Trussben
Everything posted by Trussben
  1. Completed installation of all the Thwarts, knees, windlass, mast iron work, and the sheeve. Time to start work on the Rudder, some thole pins, belaying pins. ben
  2. Hey Rusty, Yep - it sure is. I like working on it alongside Pegasus to keep me a little sane, and Chucks kits are always a blast and turn into great looking models if you take a little time on them - Yours just goes to show what level of excellence can be achieved. ben
  3. Hi Everyone, thanks for the comments and the likes. Here is the fore platform and the risers installed and “nailed”. Their positions were checked against the plans several times to make sure they were at the correct height and fore/aft position was good. Now onto the cockpit seats. ben
  4. Thanks for all the likes. Greg - no lower planking or ribands. Kenny - don’t follow me to closely as I might lead you down the wrong path 😳
  5. Hey Mark, yeh - multi year builds are tough - that’s why I do some of ChuckP’s “kits” in between ( they are plenty interesting on their own I will tell you ) it takes some pressure off and makes me want to work better on Pegasus - that’s the key point for me these days - follow Remchoes mantra! Ben
  6. Hi Pat, yeh - it’s kinda nice to see some coloring on her, I machined some boxwood today that I will use for upper planking, that creamy yellow really looks nice IMO next to that deep red/pink of the Swiss pear and the deep black of the dyed wales. as always - we shall see what next week brings - probably two steps forward and one back as usual. ben
  7. I decided to do a little work on the exterior, so the new Knee of the Head was made and installed, then final fairing and sanding to 220/400 was completed below the Wales and 1st coat of finish applied ( 50% danish oil / 50% mineral spirits ), the wales took some damage during sanding and will have to be re-dyed later on. Im quite happy with the color that the Swiss pear has taken on with this type of finish. Next up - remove the knight heads and fair the top timber line, then proberbly start the stern framing. ben
  8. Hi Kenny, I’m not much of a one for giving other people advice, just take your time and try not to accept something that you know is not right. Getting the spacing and symmetry correct can be tough if you want a really good result - I can’t count how many times I remade things on the lower platforms and lower deck - but I’m now happy with my results. One thing I’m doing differently from now on is using Black fishing line instead of copper wire and LOS to simulate bolts, much easier and looks better and more consistent to me. ben
  9. Thanks Everyone Mast partners completed, I was thinking about adding hatch gratings but have decided not to to allow what can be seen of below as much as possible. now to decide on what to work on next. ben
  10. Thanks Everyone for the likes and comments. Mast Partner layouts glued onto some boxwood blanks to start making them.
  11. Lower deck framing completed, have to make both main and mizzenmast partners to finish off.
  12. Quite a bit of work was completed in the last week before I start traveling for work again. Friezes added, trim piece scraped with simple profile and installed below the frieze, caprails painted, and all planking had the “copper” nails added. When I get back I will start on the floors. ben
  13. Stem Bolsters installed and inner upper strake completed - now to prime and paint which is my least favorite part of modeling. ben
  14. Hi Greg, I find it much easier to do them off the model when and where possible. ben
  15. Lower deck framing continues up to the beam arms, not far to go now. ben
  16. Thanks for the likes and comments. Here are the Caprails installed and I left a decent overhang both in/outboard to allow for sanding to correct width, next up is the stem bolsters. ben
  17. Here is the hull with all the frame tabs removed, the build board flipped over and two pieces of scrap glued to it and the hull fastened to the board. The reason for fastening the keel to the board was to stop hogging of the hull which I saw with the QAB as I only have minimal planking, maybe not needed with the longboat as the keel is much thicker but I thought I’d stay on the safe side. Maybe get the Caprails installed over the weekend. ben
