davec
Everything posted by davec
  1. Time for a semi-annual update. First post since January other than my pleas not to archive the group build log. Work continues slowly as a bunch of other commitments continue take priority over shop time. I have the inner hull done to the level of the upper deck clamps, and have begun work on the well. Mast step is also done, as well as the limber boards and lower deck beams. I haven’t put any finish on – I used some mineral spirits to clean off the sawdust. I’m continuing to work on the well. I began gluing the sides on right before leaving on vacation, but didn’t take a picture. Dave
  2. I haven't tried finishing planks before attaching for a couple reasons: 1) I worry if the planks are finished, the glue might not grip as well, and I might not get as good a glue joint to the frames 2) a lot of the planks will require soaking and heat to bend them. Not sure what that would do to your finish. I haven't had a problem with wood glues (white or tite-bond) affecting finish as long as I sanded first. Would definitely avoid superglue as it will affect clear finishes (the areas end up whitish). Someone who has tried this might have a different perspective
  3. Roll Models sells the Waldron punch and die set (http://www.rollmodels.net/standard/show_detail.php?hileveldesc=Tools&manufacturer=Waldron). It seems to have better reviews than the micromart one. It is even pricier, but goes well below 1 mm. It does have a plexiglass die, but it looks like it is the punches that wear out, not the die. UMM tools (http://modelshipworld.com/index.php/topic/8448-unique-master-models-tools/?hl=%2Bunique+%2Bmaster) sells some all metal ones (http://umm-usa.com/onlinestore/index.php?cPath=21_145). I haven't used any of them myself. I plan to get a set eventually, but haven't decided between the Waldron and the UMM set.
  4. I finished the treenails on the partially planked side. The other side has all the ceiling planks, so will take longer. I'm hoping to finish the treenails on that side before heading back to work on Monday, when the model will resume its glacial progress. I also milled stock for the mast step and well. I bought a 6' boxwood 2x4 from Gilmer wood 8 years ago, and just cut into the last 2' length.
  5. I've added the lower deck clamps, more of the ceiling planking, and begun treenailing. I put some mineral spirits on to get some sense what they would look like with finish. I'm very impressed with the Jim Byrnes drawplate. I was able to make .018" treenails (just over 3/4" scale) - second smallest hole on the drawplate. Much happier with the effect here than on my prior models. Hope everyone has a great new year. Dave
  6. Greg – thanks! I am using yours as a guide, and will aim for something similar in terms of half fully finished and half frame exposed. It will be a mirror image and include one gun. Druxey – you are as always incredibly kind. I took the picture at an angle that hid the uncorrectable low spots. As they aren’t near the ends or gunport, the planking should effectively hide them. There are also a few frames that are misaligned vertically, also not visible at an angle. I kept knocking them loose when fairing, and after regluing the same frames multiple times, they migrated. Again, mostly on one side, and soon to be hidden forever. I’ve been having a good week off from work. My kids are home, but sleep until late, so I have had workshop time to begin planking. I’m going to work my way up to the lower deck clamps, then stop and treenail. I made 7/8” boxwood treenails. I’m hoping the end grain gives enough contrast that they are visible against the boxwood planks without having the measles effect I have had on prior models. On the Rattlesnake I used cherry, which was too visible, and on Hannah I used boxwood, but was using cheap drill bits that left a burn mark at the edge of the hole, and was using an old drawplate that only got me down to about 1 ¼”. I got a Byrnes drawplate and am able to go smaller, and got better drill bits and lower speed drill, so now get clean holes. It looked OK on the test piece. Best wishes for the new year, Dave
  7. Even though it has been 2 years, 9 months, and 29 days since the last post, work didn’t actually stop. The framing is finished.! One side looks OK to leave uncovered, and the other is begging to be planked (meaning I can’t true some of the frames without either completely disassembling and replacing them, or thinning the others too much). Planking one side was the original plan, and the bad areas will get covered, so this is OK. Few things of note: Future builders should be comfortable that the project is doable even if you only have around 90 minutes per week to work on it. It was a fun project to do a little bit at a time. The time limitations were responsible for the problems on one side. At some point ‘perfect’ became the enemy of ‘good enough’, and I stopped doing redo’s. It was too disheartening to go long periods of time with no apparent progress. I think I have defined some sort of record for how slow progress on a ship model can go without actually stopping. I plan to fit it out, and hope to have more time to work on it over the holidays. David and Greg sent me a copy of their instructions, which are super. The framing was all new to me while most of the rest is similar to things I've done before. Happy holidays! Dave
  8. Brett - both oil and water base work just fine, but look very different. Oil really brings out the color of the wood. The water based doesn't. I use both. I use the water based on holly. The oil based gives it a yello w tinge, while the water base preserves the white. I use the oil based on everything else. Dave
  9. I'm back to rigging my Hannah, and I'm trying to sort out the gammoning, which is different than larger ships. On the Hahn model in the US Navy Museum, the gammoning wraps around the bowsprit and stem (picture at http://www.dlumberyard.com/shipkits.html - it can be seen in the lower right image). There does not appear to be any crossing of wraps as on larger ships, or wrapping of the end of the rope around the gammoning. Marquard's Global Schooner book describes this for ships with small cutwater and has a similar illustration, so it does appear to be accurate, although no specific reference is provided. My question is how are the two ends of the rope fastened? I suppose it could be started by passing through an eye splice, but how is the final end of the line fastened? I'd appreciate any thoughts. thanks! Dave
  10. Hi Len - I've never seen dimensions for serving, but you could probably safely use the dimensions for seizings. I have attached a picture off the web of the constitution that shows both served line, and unserved line with seizings, and the dimensions look the same. You probably want to use something really fine as it may look wrong if oversized. I'm building a schooner in 1/48 scale, and will probably use 4-0 or 6-0 silk. Dave
  11. It does make nice cuts. I've been experimenting trying to adapt the jig that comes with it (which works OK for 1/2" or greater). I'll let you know if I figure out something that works.
  12. I have the grizzly. You are correct to be wary. It has been somewhat disappointing. The main problem is that it is very difficult to align the piece so that you get parallel thin strips of the width you want. There is no way to align the sheet so that cuts are perpendicular, and it is difficult to see the strip to ensure the appropriate width. I haven't figured out a good way to deal with this, so I get a lot of waste. The instructions say that you shouldn't cut strips narrower than for times the thickness, but that hasn't been a problem.. If you have better luck with one of the ones you are looking at please let me know. Dave
  13. I don't think you will be able to find them, unless you find someone willing to part with a used set. Preac tool company made a great thickness sander and small table saw, and previously made the small c-clamps in the picture. Charlie Files who ran Preac passed away last year, and it appears the company has closed. The clamps had not been available for several years even while Preac was still in business. Dave
  14. Jim, Pat and Jay, Thanks for your comments. Hannah was early 1770’s American, so I think it is safe to assume it followed English 19th century practice. I have spent a while researching the rigging, and haven’t come across anything that said practices were different in the colonies. I’m trying to use cotton throughout except for silk for the serving. I used synthetics in the past (particularly morope) and had difficulty having it keep shape for coils. I also want to be able to dye it myself. So far my experiments with 4-0 silk and white dmc cordonet crochet thread have worked out well in terms of coloring – the different diameter crochet threads and the silk all end up the same color with the stain. I got the rope walk so I could get the color, size, and twist all correct. The only rigging that is over 4” circumference is standing rigging – shrouds and stays, so if it would be historically consistent to use left twist on the medium and larger diameter lines, it would make life a lot easier. I suspect the difference in strength that Pat was talking about may relate to the alternating direction of the strands in cable laid vs same direction in hawser laid- the difference is more than just left vs right twist. It would definitely change flexibility. I won’t use cable laid for any running rigging. Dave
  15. Question on cable (left/s twist) vs rope (right/z twist): Much of the larger caliber line, particularly standing rigging, was cable laid. Is this determined by size of the line or its use? As I start to make the line for my 1/48 Hannah, I’m trying to sort out which lines are cable laid and which are rope. Are all lines over a certain diameter/circumference cable laid? This would make sense as cable is made from rope, and it would seem hard to make large diameter line that is right twist (seems like it would need to be left twist, made from smaller right twist ropes). It would also be easier to model. As all my source material is right twist (DMC Cordonett), I can use it off the spool for lines up to about 4” circumference (.025" scale diameter). I have a Byrnes ropewalk, which does a nice job making left twist line from right twist material, and which I could make cable laid line for anything above .025" diameter. It doesn’t do so well making right twist line from right twist thread. It will unwind the strands, then rewind in the opposite direction, but is very finicky and hard to keep even. If I can use left twist for everything above 4” circumference, I am set. Thoughts? Thanks! Dave
  16. I was just reading through the thread, and saw Ian's post a few pages back, where he comments on the Unimat 3 requiring special belts. The belts are just O-rings. I bought a bag of 50 in each of the 3 sizes from Amazon - all the belts together cost about the same as the shipping charge. Dave
  17. I'm not familiar with the Unimat in your link. I have a Unimat, but it is an old one produced by EMCO. I think the one in the Frolich book that Tony mentioned is one of the old EMCO ones as well. The EMCO Unimats are great tools: extremely well built and precise. The one in the link has the same name, but is otherwise completely different. I think a lathe is a great tool, and I used mine a fair amount (gun barrels, ships bell, pedestals, etc). If you are planning on only turning wood, there are probably less expensive alternatives. If you plan to turn brass, you probably want to invest in a better machine. I don't have any experience with the machine you are considering, but would be careful to make sure that any recommendations you follow are based on the same "unimat" machine you are considering. Dave
  18. Hi Meredith - thanks! I found fly tying silk in diameters smaller than 00 - down to 4-0 and 6-0. It comes in white, and looks like about the right size for scale seizing and serving in 1/48 scale. I will order some and give it a try. Any thoughts on dyeing it? I'm trying to decide whether to dye the silk prior to serving, or wait until after. It seems like if I do it after, it would be a lot easier, and if it works, might help keep the serving in place. Dave
  19. Thanks to everyone for their responses. I made my pilgrimage to Woodcraft over the weekend. Usually this is a risky proposition, but I only bought the two cans of stain. I’m at work, so can’t post pictures. I got the General Finishes stain. The expresso color works great for the standing rigging. Not black, but a very deep brown. It also covers really well. I’ve been using both ecru and white cotton, and both end up the same color after staining. I also tried the Golden Oak. Chuck – what color stain or dye did you use on your line? I really want the same effect. The Golden Oak has a significant orange tinge to it. I originally thought I might have gotten a bad can until I realized it is the same color as oak flooring. I’d like something with more yellow in it. Any suggestions for other colors? Also, the water based dye is very thick. It does seem to penetrate OK, but it seems like there is a lot of stain getting into the line, and it is a little stiffer when it dries. Have people been using it straight from the can, or have they been thinning it? Dave
  20. Meredith – I need something pretty fine. When I looked at the line used for seizing on the Constitution, it looked like heavy twine between 1/8” and ¼” in diameter. .005” is around ¼” in 1/48 scale, and should look OK. Mark – I made some RH rope with right hand twist DMC Cordonett. I was only using one strand on each spindle. It came out OK. The individual lines unwind, then rewind left hand as the rope is being made. I haven’t tried it with multiple strands on each spindle, and suspect that wouldn’t come out right. Dave
  21. I have started a spreadsheet. I've been using DMC Cordonnet crochet thread. I've just started getting results that are OK, and made my first attempt at staining the line. Mm Inch How made .31 .012 #80 plain .44 .017 #20 plain .61 .024 #60 1 strand per wheel .78 .031 #20 1 strand per wheel 1.2 .046 #60 3 strands per wheel Any thoughts on smaller diameter line for seizings and serving? I need something natural fiber that will take a stain so it matches the larger lines. Most of the small diameter stuff is synthetic. I saw some very thin silk that is used for beading and comes in .005" and .008" diameter in white. Has anyone used this before? thanks! Dave
  22. Ryland - Your AVS looks great. I love the pictures and am impressed every time you bring the model to the club meetings, and am really looking forward to seeing progress. I like Tim's idea - workshop before computer! Best, Dave
  23. Best of luck with your build. I did a kitbashed version of this for my last model. The cannons that came with yours look a lot different than the ones that came with my kit 6 or 7 years ago. They seem to be using some sort of casting now that looks a lot lower quality. You should definitely get in touch with Model Expo - they have a really good reputation for replacing inadequate parts. I'm looking forward to seeing your progress. In terms of depth of the rabbet, you probably want to be consistent along the length. It doesn't have to be exactly 1/16, but don't go so shallow or deep that you can't make up the difference when you sand. You should be able to get it pretty close. having it the same depth on both sides will help you keep it symmetric. Dave
  24. I like milling my own wood, but I'm not up to harvesting it myself. I understand that for some of the woods there are some special issues. For instance if holly isn't harvested in the right season, and I think kiln dried, it ends up with grey spots. I value my hands enough that I'm not going to use a chain saw, and haven't split logs since boy scout camp a LONG time ago. It is a cool thing to do, and I wish you the best of luck. Dave
