russ
Everything posted by russ
  1. Sam: In a 1928 article by a correspondent from out of town, he got to sail aboard a schooner in the regatta. He wrote that whenever he tried to raise up from his prone position on the deck to take a photograph, the rest of the crew told him to lay down because he was slowing them down. That is how seriously they took their races. Russ
  2. Good looking cannon and tackle. The blocks and hooks look very good and well scaled for the cannon. Russ
  3. Popeye, thanks for the kind words. Sam, the captain would kneel for a couple of reasons. In any event, the wheel is set very low and it would be uncomfortable and perhaps impossible to stand and steer. In many cases, the wheel box is set forward of the rail so there might not be a place to sit either. In races, everyone stayed low. No unnecessary wind resistance. Russ
  4. The hull is shaping up very nicely so far. Good work on the bulwark framing. Russ
  5. Bob: Here is a photo of the bolt rope detail from a Biloxi schooner in the 1920s. Note the relative sizes involved. That mast is probably 9-10 inches in diameter and the sail hoops are probably about 1 1/2 inches thick or thereabouts. The halyards there are probably not more than 1/2" diameter. I would say the bolt rope is fairly large and prominent. Russ
  6. That looks pretty good. I would suggest leaving it for a day or so and then come back and look at it with fresh eyes and see what you think. If you like it then, all well and fine. If not, well it is your call. You are the one who must be pleased with it. Russ
  7. I agree that the outer windows need to come down or the inner windows need to come up. Russ
  8. Thanks. The windlass needs a few more details, but it will get there eventually. The windlasses normally seen on local schooners are generally much simpler affairs than those found on schooners up in the Eastern seaboard for instance. However, I seen several different types used down here, so it really pays to research old photos to see about what was used in any given instance. Russ
  9. Sam: Thanks for the kind words. Also, thanks to everyone for the likes. Yes, the captain would steer from the side. In many cases, we see photos with the captain kneeling next to the box to steer. Russ
  10. Bob and Frank: Thanks for those kind words. Frank, there are many things about this model I like, but I can also see all the problems. Granted, most people will never see them, but it will always bug me. However, it is all a learning process and hopefully, some of things wrong with this model will help me make the next one better. Russ
  11. John, Joe, and Elia: Thanks for the kind words. It is much appreciated. Thanks to those who clicked the like button as well. Russ
  12. Brian: The damage to the subdeck is really not that big a deal. It just needs a patch and it will not matter how it looks so long as the deck planking lays flat. On the stern frames, do the laser cut windows have an angle to them that they will fit between the angled stern frames as shown in the plans? If they do not, then you would not be able to fit them in between the frames if you installed them on an angle. If you are going to install the stern frames on an angle, then it is a simple matter of properly beveling the upper and lower ends of each frame. As for the two that are next to the false keel, there is little to be done there. It would be difficult at best to try and bevel their outboard faces to get kind of angle you want. I would let the laser cut window frames guide you on this issue. If they are not angled, then install the stern frames perpendicular and build the stern up accordingly. Russ
  13. Here is another update. Some progress has been made on the deck fixtures and fittings. Here is a look at the wheel box which still needs some sanding and another coat of paint along with a peek at the wheel. The mainmast collar and the aft hatch is also nearing completion. The windlass is getting there, but still needs a few fittings added and the axel trimmed. The bitts will be painted after the windlass has been fitted but not attached. Questions and comments welcomed. Russ
  14. Larry: The deck looks good. I generally do not put any finish on the deck before I get all the deck fixtures in place. I like to use hidden dowels in the bottoms of deck fixtures so that they will be fixed in place on the deck. I can remove a hatch coaming and know that when it goes back it is in the same place every time. Russ
  15. Congratulations on a great build. She looks beautiful. Well done. Russ
  16. John: It looks great. It is really good that you did not need any bilge stringers to stiffen the hull. Looking forward to the hull planking. Russ
  17. Larry: The deck looks good. No deck was ever perfect. Just get it as even as you can and I am sure it will be fine. Russ
  18. The metal work looks very good. There is a lot of it on small workboats like this and you are doing very well with it. Good work. Russ
  19. So far, the fairing looks like it is coming along well. Keep at it. In my experience, just when you are sure you have it faired, go back and check again. The moment you are sure about it is when the rug is likely to get pulled out from under you. Russ
  20. Good work so far. Is the bottom of the hull supposed to have any fore and aft curve in it? I think it should, but it is something to look at before you get too far. Russ
  21. Nice work on the halyards. Good solution. Russ
  22. Frank: The planking job looks pretty good. I have also had one those repair jobs and it is always good to get it done. Nice work. Russ
