KeithAug
Everything posted by KeithAug
  1. Julie / Mark Thank you for your kind comments.
  2. Scuppers--------- The penetrations through the bulwalk have covers on Altair. I thought the covers would look bad if they weren't identical so I decided to cut them from brass channel. The correct angles were formed using a combination of the disc sander and mill - with the settings being maintained through the use of simple jigs. The uniformity was good and the test mounting looked fine. I also got round to putting the 1st coat of poly on inner surface of the bulwarks and capping rail.
  3. Hello David, I made the prop some time ago. You can find the details on page 5. Thank you Bob for you comments - and also thanks all of you who hit the "like" button.
  4. Progress is very slow. Much time away from home visiting family and holidays. At least the dog is getting a lot of walks and looking fit. I did get an hour or two to make the prop shaft rear bearing and hull outing plates, The test assembly looks ok but I'll postpone final installation until later in the build.
  5. Hi Nils. She is coming along very well. Loved the sanding drum, drill bit etc up-stands on the aft deckhouse. The vents are excellent.
  6. I came across the attached product for the first time earlier today. I can think of a number of uses that I could have put it to on previous builds. Its worth watching the video. http://www.albionhobbies.com/connecto/ I wondered how many other products are out there that a lot of us are unfamiliar with????? Another useful link. http://www.chronos.ltd.uk/acatalog/Abion-Alloys---Precision-Metals.html
  7. Hi Kees A good clear out and tidy up always makes me feel better - almost like a new begining. I hope it makes you feel the same. I hope you start feeling much better soon - your skills are missed.
  8. Hi Guys You might want to look here also http://modelshipworld.com/index.php/topic/10830-how-would-you-improve-your-byrnes-tools/?p=327942
  9. Thanks Bob, I'm pleased you found it and hope you enjoy.
  10. Altair has 7 portholes just above the waterline, 3 port and four starboard. I had a play with 2 designs. In option 1 the window is glued into a recess cut in the front of the porthole. The porthole is cut from solid brass rod of .325 inch diameter. The window is cut from stiff clear plastic using a standard paper hole punch. Option 1 has the advantage that the resulting porthole seems less "heavy" at the rim. The disadvantage is that its hard to disguise the glue and any unevenness in cutting the edge of the window (made from plastic) is also apparent. The result can look a little messy. In option 2 the window is inserted into the rear of the porthole and held in place by a tube which is also pressed in from the rear. The advantage is no glue and no rough edges - but at the expense of a heavier rim. I made both types before choosing option 2 (on the left in the picture below). For me the neatness outweighed the heaviness. The components below are pre-assembly. The tube was pressed in and then sawn off. The portholes took about 10 minutes each to make - but as the picture shows they need a little cleaning up. I'm off on my travels now so no more progress for a while.
  11. Hi Nils Re vents for post WW1 liners. I have seen then made using a shaped plug which is pressed into a circular die. The vents are usually made from copper with many annealing steps to avoid work hardening and splitting. The tubes are than soldered on and the hole is cut from the inside of the tube. I am planning to have a go at this method later on in my current build....... just for the experience!
  12. Julie / Tom Thank you for your feedback. I feel I should be getting on quicker but unfortunately other time commitments seem to be getting in the way.
  13. I had a go at the hawsepipe today. The complication is the plate as it exits the hull which is oval in form. This could have been tricky and I wanted it to be neat. The solution in the end proved to be simple and quick to make. I started with a length of .200 inch diameter brass rod. I drilled out the rod on the lathe to the diameter of the hawsepipe. I then measured the angle the hawsepipe made with the hull at its exit point and set up the bar at this angle in the mill. I then lopped off the end using a slitting saw. The next operation was to solder the hawsepipe into the brass rod while still set up in the milling vice. I then indexed the slitting saw down and repeated the cut. With a bit of buffing the job was done.
  14. I though I'd better finish and mount the rudder. I needed to drill the holes to take the rudder pivot - a more complicated job than might be expected as I will explain. I started by marking the position of the hole at the back of the keel. I used tape to mark out the angle and get the right distance from the hull (.200 inch). I carefully drilled an undersized hole by hand, stopping frequently to check the drilling angles (alignment along the axis of the hull as well as parallel to the back of the keel) I then started to widen out the hole with some miniature square section broaches - a birthday present from the wife. Finally finishing to size with a round needle file. A bit complicated but the result was a hole that was exactly right in both size and alignment. Drilling the top pivot hole was done through the lower hole. The drill bit was much too short for this but I stuck the drill bit in a tube to give it the required length. The pivot was cut from brass tube and the rudder mounted as a test fit - it worked fine. I then did a bit of brass bashing to create the rudder strengthening strips - they are about 1 inch x 1/8 inch - fastened in place by 4 rivets.
  15. Exceptional work Toly. I am very impressed.
  16. Hi Julie I had a go at steaming and bending the .010 inch mahogany planks. It sort of worked but I don't think I'd use this method. I think David B's post is the way to go.
  17. Hi Julie. I agree it is a dinghy / tender and not a lifeboat. I have scrapped more than a few attempts in the past, learning what works is part of the fun. How thin did you make the planks. I was cutting some mahogany planks recently and mistakenly made a plank .010 inch thick. It behaved more like paper than wood. I'm away at the moment but I'll have a go at bending it when I get home and let you know the result.
  18. Julie Most of the rudders on sailing ships were built solid from very heavy timbers - and even then they failed. Cutty Sark is a good example:- Cutty Sark lost her rudder in heavy seas in the Indian Ocean when racing Thermopylae with a cargo of China tea. The accident meant Thermopylae beat her back to London by 7 days. Endeavour being of metal construction probably did have a fabricated rudder.
  19. Julie - you might want to see the rest before stealing anything! So here is how it developed. I started to sand the rudder down to its final form but part way through the process I started to feel the larger pieces of mahogany were looking a bit monolithic and hence out of scale. I did like the pin stripes and I think I will bank this for a future date. So decided to use what I had as the core of the rudder and clad it as I had done with Endeavour. I started by laying two strips either side of the leading edge. I seemed to have created some sort of bug!!!!!!! I then laid more strips across the rudder, parallel to the waterline. Another weird creature was born!!!!!!! 27 pieces per side = 54. Plus the 17 core parts = 71 parts in total. After a lot of sanding.......... The next step is to make and attach the 2 strengthening plates - one either side of the rudder and then buff the rudder with fine sandpaper before painting with poly.
  20. The rudder............ Sometimes I have to question my sanity. I managed to make the rudder (excluding the strengthening plates) from 71 separate pieces. Excessive by any stretch of the imagination! This did include a bit of experimentation but that only added a few bits to the total. I started with a card template made to the profile on the plans.This was positioned on the hull and adjusted to fit. I also made a template of the rear of the keel (immediately in front of the rudder) so that I could get the varying thicknesses correct. My starting point was to find a brass tube from which to make the pivot. Around the tube I constructed a beam which would ultimately form the front edge of the rudder - thus far 5 parts. I attached the template to the beam and shaped it to the profile of the keel. It always looks better to me to have the grain on the rudder running in the same direction as the hull planks. Also I like including a bit of detail (interest) into the rudder. I thought I'd have a go at some pin stripes. I started to question my approach at this point - thus far 17 parts. More to follow.....
  21. Alex - a really fascinating build that I have been following silently for a while. I look forward to future posts. In terms of tubing this link may be of interest...... http://www.cornwallmodelboats.co.uk/acatalog/Assorted_Selections.html I'm not sure they ship to your part of the world but they do seem to send to most countries. Their assorted metal tubes come in handy for making a lot of fittings.
