Everything posted by mbp521
George, Just catching up on your build and your work is beautiful. I’m glad to see that I am not the only one that is not a big fan of the britannia fittings. The only ones that kept from this particular build were the forward and aft bells, windlass and the pump, the rest I scratch built as well. Great job on the railing. I made several attempts at soldering the wire railing and finally gave up and fabricated mine from wood. I used the same wood stanctions that I used on the main a forward fife rails and built up a wooden handrail. Although it’s not historically accurate I found the results came out rather nice looking and match up with nicely the aft top rail. As for the spacing on the pinrails, I ended up drilling holes all the way down the entire length. I spaced these all at 3.5mm and it came out just about perfect. I then just placed the belaying pins in their locations according to the plans. I did skip drilling the holes in the middle of the pintail where the gangways are. I used the same spacing on the fife rails as well. Keep up the great work. Looking forward to more updates. -Brian
- 602 replies
- Flying Fish
- Model Shipways
Yards are looking good Keith. I’ve been on the steamboat wagon for so long that I am missing the full rigged ships. On my list of ships is a hybrid like this, one combining steam and sail. I wish there were more options available in kits. I had contemplated the Harriet Lane, but it’s a tad bit small for my tastes, and I’m not a fan of the solid hull. Going to have to do some research one day to find a suitable subject for that build. As for the jeep story, sounds like someone was having a good time that night. -Brian
Johann, I’m not sure what I am more impressed by, your ship building skills or your photography skills. Building a first rate model like this is one thing, but to do that and take such beautiful pictures as you go along. This just takes it to a whole other level. I truly enjoy following your work. -Brian
I was just following up on this post from last month. I was able to dig up the info on this painting and unfortunately it is a recent one and not from the 19th century. Although the coloring looks like a true representation of what Cairo may have looked like back then, there is no way of really determining the real colors, but I think I am satisfied with what I have come up with and will move on. The painting is titled "Infernal Machines" by William R. McGrath and was painted sometime around 1992. Mr. McGrath has numerous Civil War era paintings on his website https://www.wrmgraphics.com/, several of these are of different Ironclads, all beautifully done and worth a look if you are interested. -Brian
Nice tutorial Keith! Thanks for the info. I think that I have tried a similar method with wire before but I always either seemed to split the blocks with too many twists or I crushed them with the pliers. That’s probably why I mostly strop them with rigging line. Of course I most likely was using too big of wire for the process. I’ll file your method away and give it another shot with a smaller gauge wire when I get around to doing some more rigging. -Brian
Thank you Eric. On my first attempt I used the pastels to show the seams in the tarp, so when I redid it, I used the same technique. What I did write not about in the post was that there was another attempt before the final one where I ran the ropes across the top of the tarp, then covered it with tissue paper to give the look of the ropes being sewn within the seams. This idea proved to be a big mistake and looked horrible. So I went with my third version and strapped the ropes across the tarp and then highlighted them with the pastels. I was going for the look of the sewn seems underneath the ropes and never thought about the rope staining the canvas. However, that is a great accidental detail you pointed out that I’ll have to use again in the future. -Brian
Thank you Gary. I sure wish I was a better photographer because the pictures truly do no justice to the color. I lost count as to how many coats of different grays I put on my mock-up before I finally found a color that I liked. I was struggling to get the blue out of mixing the black and white and the Raw Umber was the final addition that did the trick. -Brian
Beautiful job Eric! I love the fact that you took an otherwise normal model and made it your own. Adding to the fact that you used home grown wood all milled on-site, not just for the hull but the display as well. Absolutely fantastic! I just recently purchased the capstan project plans and will follow your build closely, as that will be my next project -Brian
Hello again everyone, I figured it was about time that I get another update out there since it has been a day or two since my last one. I continued with work on the roof beams. I started with the area around the chimneys first, since there were so many pieces to fit together. The frames around the top of the flume were built first. Then the frames for the funnels were built. Once the whole section was assembled it was installed on the boat. Next I built the hangers for the piping. These were made from 24ga wire for the hanger rods and some scrap 3/16" x 1/16" strips for the supports that I had. I used small beads to simulate the nuts on the ends of the rods and painted and stained everything up. Then they were installed along the roof beams. Next I moved on to the roof beams forward of the boilers. This area contained the access hatch for the pilot house. This was another area that was lost during the salvage, so I did the best that I could to truly represent the way that I though this might have been built up. The location of the hatch is shown on the HSR plans and I used one of the examples for the comings from one on the existing gun deck that survived. Next it was on to constructing the skylight over the boiler. This was another area that did not survive the salvage. It was crushed when the mid-section of the ship collapsed in the cables when being moved to the barge so details are going to be pretty much left up to builders liberties. So what I did was follow the HSR plans that called for framing of 16 openings covered with a mesh screen that sat above the boilers, most likely to let out the excess heat and smoke. My take on this is that the funnels that sat just forward of the chimney could be turned into the wind to direct the airflow down into the boiler hold. The forced air from the funnels would flow through the boiler room, then up and out of the skylight. This is the template I used for the framing. Frames constructed. Mesh installed and then the whole assembly placed in the roof frames. Then the remainder of the roof beams were installed. Once I had the roof beams installed. I moved on the ships boats. These boat have taken on a life of their own and have been a very time consuming project. In one of my previous posts, I had shown that I had used the Model Shipways 5 3/16" lifeboat kits for these. Since these were the longest kits that I could find, they had to be modified and stretched to 6 3/16" to fit the proper scale of my build. I was having some difficulty trying to get the correct color schemes for these boats and I finally decided that I was going with a black hull with an off-white interior, to match the one shown in the only photo of the Cairo. I had first started out with the plan to build all four boats covered, since there was very little detail on the boats. However the more I thought about it, the more I figured, I am going through all the trouble to try and get this build as accurate as possible, then why not show some of the detail in these boats. I then decided that I would do all of them uncovered with the interior details because I wasn't sure if I could get the look of the boat covers to look right. Finally, I went ahead and decided to go with two covered boats and two uncovered. My confidence level was not very high on simulating the tarps, but how am I ever going to learn how to do something if I don't try. So here is my process for the boats. I started with the covered boats first, since I was still researching the correct colors of the interior and of the oars. The boats were initially painted with the reddish-brown color, which I later on found to be incorrect, but since I was going to cover them, I figured there was no need to go back and paint them again. Here is the construction of the covered boats. To simulate the tarps, I first wrapped the boats in some press and seal I borrowed from the Admirals kitchen (with her permission of course). This would allow me to remove the tarp once it formed to the boat. I then took an old pillowcase and wrapped that around the boat. Then I applied several diluted coats of clear Elmer's glue to stiffen the fabric, then several coats of white acrylic paint. Once the pain had dried, I removed the tarp from the boat, flattened it out and started installing the tie-down ropes. I also added some weathering to give a little bit of an aged look. Back on the boat, I started securing the ropes and fitting the tarp back into place. It was at this point, that I found that I was not happy with the way this was looking. Something seemed to be missing. When I was weathering the tarp, I tried simulating the seams of the canvas that would have been sewn together the make the cover and thought that this needed more. So I went back and tried it again. Following the same procedure as before, this time I decided that the ropes needed to go completely around the boat. This seemed to add a more realistic look to the way the covers fell over the sides of the boats and provided some separation of the cover sections. So I tossed the original one and built two this way. Then it was on to the open boats. I painted these with a white interior and gave them a bit of an aged, off-white look with some pastels. I went ahead and stained the benches, since I had already built the floorboards and stained them and I wanted them to match. Using all of the great input from everyone, I went ahead and finished out the oars. I used the same stain as the benches and floorboards to keep the colors consistent. I then used some small heat shrink to simulate the leather sleeves that protect the oars from wear in the oarlocks. I painted the handles black, only because I liked the look of the black with the stain. Then the oars were bundled together. Then lashed to the insides of the boats. A shoring rope and tiller was added as well as some more weathering to the oarlocks. And the second uncovered boat was completed. All four boats complete. All four boats on the ship, just to give an idea of what they will look like in place. They will actually rest in the davit supports slightly outboard of the current position now. Since the forward port boat will hang over the cutaway opening, I am thinking of showing this boat as in the process of being launched and sitting at the water level but still in the rigging. This will keep the boat from blocking the view of the interior and add a little action to the build. Lastly, I started playing around with the coloring and some of the weathering. I finally found a base color that I am happy with for the casemates. I mixed together black with a touch of white and raw umber. It gave me a nice looking dull gray that is not too light, yet not too dark either. I also played around with some weathering pastels, adding some rust to the railroad irons and armor plating. I also toned down the bright white of the port door interiors with pastels and added the inside straps and rivets. I cannot get the lighting right to do the pictures any justice, but from what I can see, I am liking the colors. Well, that is all for this update. As always, thanks for stopping by and all the likes and kind comments. -Brian
Mark, I was digging through some of my pictures and ran across this little gem from my visit to Vicksburg back in 2014. It is one of the information plaques from around the Cairo display showing a painting of her being torpedoed. I'm going to have to go back and do some research on the painting itself to find out if it was Civil War era painted by an eye witness or something done more recently for the exhibit. However it does give a good look at the coloring of the ship (not sure of its accuracy), and it brings about another interesting detail that I might want to add to my build. The sandbags added around the pilot house. I have read that there were many boats that used cotton and hay bales as a armor, mainly a lot of the tinclads and converted packet steamers. So it wouldn't be too much of a stretch for the ironclads to use sandbags for additional protection from enemy fire. Going to have to play around with this idea some more. -Brian
That definitely explains the reason for my question. It’s all in the appearance, and from what I see it looks great! Like Keith said, unless you were to put it under a microscope, no one would be none the wiser that it was all one piece. -Brian
Eberhard, what amazing detail work, on such a small scale! I have troubles painting pieces like this that are double the scale. So are the floor gratings and the comings two separate pieces or just one? From the pictures the grating looks as though they are framed due to the color differences. Either way, fantastic work! -Brian
Lots of tedious work, but the end result will look fantastic! Beautiful job so far on keeping the planks perfectly aligned. -Brian
George, I have several Model Shipways kits, both finished and ones still in boxes. In my opinion, MS puts together a fantastic kit, it is a shame that they can't seem to get better quality fittings than the Britannia ones they ship out with their kits. I'm sure it is to keep the cost down, but I would be willing to pay a little extra to have quality fittings included. As for the recent progress, you are doing a fantastic job! I really enjoy following along on your journey. One of these days I'll get around to digging my Flying Fish out, dusting her off and finishing her. However un-authentic it may be, I love the half moon detail on the water closet. Nice little touch to make the model your own. -Brian
- 602 replies
- Flying Fish
- Model Shipways
Wefalck, Another method that I just thought of and may give a shot, is to paint a couple of coats of satin varnish over the white. That may add a slight yellowish color to it as well. Generally the more coats of varnish the yellower the color tends to get, especially over white. I wouldn’t think that a coat or two wouldn’t add too much depth to the color. Worth a try anyway. -Brian
Eric, Good to see you back! This discussion has definitely proved interesting to say the least. I sure have a “boat load” of info to help me along (insert cringes here). I can’t thank the experts enough for their input. -Brian
Keith, I’ll have to give that one a look and see if it can tone down my brilliant white doors. -Brian
Mark, I’ve seen a few of other ironclads, but none of the City Class boats. The ones that I have run across show them painted in an almost battleship gray or some even with a brownish hue. None that I have seen show them as pitch black. The only City Class renderings I have been able to find have been sketches, drawings and lithographs. Of course all of these are black and white. I would presume that the same painting techniques would have been used on the other boats though, so these could be useful. -Brian
George, how right you are. I ran across this one during my research. It's not near as bad as some of the ones that I have seen. Some are just downright comical and cartoonish. -Brian
Wefalck, I recall reading something about that in Daniel's "Victory and Beyond" build here on MSW. This has gotten me taking a long hard look at my paint scheme. While I am satisfied with the red-oxide color that I used for my hull, I have been contemplating a repaint of everything above the waterline. The more I look at my build, the more I think that it is too black and not realistic looking. Since experimenting with the weathering, I have played around with toning the black down a bit by adding a touch of white and brown into the mix. I haven't quite come up with a color that I am completely satisfied with yet, and now that the topic of lead white coloring has come about, I'm also starting to consider toning the white port doors down as well. These were something that I have not been happy with since I installed them. The seem to stick out way too much. Personally, I am not 100% positive that these boats were painted pitch black at all. Looking at the pictures, you can see how much darker the ships boats are compared to the ship itself. I am thinking that they may have been a more grayish black instead. But the pictures could be skewing the colors according to the sheen of the paint as well. Some of the more glossy areas would tend to show up lighter than the matte features due to the light reflection. Just more things to ponder as I move along. -Brian
Roger, I think I would have to agree more with the first part of this statement (not discounting the second part). During the build of the City Class boats they were scavenging pieces and parts from everywhere to outfit these boats. There was a hodgepodge of armament initially installed on them just to get them going, so it would make perfect sense that the boats would have been requisitioned the same way. The supervising Naval Officer probably sent out the rec that he needed 28 ships boats in the 25' range and accepted everything that was sent his way. This would partially explain the variety of different colors and shapes the different ironclads have in the photos. That and over time some of them would have been replaced from battle damage given their location on the ships. Real easy targets. -Brian
