batten trials has served me well. I did extend my bow filler layout method to the port side in the following manner. Before I permantly glued in the starbaord elements I ensured that the taper on both the exposed and backside profile of the port side matched the starboard elements. I then extended the perpendiculars I had inscribed on the starbaord topside element to bulkhead 'W' on the port side. Then using the ;story pole' shown clamped to the strabaord side I marked the taper that would 'dial me in' on port side and made the tick marks shown. In theory this will give me a near identical bow geometry to plank. To my way of thinking this simple method nudges me away from the 'eye balling' I have done in the past that has not always turned out for me. Joe
  2. Hmmm! I didn't read the monograph thoroughly enough or should i say I did not spend enough time on line where at times more detail can be found. Of course that explains it. Another lesson in more deliberate execution. Not an excuse but at this time I can only spend an hour at best at this and the on again, off again approach does not lend itself to the build. Thank you. Joe
  3. Good advice Glen. I was playing around once again with the transom framing alignment. It is coming along but I came upon something I wonder if people can enlighten me on. I cleaned up the transom fillers and dry fitted and clamped them in place save the outer ones port and starboard. I was a bit surpirsed to find they were a bit too fat. Certainly way to fat to be tweaked. I would say they were 3/32 inch too wide. I laid them on the drawing and found that they are too wide there as well by the same amount. The drawing shows vertical lines on the pieces. Now they could be trim lines. Has anyone had to trim these per the drawing?Have I missed something here? Joe
  4. Back to fairing the hull after my stumbles with the transom frame(s) alignment. I went back to concentrating on the bow bulkheads and fillers. I find this area particularily fussy to work as one is trying to shape the bow mostly through an itterative trial fit process. The battens come in handy for this stage so they must not be neglected in the shaping effort. Observing how the batten lays against the fillers and the first two bulkheads is always a clue to the trueness of shaping. To make things just a bit more complicated the 'W' bulkhead has a mild serpentine curve at its base so that the fillers have to mimic that ever so slightly. To give myself a better chance that all will come out in the end I do not glue the fillers (BF 1 - 3) in as they are so awkward to shape whilst on the model. I start with the bulkhead shaping first ( W and U ). I shape them closely to thier prpoper bevel. In preparation for the next step. I glue fillers, BF 3 & 2 together making sure they align correctly. I then clamp that assembly to the strong back and trace the bottom and rear face of the assembly against the bevel edge of bulkhead 'W". Iteratively I sand via a Dremel with a fine drum sander attached until I get close to the desired surface contours. The process is repeated until I feel I have achieved the desired shaping. I compare my results to some of the helpful photos of Chuck's build as shown in the attachment. In that photo you may notice that I drew in a contour line on the fillers just to get an idea of the shaping trajectory. Ultimately the assembled elements are finished sanded with blocked up linear sanding. This next step is something I learned the hard way in planking Cheerful. On the semi finished starboard filler on the right I drew perpendicular lines as replication markers for its port mate. On the starboard element I drew in a similar contour line as shown on the photo. Using the perpendicular intersects of the starboard side I marked off the port side and drew in the contour shape with a french curve. This produces a very symmetrical bow framing for planking. Now the photo fillers appear a bit wider at the waist area. So as a sanity check I measured Chuck's photo dimensions of the photo filler waist to the distance of bulkhead 'W" from the strong back to its tapered edge and compared it to my contoured filler. I came up with a simple ratio of filler waist width to bulkhead waist width. They turn out to be almost dead on. I am thinking that the appearance difference is the angle and optics of the photo taken. At this point I am second guessing myself and if I am not happy with the results I can always make more fillers and restart the process!!!!!!!!! Joe
  5. Thanks for sticking with me on this. After reviewing your posts on your build and studying the process from #101 on it seems so clear now. No need for an elaborate jig. I am so thankful for your help. Joe
  6. Ron et al I am not at all critical of your works as a matter of fact I marvel at your bringing the "sciences" into the realm of model building. What have we wrought in just the last few years and maybe more importantly where is it all going? And the other sense I gather is that 3D printing may be more complicated than say CNC or laser machining. Your discussions sugest that in these cases the material brought to the machine is lessof an issue in some respects. But in 3D printing the material is somewhat "one with the machine" if you get my drift. Am I wrong? Joe
  7. Thanks scrubbyj427. It seems to be a buzzing in my head that won't go away and after thinking about it that is the direction I am heading in (I think at this point) with a jig I had built some time ago which I will adapt for the solution. I am sure people are asking themselves "why is he making this so complicated". The simple answer is it is in my DNA. I used to build homes while I worked for Habitat for Humanity. It was imparative that the foundation diagonals were never more than 1/4" off square. And then that error was made up by the foundation top plates. I carry that sense of things in my cabinetry and furniture building as well. If not, one was always be making up for it for much of the rest of the build. If my method works I will soon share it. Joe
  8. Frank I am past the child rearing and career pursuit but I still remember those times. Family was always first. I used to steal away after the house was quite at night and try to work on models for a time. It was not the best time for me to do so. The joy in retirement is there is indeed more time but not as much as one would think. Life for us all has changed. All things equal we are more active and involved than our parents. I may get in at most 2 hours a day during the fair months but no more. And given the standards set by the most accomplished modelers of this community I will either halt my work if running aground until I can find a way to resolve an issue. I actually find the problem solving enjoyable. Such as last night I think I came up with a way to solve the transom alignment problem that will work for me. I will experiment with it and post my results. Joe
  9. As so many of you recount, fairing the bulkheads is such a tedious and for me a boring job! To break the monotny I took a stab at the transom. After sanding and trial fitting I was not pleased with the transom frame member alignment and spacing. There are so many ways to get this wrong even with the care and deliberate bulkhead alignment of #28 and #29 that I took. I clamped the transom facade to the frames and was not surprised to find them out of alignment. One way I thought of to aid in truing up the transom uprights is to copy the drawing of the transom on vellum and attach it to a frame (at the proper height and angle) that I can lay up against the transom and work on the alignment of the members i.e. the slots in the bulkheads. I perceive this will be a tricky method. So to those who have gone before me can you offer some idea(s) of how to go about this critical stage? Joe
  10. Roger I built a 45 degree mitre sled for my large shop saw using 2 inch aluminum right angle. Someone smarter than me suggested I check the "trueness" of the right angle. Sure enough I had to have it milled. At the low height of your stock it should not matter I am sure you know. Just a thought. Joe
  11. My model building experience started with an AJ Fisher kit in the 1980's. It was the Bluenose. I bought a number of others, both foreign and domestic pre Syren. They may never be built. Your products have been successful for so many reasons for the "average" model ship builder that they have displaced them. Product design/engineering, material quality, instruction sets and customer support are the bedrock of your enterprise. Add to that the models you build so skillfully are so inspiring! Who else delivers such a complete product? Joe
  12. If I may add my experience to the mix. I am just finishing a restoration of an exquiste scratch model that had ferrous parts/fittings. I estimate the model is somewhere in the 60 to 80 year age. It appears not to have been abused and shoved somewhere that was dirty and humid. Nonetheless the ferrous parts have rusted and as pointed out by others will stain the wood in the area. Another case in point. I restored an old machinist chest sometime back. It had ferrous drawer pulls and corner protectors. All the wood surrounding the ferrous parts had blackened. My advice is do not use ferrous fasteners or material for models! And as mentioned other forms of ferrous metal that do not corrode are just too hard to work with. You may not see the effects of environmental exposure in your time but your future beholders will. Joe
  13. Slow at times wins the race as they say. This build is not a contest save with myself to execute this model with the best ideas of others who have traveled before me. I was looking at sheet 3 of the plans last eve and came up with at least 2 questions at this time. 1. The simulated rabbet stops at bulkhead 21. I was trying to envision how the planking would transition to the stern given the rabbett absence. Can anyone recall how that worked? 2. I observe that the gunports on many of the bulkheads appear to have a piece of material "let" into the face that forms the vertical of a gunport. Is that really the case? I do notice that my model ply is pretty rough on the surface so is that the reason the drawing is so? Joe
  14. The pressure has finally built to the point where I cannot ignore this model any longer. I took it down to start some of the rudimetary work such as fairing the hull. Although I treated the prior work with respect I did have a number of the mid section uprights crack since last year. I have repaired those but i still find those upper elements quite weak and are sure to break during fairing. One advantage of a late start is one gets to see how others have worked through their encounters. I hitch hiked on Stunt Flyer's method albeit with my own rendition shown below. I was careful not to force any of the bulkhead uprights out of their rest position as I expected they would spring back when the 1/16 X 1/8 strapping was removed later on. If needed I added a suitable scrap to keep them in their natural position. The end result is a pretty strudy upper frame area that should take sanding well. The bow and stern areas will have to be dealt with in a similar manner but the scrap build out will be a bit more elaborate.
  15. Dilgence and determination results in a task well done. Just a remarkable beauty Mike! May I ask what are you using to photograph your work? Joe
  16. We cannot account for the lost days and time during the Covid isolation as I am sure you will agree. As far as the PBR is concerned we have been working on her albeit haltingly. Here is a recent photo of the model coming together in April for a dry fit of masts, gun turret, helm (not shown) and rear 50 caliber tripod mount gun. The hull still needs some refining but we are getting close to a full paint job of the basic unit. Lots of fittings and details to add but we are getting there. Joe
  17. I should not be surprised by your response but I am. The demands you place on yourself in model building run deep. It would be a pleasure to meet you were it possible. I say that as I am working on a "restoration" of a model that is extremely well done, yet not of your complexity. The modeler is unknown yet the work deserves my efforts to bring it back to life. Everytime I work on it I can hear myself saying "Who was this person?". Sadly I will never know. It is the same thing I say when I look at a painting masterpiece such as Caravaggio or Vermeer work. I will let you read into that. Joe
  18. You deserve all the continued praise for your work is no surprise. Bitao it did get me thinking about the long term and your legacy. Have you thought about what to do with your works? Where will they go/ certainly to somewhere where they will be cherised. Joe
  19. That was a fine presentation you gave on Power Point presentations. You gave me new tools and access. I did follow up on my version of PP and it is a 2016 version and does not have all the up front conveniences you demonstrated today. I can get at most all via the task bar within PP. Thank you again.
    Joe
    1. robert952
      robert952
      My pleasure.  I am glad you can use the tools and apply what I covered.
      You are quite welcome.  Contact me if you have specific questions or need pointers on some set of tasks.
  20. Prior to MSW few could comprehend the labor, love and progressive record of construction of this heirloom piece. I do hope there are plans to archive this incredible journey for future generations. It just speaks volumes to the work. Joe
  21. Many thanks for all of your suggestions. I will go back at it again with these updates. If you have had success it can't be "black magic" as I was beginning to believe! Joe
  22. It has to be immensely satisfying to be nearing the end of what was in your "mind's eye" come to life. All that thought, experimentation, expert work and results and carrying us along. Just amazing!!!! Joe
  23. Ian there are so many good folk on this forum who are willing to help. Don't be intimidated by their works and abilities. Ask for help and reconsider posting. In one way or another we are mostly students of this subject with few masters. Joe
