KeithAug
Everything posted by KeithAug
  1. Michael. In these woke days I'm not sure that I should worry about buying a slinky leather skirt - beautiful travellers. Druxey, Eberhard, Hakan. I have asked my wife to go through her gloves draw but failing that I will try paint.
  2. Thank you Druxey, Keith and Mark. I don't think my wife would wear it which is the most telling test. Michael - thank you. I don't really have photos that show that detail but there are a couple of fuzzy shadows that suggest the inside of there saddle has some form of covering so I guess that will be leather. I may try lining the face but it will depend finding something suitable to do it with - perhaps a visit to my wife's glove draw?
  3. Phil - Thanks - I had thought that I might take Dremel brushes and soak the subs in CA glue to see if this would reduce bristle loss. Toni - thanks - if the above doesn't work I will give them a try.
  4. I finished off the other ends of the gaffs before moving on to the saddles. I started the saddle with a strip of 1/2" wide x .040" thick brass. This was milled along its length to a depth of .020" I marked out the ovals for the saddle on a piece of card and then attached it to the brass strip with double sided tape. I then cut out the ovals with a jewellers saw before finishing with a file. I then annealed the brass and bent the ovals around scrap lengths of steel bar of the same diameter as the masts. I then made the attachment brackets for the gaff out of strips of .020" brass. These were bent to the correct radius with the ends turned out to form the hinge brackets. The piece of aluminium is a spacer to get the brackets correctly positioned. The brackets were then soft soldered to the saddle. The stirrup for the gaff lift was then made. A piece of 3/32" tube was part turned to mark the cutting locations. Holes were then drilled and a piece of shaped .040" wire was bent, inserted and soldered. Finally the small bridging piece was soldered to form the eye. The tube was then cut away. The saddles were then mounted on the gaffs.
  5. Druxey, Gary, Bill and Jon, Thank you all for your kind comments. It seems amazing that I started this build 3 years ago - how time flies. My hope is that some time this year I will get started on another build. As I get older I find myself rejecting long duration projects!
  6. Mark -, preferably steel or brass - for removing excess solder.
  7. Great project. I must have seen her while visiting the museum, but don’t recollect. I look forward to seeing her develop.
  8. So now we know, it was you who was responsible for initiating Chinese world manufacturing dominance.
  9. The internet is festooned with small wire brushes for Dremel type drills. My experience is that most of them are rubbish. They either disintegrate or wrap themselves into a tight ball. Can anyone recommend a source of high quality small rotary wire brushes? By small I mean up to 1" diameter.
  10. Jon - In Scotland the wind always dies about 5 miles before the anchorage which inevitably means that the hook only goes down as dusk descends. Just as the last rays of sunlight fade the wind starts blowing at about 25 knots directly into the mouth of anchorage. My sailing pal says it is due to diaurnal variation but I just think winds are perverse. Jon - That's not too bad. I find it much worse when i leave the model all ship shape and then turn up the next morning to discover all the failures.
  11. Brett - alternatively look up Gerald A Wingrove - he has written an number of books and you can find some of his work on MSW. Sadly Gerald is no longer with us. RIP.
  12. Brett - this would be a good start:- https://www.amazon.co.uk/Model-Building-Brass-Ken-Foran/dp/0764354949
  13. Arrrrgh! You have all shattered my dreams. I thought Valeriy had discovered some way of only making the solder go where he wanted it to go. I am a broken man!
  14. The crew are obviously a bit pedantic about sanitary cleanliness. Don't you think that a bit of realism in the pan might add to the overall effect?🙂 Perhaps the door should be slightly ajar, with a glimpse of the seated occupant smoking his corn cob pipe.😀 You can see that I am very taken with your Bogs. Your work is beautifully neat as always.
  15. Jon - I always struggle with making the sails look full. In the end I convince myself that its the end of a perfect day, the wind has failed and the crew have decided to partake in a round of gin and tonics before taking the sales down. This makes the set of the sails perfect.
  16. Valeriy - your soldering is always very neat. You must tell me how you keep it so clean.
  17. I moved on to gaffs. They were again made from mahogany dowel turned to the correct maximum diameter (the taper being left for later). The gaffs have features which in the majority lie on 0, 120 and 240 degree radial orientations. To make rotational location easy I drilled 3 location holes on a extension to the finished boom and then used these holes for location. I needed to cut 2 x .040" wide slots along the lengths of the gaff ad i did this on the table saw using a simple jig. A square cut out was made in a piece of scrap wood equal to the diameter of the gaff. A hole was drilled for a locating dowel. The gaff was mounted and the slot was cut with the saw fence bearing on the jig. With the slots cut the ends were milled to take the gaff saddle brackets. The .040" slots are for the wear strips - made form .040" brass wire. The wear strips are not continuous so I inserted thin strips of mahogany (cut to the correct length) to segment the slots. With this done I then sanded the tapers on both ends of the gaffs (the slots were deep enough not to be removed by the tapering). The brass wire wear strips were glued in with CA. The second gaff was made in the same way. Straps for locating the gaff hoist lines are positioned at the 120 and 240 degree rotational positions. The straps were cut from brass sheet and when drilled were inserted on pins so that the end radii could be filed in one operation. The gaffs were drilled to take the pins for the straps and the straps were mounted. The straps for the saddle were cut and shaped to fit the previously machined slots. The hoop and the end boss was also turned and milled. The straps were blended to the shape of the boom using a file and then the hoops were fitted.
  18. Hakan - Have you got a jewellers saw? Ideal for jobs of that sort and relatively cheap. If you get one invest in decent blades. The ones that come with the saws are usually poor.
  19. Whatever happened to those beautifully elegant cargo vessels, alas their modern replacements have all the elegance of a floating brick. At least modellers can record their passing.
