![](https://modelshipworld.com/uploads/set_resources_21/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
IgorSky
Posts posted by IgorSky
Just now, cog said:
That's a nice way to make the railing, very well done
Many thanks, Carl!
It was very laborious work, but it seems that these efforts were worth it.- cog, mtaylor and Tigersteve
3
Hello to all!
For almost a month I did not post updates, though, the work was quietly conducted. Now I will make up for lost time
So, the next stage of the construction was the making the railings. I have, if possible, delayed this stage, because I prefer to install them whenever possible, so as not to interfere with the work.
Racks of railings I cut from medical needles. In the gunwale I drilled holes for them. I screwed a very thin wire rings with legs to paste them into the upper ends of the posts and then stretch the railings through the rings.
- JesseLee, cog, Tigersteve and 2 others
5
- mtaylor, Tigersteve, cog and 2 others
5
- Landlubber Mike, JesseLee, mtaylor and 1 other
4
Hi, Daniel!
I hope that you will cope with this problem!Good luck!
Igor. -
Hi Nils!
Excellent work! My congratulations to you!It seems to me, always a little sad when such a great work is completed...
- mtaylor, Omega1234, Mirabell61 and 1 other
4
Hi Nenad!
I think you made great boats! Congrats!- NenadM, mtaylor, CaptainSteve and 2 others
5
- hexnut, Landlubber Mike, cog and 4 others
7
Many thanks, Carl, Jan, Jesse and all who is likes this project!
On 13.07.2017 at 0:59 AM, cog said:You can't mean that, Igor. It can't be true, you must be having a giant match stick and blow up fingers ... 2.5mm
Do you really want to make double and tripple blocks at the planned smaller size ...?
Yes, Carl, I try to do this.
On 13.07.2017 at 9:18 AM, amateur said:Looking impressive!
how did you make the puley?
jan
Jan, I made this pulley from a brass tube with a help of a minidrile and the file.
18 hours ago, JesseLee said:You must have incredible close up vision. That would strain my eyes to death!
Jesse
Oh, Jesse, I use glasses and sometimes "magic glasses"
Many thanks, Jan and Carl, for your support!
As I think, there are several mistakes. Firstly, the position of the attachment point of the gafel to the mast is too highly. And the distance between mast yoke and mast cap too small. This does not possible to make the correct rigging of this node. Please, look at the attached photo:
15 minutes ago, cog said:
Igor,
Usually we see our errors (to) late. Fortunately you know how to correct them!
I like your blocks. So easy to handle
Hi Carl!
Many thanks for you feedback!
Unfortunately, this time I can not fix this error... For this, it would have required to make again the mast and main sail. I started doing this model at a time when I did not have enough information about many of the details of this boat. Later my friends from England sent me some photos, but, unfortunately, it was already a bit late
As it turned out, these blocks are quite easy to make. Now I need to figure out how to make a few double blocks. -
- JesseLee, cog, Mirabell61 and 5 others
8
- JesseLee, Tigersteve, cog and 2 others
5
Many thanks, Patrick and Nils!
- mtaylor, Omega1234 and Tigersteve
3
Jolie Brise by IgorSky - FINISHED - Scale 1/240 - BOTTLE - Pilot cutter
Then I cut out of from the tea bag a grid for the bowsprit and fixed it in place (without final fixation for now)
