Trussben
Everything posted by Trussben
  1. If anybody out there is still looking to buy Holly, try these guys in US. https://www.domexhardwoods.com/ ben
  2. Stern framing completed and transom looks like everything is where it should be, I will now add the QG supports and begin installing the frame reveal shadow box. ben
  3. JJ From what I see from that stern view, it appears that you have tapered them too much inwards, look again at the plans from astern to see the correct shape and adjust from there. ben
  4. Thanks All, After manipulation of the NMM plans in Autocad I have now also completed the design of the hull framing parts and where their joints will be. I need to make a load of these and construct the shadow box, I’m not going to make actual chocked joints - just simulate them and highlight with black monofilament line treenails. This could take a while. ben
  5. Here is my shadow box design and it will be made from 1/4” ply just like the bulkheads.
  6. Here is what I have cooked up for my Winchelsea build to add a little difference to it. I intend to add a frame reveal to the model, much like Chuck's one on his Confederacy or David's one on the Comet. Midships is the obvious place to put a reveal so as to simplify the design work and make construction easier, so I have decided to make mine between the bulkheads of station frames G thru 5, Also it will be just below the wales to allow for two strakes of lower planking above and several below it. It will be quite a large reveal so as to show the first and second futtock frame joints, I will have to construct a shadow box behind it to be painted flat black and the simulated frames will be made of swiss pear. According to "Steel" and the "Shipbuilders repository" table of scantlings, a 32gun frigate of the time would have had 11 1/2" wide second futtock framing, molded 9" with a room and space of 27 3/4", I intend to simplify this a little with 11" wide framing with 3" between them, and it works out that I can fit 23-24 frames in the reveal. I will finish the design side of this soon and start building it when I have completed construction of the stern framing. ben
  7. I’ve begun lining up the stern framing and adjusting everything before glueing using the patterns and plans supplied by Chuck, everything is lining up nicely and looks real good. ben
  8. Thanks Rusty, I have a feeling you will like the recipe I have in mind. ben
  9. Port layout and upper/lower cill framing complete, no issues were encountered with this process, and I have begun installing the port sides. Next up will be adding the stern framing and I’m also cooking up something special to add to this model which will change the original design somewhat but hopefully it will add to the whole. ben
  10. She looks great Rusty, have you decided on the final finish you are going to apply to that gorgeous pear? Maybe even oil it like Chris did on his Confed - that looked sublime IMO. ben
  11. Thanks for all the likes. Rusty - I have been at home for a few weeks so have managed to spend some time in the shop, that will soon come to an end but I hope to get the port framing completed before I go back on the road. Erik - sorry to hear the benches are so expensive, you could try and make one, instead of drawers just make 2-3 shelves instead, wouldn’t be too hard I think. ben
  12. Yep Chris, I have started the Rough fairing process before I start the port framing layout, you can see the flexible holly battern I use to check fairness as I go.
  13. I have completed the keel and started glueing the bulkheads together, here you can see them sat in place. ben
  14. Thanks David and Rusty, I decided to make up both the AYC and my own Pear/Box knee of the head to look at the difference in color and grain appearance and I have decided to go ahead with my decision to make the framing in Pear. ben
  15. Hi So I'm going to go ahead and start a build log of the Winchelsea, It will based off Chuck's designs with a few modifications of my own. My main reason for building her is because she was once captained by Pellew and I intend in the future to build another of his ships, a 1:48 fully framed model of the 44 gun Razee Indefatigable and it would be great to have both models together in the same scale. I will not be planking in AYC as I have a goodly stock of Castello Boxwood and prefer it on a model of this size, also stem/stern framing and keel will be of Swiss Pear with other wood highlights, maybe I will use the cedar on things that wont be seen easily and use the fruitwood gel stain that Chuck has discovered to blend it with the boxwood to minimize usage. I did purchase the Bulkheads and starter packages from Chuck and will certainly be buying his cast resin set when they are available. The first job I have started while waiting for planking to dry on Pegasus is to make a new build board for this "BIG" ship, it will be approx 38" long without rigging and will need good support while framing, planking and finishing, so I decided to go and buy another 'cheap' 5foot workbench from Harbor Freight for $100 and modify it to suit. First it was put together and lift casters added so that I can quickly move and spin the bench whichever way I need it. Second was to add 4-foot T-tracks and a nice large 1/2" MDF buildboad to the top. Third was to install the keel and bulkhead former holders ready for the backbone. The 4 drawers are great for holding parts/tools and the bottom shelf for materials which keeps an entire build together on one table instead of being spread about my workshop. Here is looking forward to an interesting build and I should start on the bulkheads later this week. ben
  16. Hey Rusty, just catching up and I think I see that your stern framing is still a bit wrong, see doctored picture showing where the upright and the back of the port should go to in yellow and the red shows where the bottom sill of the QG door should slant, this will affect the QG door a bit I think. Maybe you can get away with just filing the correct angle into that existing bottom framing to get it correct. Also I think you have your foremost gunport a little bit too far aft, the plans show its foreward aft edge on the aftside of bulkhead W, yours appears quite a bit further back than that, should be real easy to fix. BR ben
