Posts posted by Morgan
Last time I was at the BL I was trying to review Thomas Atkinsons journal, the Master of the Victory at Trafalgar, the answer was ‘no way’.
Fast forward a few months The National Archives copy (there are several original copies of each of the main ships logs) was in conservation, but they would have been happy for me to return and see it, going out of their way to ask Conservation to do a special viewing in their offices. Unfortunately I didn’t have time, but now I do and I’ve got it booked for next Thursday.
I’m trying the BL again on the way to Kew next week to see some of the Nelson papers, fingers crossed 🤞, no rejection to my request so far, but I’m not holding my breath.
The Library at the NMRN are also very helpful, always got time to assist and dig out other documents if they are not busy.
Gary
Hi Steve,
The figures come from Bugler and Goodwin. What you won’t find on the present Victory are any Riders above the Orlop deck, but at Trafalgar these were in place, 2 sources, firstly the clue comes from Hardy in referencing them being shot through, secondly is correspondence I examined at the NMRN Library between the Chatham Officers and the Admiralty concerning the bolting up of these Riders during her 1801/03 refit. There is a further source I’m attempting to access at the British Library that may detail the extent (if different to the 1787 plans), but the BL are a bit elitist and don’t let you always access their manuscripts collection unless you are from Academia or a published author!
These upper riders were effectively replaced by the iron knees, strapping, etc. in the 1814/16 refit, hence why we no longer see them.
Gary
23 hours ago, vaddoc said:
Looking at the photo of Victory's planking above, it is incredible how thick the planks are. Considering the thickness of the frames and the inner planking, the hull sides must have been 2+ ft thick - solid wood. And still a cannon ball could penetrate.
Even thicker, we know from Trafalgar that the riders on Victory were shot through and broke, as were the Wales and some knees. This means you had to get through the outer skin, and frames to get to the rider
So we have the outer planking at 4 / 5”, the Wales at up to 11”, the frames at approximately 13”, the inner lining at 4”, and riders at least 14” but more often than not greater (upto 20”) depending on height above the waterline.
In summary anything from at least 32” to possibly over 40”. The destructive force of solid shot doesn’t bare thinking about.
Gary
I understand that part of the problem is the past use of laminated timbers, generally Iroko overlain with teak. The Iroko has rotted, whilst the teak hasn’t, meaning it looks good on the outside, but ……
The plan now is to go original and use oak, it will still use laminates, but all oak. I’m surprised they aren’t even trying to steam bend properly sized planks, but I gather from a trial video I watched that using thinner strips means it can be laminated over a mould of the individual plank without steaming and built up in the profile shape required.
Gary
Hi Lin,
You’ll find she has had a facelift, well, a new coat of paint at least! There are also a few artefacts from the wreck of the Invincible to look at.
I was on board a few weeks ago and due to the weather struggled to get a photo without a plastic bucket in it, I guess the upper deck needs re-caulking.
Enjoy your trip.
Gary
Hi Daniel,
When I went through Gunner Rivers notebooks the drawing was undated, unfortunately there is no logical order to his notes, he did not fill his pages in a sequential manner, such dated material as there was was clearly out of sequence. My best guess is that it was between 1793 and 1806, there being a new notebook from 1806 - 1812, but there were still sporadic dates after 1806 in the earlier book.
What needs bearing in mind is that Victory carried a mixture of Armstrong and Blomefield pattern guns, and it seems the carriages differed. Caruana dates the introduction of frontal horns and side cleats to 1795, these are clearly an add-on to standard carriages as he identified separate charges for them, so the breast pieces (front horns or stand-offs) were not integral to the main structure of the carriage. He is also of the view the side cleats were particular to the carriages for Blomefield guns to prevent tackle fouling. He reproduces the diagram from the Sea Gunners Vade Mecum as below, correcting some references, although this shows an integrated frontal horn and is contrary to his documentary evidence, although it was not originally his drawing.
This all ties in with the St. George artefacts, allowing frontal horns were added-on and necessarily, in my view, a sacrificial soft wood so as not to damage the sides of the ship, but which would have rotted away more quickly than the carriage bodies.
Given gun carriages lasted 10 years both Victory and St. George would have been issued with new carriages upon completion of refit. You don’t spend that much on a refit and then put aged gun carriages back in, even the Armstrong guns would have had new carriages, I think they could have been fitted with frontal horns, but probably not the side cleats.
Gary
There is a large scaffold like temporary structure covering her sides with viewing platforms at deck levels on her starboard side right now, including lift access. A guide is on hand to answer questions, you can also ask the conservationists questions.
There is also now a permanent walkway under the ship on the port side which is where Steve obviously got his hull bottom photos.
Steves last photo shows where the old support cradle pads were removed revealing planking that will be done if the oldest on the external hull, although there are also several strakes of ‘top and bottom’ just below main whale, but are obscured by the scaffold.
Gary
- druxey, Keith Black, tlevine and 2 others
- 5
Hi Michael,
Just catching up with you last few posts, and a couple of points.
In terms of painting ladders, gratings, etc. it depends if you are going for realism or following modelling conventions I suppose. If the contract said they were to be painted then I would imagine they were indeed painted. But then what colour? In contemporary paintings they look like natural wood. So is it the case they were painted with Rosin - the varnish of the day? Modelling convention in the 18th Century and now dictates natural wood. There is also the issue of what any colouration wood look like at scale to consider.
In my view Longridge is wrong on the universal painting of the bulkhead blue. The pigment was very expensive, at Trafalgar Victory’s beakhead bulkhead was black with yellow ochre detailing, you can see this in the works of Stanfield and Turner.
In respect of the name on the stern it did vary from time to time, but at Trafalgar certainly Victory did not have her name on her counter. This is evident from post battle sketches by Turner and Livesay. Putting names on sterns in both paintings and models was to inform the viewer as to what ship they were looking at. Upto c.1790 I would have her name on the stern but not after that date.
BTW nice progress.
Gary
Adding to what Allan has said, in practice the models were made to expand the proposed draughts for a new ship or class of ships and provide a 3D representation to inform decision makers or to gather support for the proposal to show what interested parties were getting for their money. The models helped the observer to appreciate the lines and form of the ship. Models did not capture all fixtures and fittings, and neither did the draughts, unless some new facet or feature was being showcased, guns are one of those routinely omitted.
In practice ships and their models were ordered in the Royal Navy by the Board of Admiralty, whereas guns were provided or loaned to the Navy by the Board of Ordnance who were separate from the Admiralty, this is because they served both the Navy and the Army with artillery pieces until 1855 when they were disbanded. Perhaps the models without guns are an example of art following life reflecting the division of ownership between ship and armament!
Gary
The Caldercraft instructions are correct.
When Victory was restored in the 1920’s they used gun carriages that were readily available as a pattern, however, Peter Goodwin, the ex curator of Victory identifies these as fortification carriages from whatever land based establishment they dug them up from. Consequently they are incorrect making the guns sit off centre.
There has been a programme of recent to modify the carriages to correct them, which from my last visit seems not yet to be complete, there are some odd carriages particularly for the 12-Pounders.
Bugler and McKay correctly capture what was there, it’s just what was there was wrong.
Gary
- mtaylor, allanyed and thibaultron
- 3
To close off some of the questions initially raised it appears that the NMM purchased the model for themselves at auction, thus retaining it.
As reported in the May 2023 edition of Topmasts, the quarterly newsletter of the Society for Nautical Research.
Gary
- mtaylor, chris watton, GrandpaPhil and 3 others
- 6
Similar to Bruce’s thought, are they for a secondary or preventor breech rope? The Sea Gunners Vade Mercum mentions them.
Gary
- bruce d, DaveBaxt, thibaultron and 1 other
- 4
Dave,
My understanding is that the guns were to be central to the port, both horizontally and vertically, and this was part of the Gunners duties imposed on him by ‘Orders in Council’ - Sea Service Regulations. Where this is particularly evident is where gunports are fitted with with half ports (lids), which have a round opening where they meet to allow the gun to be housed in a run-out position. Half Ports are not usually shown on models, but we’re usually fitted to the upper deck (initially these were lightweight 2-part removable shutters fitted with hooks, eyes and dogs, but later in the early 19th Century the lower half was hinged).The chain plates and rigging should not foul the gunports. The Admiralty were very concerned with gunfire setting fire to the rigging. From time to time they reminded yards and Captains that where a mixed Gun and Carronade armament was used that only long guns were to be fitted in the wake of the rigging (AO’s dated 23 March 1797, 8 April 1803)
Other developments where an all Carronade armament was used to avoid the rigging was the addition of the muzzle cup to the carronade and mounting the carronade on the outside principle to move the muzzle beyond the line of the rigging. This is why you will see any given ship varying it’s quarterdeck and forecastle armament mix of guns to Carronades at various points in their career. As the muzzle cup type became predominant it allowed the Admiralty to relax the ‘in the wake of the rigging rule’ (July 1804), but this was reversed again in June 1805, presumably as the problem persisted.
You may have to tweak the positioning of you chainplates to avoid the gunports, and depending on what date you are modelling the ship think about where Carronades and long guns are positioned.
Gary
- davyboy, thibaultron and mtaylor
- 3
David,
I’m afraid you are looking at a theorised entry port from Victory’s 1920’s reconstruction as per Dafi’s reference.
Victory did not have an entry port between 1787 and at least 1816, this was an additional Gunport. This is demonstrated by contemporary plans and paintings.
I’m afraid the 1920’s reconstruction got many things wrong which have perpetuated.
My understanding is where entry ports were in place the doorway was blocked off at sea by 2 part hinged ports, the upper part lifting up like a gunport lid, and the lower part falling outward to form a landing platform. The grating is just an internal step, it allows water that visitors drag in to drain into the waterway and avoid them stepping in the inevitable localised puddle that will form.Gary
Dave,
I assume this is for your Endeavour. There is no contemporary evidence to suggest that deck planks at this time on the real ships were joggled or otherwise ‘let into’ the waterway or other margin plank. If you take the original surviving deck planking of Victory (lower gun deck only), Trincomalee or Unicorn their original decks merely butt-up against the waterway.
Joggling on real ships came later, and is often a model makers convention. However, this is your model and if course it is yours to model as you desire.
Gary
35 minutes ago, Michael P said:
68 pounders look to have been rare, but apparently one survives from 1790, in the Royal Armouries at Leeds.
Hi Michael,
I haven’t been to the Royal Armouries for a decade or so, but it’s only an hour down the road, I should book a visit for this summer.
Gary
Hi Michael,
Little know fact, if you are modelling prior to 11 June 1796, the date Nelson transferred to HMS Captain, he took with him 2Nr. 68-Pounder Carronades, probably the same 2 he had fitted to Victory 8 years later. Roger Knight recounts this his ‘Pursuit of Victory: The Life and Achievement of Horatio Nelson’, page 268. It seems Nelson toted these guns around the Mediterranean in his successive ships.
I have not seen anyone model this, primarily as these were unofficial ordnance that did not appear on the record.
Gary
Here is an interesting article on a well researched model of the Agamemnon, in particular the decoration.
https://julianstockwin.com/2017/10/10/agamemnon-the-darch-model/
Gary
Whilst Pocock was an ex-seaman and knew his naval subjects you have to be careful in placing absolute reliance on his works. He was more than happy to ‘bend’ the details of his compositions to suit his patron’s requirements (see the article by Eleanor Hughes in ‘Spreading Canvas’). There is nothing to say this happened with his painting above at post #11, but you then have the painting in post #1 which ‘stretches’ what Pocock produced exaggerating the sail size, which in itself stands as a case in point - don’t take as gospel any painting without corroboration.
Gary
Certainly the film Master and Commander shows chain pumps in use, you’ll confuse non nautical nerds if you don’t offer them 🤓
Gary
- chris watton, Canute, thibaultron and 1 other
- 2
- 2
On 9/14/2017 at 1:42 PM, JerseyCity Frankie said:
. And in situations like this, your safety lanyard becomes paradoxically dangerous since you want to clip into the futtocks, but as you climb up to this point you now are obliged to unclip and reposition your safety lanyard to a higher spot. This makes you more vulnerable than if you had not clipped on in the first place since now you're hanging on one-handed while you re-clip. To deal with this many modern ships have a dedicated safety line running from above the top down to the highest ratline level. Clipping into this allows you to use both hands for the climb but if you do fall, you fall the full length of the safety line + landyard length before you fetch up. I saw this happen to a guy once.
Interestingly (or not 😉) we overcame this in the Electricity Transmission sector with the guys who climb the lattice towers / pylons, they are equipped with two very large Caribiners on separate lanyards and the mantra was ‘clip on clip off’ with the alternate lanyards so you were always secure. Watching them climb was like watching a mountaineer using an ice pick in each hand only a lot faster!
Fair play to anyone who climbs heights, I like to cuddle terra firms whilst watching others.
Gary
5 minutes ago, allanyed said:
Have you considered resin printed barrels? I paid $12 for 18 barrels in two sizes barrels to the 3D printer
That is a very cheap solution compared to the likes of Shapeways and Model Monkey
- Canute, mtaylor and thibaultron
- 3
Gun Carriage questions
in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
Posted · Edited by Morgan
It looks to me like the breaching rope wouldn’t fit through that ring which seems small, possibly a reproduction or conversion error depending on the origins of the carriage.
Even if you got he rope through it wouldn’t run freely and would bind.
Gary
