Chuck
Administrators
Everything posted by Chuck
  1. the rings are made in the usual manner. Wrapped around a 47 drill bit and parted with a razor saw. The bent wire is much lighter and thinner gauge. In my case here…24 gauge for the split rings and 28 gauge for the codder pin bent and inserted into the deck.
  2. I am not really sure but would guess that it was one of the hatches as well. If I was going to show that detail I would have one of the coverboards removed and the anchor cable passing through it. My guess would be the forward cover board of the forward hatch. But I am no expert in that area. Honestly I would need to do a lot more digging.
  3. Thank you Jim... I have completed all of the hatches, gratings and partners to be placed on deck. You have seen how the gratings were made. The two hatches are pretty similar. The only difference is they have cover boards rather than gratings within in the coamings. The photo below shows the laser cut coamings assembled. There is no need to remove the laser char from the lap joints at the corners. In fact it probably isnt a good idea at all. They are precision cut so you end up with a perfectly squared up coaming the correct size. You can and should sand both sides of the sheet before removing these laser cut parts to clean the char from those sides. Just glue them up using the same right angle jig provided earlier. Then sand the char off the top of the completed coaming being careful to keep the round-up consistent. You can see the smaller hatch completed. The larger one shows the three cover boards also laser cut waiting to be glued into position. But this you will also note the ledge created on the inside of the coaming that the cover boards will sit into. These are laser cut for you and can be glued on the port and starboard insides of the coaming. This photo shows the three coverboards in the coaming. They are pretty thick, but only so they are flush with the center of the coaming to allow for the round-up. The round-up along the sides of the coverboards should be sanded flush to the top edge of the coamings along the P & S sides. I know some folks like to show one or two coverboards off the coaming. You can do this if you want to. But then you should sand that roundup into the bottom of the coverboards as well. But I will show them all in place like the contemporary model. To finish off the hatches...round off the corners using the right angle jig like you did for the gratings. Trim them down to the top of the deck planking. The bolts were added using black fishing line in the same way. The iron ring for handles were made just like those on the lower platforms. Exactly the same. Also shown in the photo above are the mast and capstan partners. These are completely laser cut for you. They have etched lines to show the separate sections. All you have to do is sand them clean and round off the corners as described earlier for the capstan partners only. Soften the top edges as well. Add the fishing line bolts and the eye bolts on the main mast partners. Now some of these can be glued onto the model. They are all ready to go so you can start planking the decks. BUT there are a some like the main mast partners and capstan partners that need some extra work. I will describe that next. For example the elm pump tubes below the main mast partners and the capstan drum as well. More to follow...but here is a photo with the all of the hatches, coamings and partners simply test positioned on the model. They are not glued into position yet. I did however glue the smaller grating and coaming on the forecastle deck in permanently....those are all finished up. Its getting there!!!
  4. Nice save....I have a bit of room on that sheet so I have added a second pair of those parts 9 & 10 just in case. Best to have a back up... I am watching the current builds closely so I can add extra back up pieces based on which ones might need it if room on the sheet allows.
  5. They look great. You did a tidy job of all those individual pieces.
  6. Coming soon. Resin cast barrels. I have three sizes of cast resin barrels that will soon be available on my site. Currently I have the 11/16" tall and the 1" tall barrels. I am waiting for my casting guy to make the third smaller size. I may even make a fourth smaller size later as well. I have the two smaller sizes and I am waiting for the last larger size not shown. They are cast in white resin or a light tan like my carvings for the ship models I make. This makes it so much easier to prepare than building my laser cut versions. Those will still be available but these resin versions will give you guys more options. These can be prepared in minutes... Just clean whatever flashing which is minimal. And remove the small vent hole plugs with a sharp #11 blade. Then brush on some gel stain...in my case pictured, I used General Finishes Fruitwood gel stain as usual. I have one coat of stain on these. You can add more to deepen the color as you see fit. Then I just used a black sharpie to color the raised iron hoops. You could use any color you want for those as well. You could use a copper leaf pen for example. It isnt difficult....and takes just a few minutes vs. a much longer time to build my laser cut versions. Each size will be sold two per package. Its unfortunately too late for me to add these in the hold of Speedwell....but when you need to make a dozen or more barrels for the hold its nice to not have assemble them one at a time. And Buckets...crates...and other items will soon follow. And whatever else I can possibly think of...please let me know if you guys fancy something in particular.
  7. Yes just knock the corner off a bit. I would continue the taper lower a bit…not much by maybe a 3/4”.
  8. No I wont be selling a wood package. I just dont have time to mill wood and sell lumber. I work directly with Joe at MS. We are old friends that go way back...he mills and supplies me with all of my wood at Syren. In fact we are hoping to go to a yard to pick up a whole bunch of cedar really soon. We are currently very low on it. Chuck
  9. That would be so nice but it probably would put the builder at risk of being abused. Anyway....those gratings You will basically get all of the laser cut parts in this chapter. There are only four hatches with gratings. They are not very large. Here are all of the elements needed. You will get two layers for the jig. The two layers are glued together to form the jig. You also get a right angle jig which is 3/64" thick. The thickness is very important. Lets get started. Start with the coamings. They are laser cut and 1/8" thick. The fore and aft sides are already shaped with the round-up of the deck....or camber as usually described but is an inaccurate term. Use the right angle jig to glue two sides together...dont worry about the laser char just yet. Then glue the remaining two sides together using the same jig to make a nice right angle. Glue the two right angles together to form the coaming. Sand the sides clean which are left a bit longer as you can see in order to remove the char and leave a nice bright smooth surface. Also sand the top sides to clean the char. You can see the cleaned coaming below. Then you can start working on the grating. Again just like my other smaller scale grating kits. Insert the laser cut grating strips in the slotted jig. NO GLUE of course!!! This is just for alignment. Then start adding the cross battens. These are glued in position. They may be too tight as you want a press fit. So just run the small strips 1/16" x 1/16" through your fingers with some fine sandpaper. Not much. Just enough so the battens fit into the slots. see below. There are seven batten strips and seven laser cut grating strips for three of the hatches. The fourth is made the same way but is much smaller on the fcastle. When all the strips are glued in position, remove the grating from the jig. Snip off the edges as shown below. Then sand all four edges clean. Try and not distort the perfect square shape. In the photo two sides have the ends snipped off. The smaller hatchway will have fewer battens and more to snip away. Also sand the top surface clean and smooth. Once again try and maintain the proper shape with the round-up. You will know when its all done when the char is cleaned from the laser cut grating strip squares. The photo below shows the top of the grating and sides all clean and nice and smooth. It makes a nice grating. The holes are 1/16" or 2" on the real ship and perfectly in scale. You should but dont have to sand the bottom side as well. Here is a look. The battens are clearly less thick than the grating strips and these are pretty close to actual construction methods. Or at least the impression of it. And almost done...you will see how nice and tight the grating fits in the coaming. Dont over sand the edges and you should test the grating in the coaming as you sand the edges. In fact, the coaming normally has ledges on the port and starboard sides inside the coaming. These create a ledge that the grating sits on so it doesnt fall through. You can add those if you like. But in my case the gratings fit so snug that they were not required. I simply glued the gratings into the coamings making sure the top of the coaming was flush with the grating. I sanded it smooth with some 400 grit paper. The four corners of the coaming are very sharp at this point. You dont want that. They should be rounded off. But they are only rounded off down to the deck level. That is when you take that same right angle jig and use it. The jig is the same thickness as the planking. So you can place the coaming into the corner and use a sharp #11 blade to slice away the corner. Slice it down to the top of the jig only. You can make a stop cut at the jig level before slicing off the corner. Then just round off the corner. Dont slice off too much. Just a little bit to round off each corner. To finish it off I drilled three holes with a #76 bit. I used 20lb black fishing line to simulate the bolts on the top of the coamings. Three on each side. They cut flush with the top of the coamings with a sharp blade. All done!!!
  10. Yes, another forum but seriously most already know what they are like...thats why I wanted to post publicly for everyone not to take the bait. Its just not worth it. Just stay clear of the whole bunch. Chuck
  11. I am just about to post an update with those...LOL The gratings for Speedwell are different but the same basic concept. They are a different scale to reflect the larger size needed. They will have 1/16" square openings which at 3/8" scale would be a 2" hole. Just right and exactly the same number of holes as the contemporary model. These will all be included in the chapter along with the jig needed. I will have construction pics really soon. I have been distracted lately with the topic on the SOS where the staff and admin are trashing this project relentlessly....but its a lot fun to watch. Many of you guys have sent me messages alerting me about it. I have to thank Ben however for being a brave soul to have something nice to say about it knowing he will get the wrath for it. I must be the worst kit designer in the world if you read some of that stuff over there. But seriously...dont put yourself out there because if you do say anything positive about Syren or any of my projects on SOS they will lambaste you. So no worries. Dont put yourself in that position. Its not worth it. Most folks know its all nonsense. And I am well aware. But thanks for the positive notes of private support. Anyway...back to building gratings.
  12. That looks very good. You can extend it a bit further down the stem if you like. But its very nice. Same with the thickness at the figurehead area. Not much though. Dont be afraid to sand the gripe smooth at the keel intersection as well. There is plenty of meat on the bones yet.
  13. Thanks guys...There are a lot of things I could work on next but I am eager to get the decks planked. So next up I will make all the coaming and gratings down the center line so I can plank around them. Once that is done I will add the waterway and start on the fun bits. It should come together rather quickly once I plank the decks. A quick look at sheet 5 still being tweaked which has all of those details.
  14. That is kind of difficult to do with planking. The planking needs to be sanded. afterwards to be neat and smooth and it will only get wrecked. At least for me. Most items are indeed painted beforehand but I just dont see how you can do it with bulwark planking and have nice neat planking.
  15. What a difference some paint makes. Bulwarks are painted however as usual, I will be applying many more thin coats over the next few weeks as I progress. Before and after...
  16. Actually it survived without a scratch. I was very lucky. But yes they clearly dont know how to handle a ship model. I wonder if Ed Harris also autographed an original Jackson Pollock with a sharpie during that film....LOL. Not that you would be able to tell.
