![](https://modelshipworld.com/uploads/set_resources_21/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
IgorSky
Posts posted by IgorSky
- mtaylor, kees de mol, hexnut and 5 others
8
As you remember, I set on the deck several lifting eyes for fixing the rigging. Lifting eyes have a hole diameter of 0.2-0.3 mm. Since I'm going to put the mast in the bottle separatly from the hull, it will be quite a difficult task to stretch the thread through the lifting eyes. So I decided to insert the temporary loops from threads into them.
- John Allen, mtaylor, hexnut and 5 others
8
Thank you, Bob and Lawrence!
Yes, it was fun to try to make these chessboards. I used two different techniques to do this.
Now I need to try to make sets of chess pieces.
Best Regards!
Igor.- mtaylor, captainbob, Omega1234 and 1 other
4
- tadheus, kees de mol, Omega1234 and 8 others
11
Hey Igor
At last! I've been waiting patiently and now, with these updates, I'm not disappointed!
Definitely your best model yet. I'm really loving all the fine details that you're adding.
Beautiful stuff!
Cheers
Patrick
Hi, Patrick!
I am glad to hear you again!
Many thanks!
I would say that this model is a good school for me. I was able to check out a lot of my ideas, technical solutions and technologies. Of course, I could not avoid some mistakes, but I hope that the experience of this project will allow me to avoid them in the future.
So, we go ahead
I then installed the davits complete with the lifeboats and began compiling the assembly diagrams and marking of the ends of the rigging
- Mirabell61, Tadeusz43, cog and 8 others
11
And, finally, I was able to proceed with the final assembly at the stand.
Assembling was carried out in the same order in which it will be made later in the bottle.
At this stage I revealed some mistakes that are likely to affect the assembly in the bottle, but ... something to alter it's too late
Although, of course, I will try to fix some of them. For example, I'm going again attach ladder to the bridge and I will to lift up the lifeboats.
So, first I installed the rear mast, the engine room and the bridge.
Very nice work, Igor. Since I started working with PE at 1/350 I now know what you are going through with for example the railing. You are even having more chance to damage items on your build as mine is at a far larger scale. Well done my friend!!
Hi, Carl!
Many thanks!
The handrails in front part of the hull were broken off several times in the process of the work, because I glued them too early
- captainbob, canoe21, mtaylor and 2 others
5
- captainbob, canoe21, cog and 2 others
5
LENA by IgorSky - FINISHED - scale 1/290 - BOTTLE - steam schooner
Now I was able to start assembling the model in a bottle. First, I installed and glued the engine room.
