rafine
Gone, but not forgotten
Posts posted by rafine
  1. Work on the planking continues. I've now added the second layer of the wales and painted them black, and done the first two strakes of the lower planking, including the drop plank. Those lower strakes were given a rough sanding.  If I had it to do again, I would probably not add the second wale layer until after doing the lower planking, since the the paint got pretty nicked up and will require extensive touch up later.
    In any event, I will now move on to the remainder of the first belt of lower planking.
    Bob
  2. Back from another summer trip and eager to to get back to Cheerful.
    I chose to deviate from the sequence that Chuck and the other Cheerful builders have followed at this point. Rather than doing the wales and the lower planking, I decided to treenail the upper planking. My reasoning was simple -- I hate to do all of the treenailing at once, and this allowed me to break it up. The treenailing was done by the drill and fill method, but I chose to use a more visible filler, rather than the subtle ( and likely more accurate) route taken by Chuck. I must admit that I simply like the look of the more visible treenails better. After completing the treenails, I applied a coat of Wipe-on Poly as a sealer.
    Now I will move on to the wales and lower planking.
    Bob
  3. Summer is vacation time (although my family always asks what retired people take a vacation from  :P). As a result of the travel, progress slows considerably.
    I do have some new work to report. I've done the planking of the counter and the transom. The first step was to trim down the outer stern frames. I did this with a #15 Exacto saw blade initially, and then sanding sticks. The planking of both areas went relatively quickly and easily, with some shaping and bending of the planks.
    Next will be the fashion pieces and painting the counter.
    Bob
