Posts posted by G.L.
3.8
Determining the shape of the knee is a little more difficult as for the apron because the knee is round. I take for the upper shape the lower profile of the apron and for the after shape the profile of the first station. I use the sand disk to give the knee shape mostly at random between the two profiles.
- aviaamator, mtaylor, tarbrush and 2 others
5
- mtaylor, Captain Poison and DORIS
3
- Captain Poison, mtaylor and tarbrush
3
- aviaamator, DORIS, mtbediz and 4 others
7
- aviaamator, Captain Poison and mtbediz
3
3.2
I made the keel, the stem and the stern simultaneously but I will deal with one after the other in this report for clearness' sake.
The keel is made in two parts with a keyed hook scarf in the middle. I saw the scarf with the fretsaw. The scarf is keyed with two wedges. The two parts of the keel are glued together. Once dry, I saw the wedges along the keel and sand them.
- aviaamator, mtaylor, KORTES and 4 others
7
Part 3: Making keel and stems
3.1
Time to get to work now. The wood that I use is provided by my garden. Many years ago I planted a cherry tree in the garden, when the tree started to bear fruit, it were plums instead of cherries. Two years ago I made finally the decision and removed the tree and replaced it by a real cherry tree. The wood is dry now and ready to be sawn and planed into planks.
Remark afterwards: After completing stems, keel and frames I made some samples of the finishing color for the planking an discovered that the plum wood did not give a finishing result that I liked. Therefore for the planking of the hull I changed to oak, the wood which was in reality used to build the Flemish shrimpers.
The stringers are 2.5 mm thick, so I plane two planks to that thickness (2 because there have to be made 2 stringers in mirror image). I set my table saw for a thickness of ±1.2 mm and saw the grooves for the steps. Some time ago I made a simple table saw sled on which I glued a piece of millimeter paper, that makes it easy to saw the groves exactly parallel and with the correct intervals.
Patrick,
Looks great!
If I was You I would also treenail below the waterline, just for completeness. Looks me a nice job for a Sunday afternoon in a comfortable and heated hobby room like yours with some good music at the background.
G.L.
- mtaylor, John Allen and Baker
3
- mtbediz, tarbrush and Mirabell61
3
- tarbrush, Captain Poison and mtbediz
3
3
Oostends schipje by G.L. - scale 1:20 - Ostend shrimper - first POF - Edition 2
The last thing to do is gluing the whole assembly together and fixing the deadwood with the keel and the apron with the stem with treenails.
