Everything posted by RGL
You’ve inspired me, I was in a hobby shop the other day and bought the old Tamiya kit of the Fletcher
- 140 replies
- the sullivans
- trumpeter
There you go, a nice clean deck! Note, do not add the 10 fairleads until after the deck is laid as you’ll have the same pain I just did. I’ll have the trim the edges so the stanchions can go in.
Just to annoy, but, North Star make some very small chain links you can make very realistic chain from. But it hurts. A lot. And takes forever.
I only use acrylics for the main paintwork. Chipping fluid from AK has some Utube videos on how to use. The washes and weathering is all enamels. The scale is so small you have to use an airbrush to avoid losing details.
I really lost the detail of the side armour panels. So I scribed them again and gave them a dark grey enamel wash to bring out the detail.
But wait! There’s more! The large grey bootstrap. The waterline is midway but apparently they rubbed off really easily due to the lack of enamel during the war. So, a quick mask, some chipping fluid, some grey, rub it off a bit. I’m really happy with where I’m at with this. I can now airbrush a waterline with green grunge and white for salt. I’m interstate for a week so nothing will get done. Then my plan is to put the deck on perhaps then do weathering.
Doing the wetting for the worn effects, three layers of paint over the top is too much. Still comes up ok.
Hull colour. First, 2 layers of chipping fluid. Next a blue grey undercoat next a lighter grey highlighter for the panel lines finally light grey overspray. Ill give a a couple of hours then do some chipping
I’m still very tempted to do one. I have the AOTS book, so lots of references.
- 140 replies
- the sullivans
- trumpeter
Only Boxing Day. I’ll get the template to you Friday. It’s a lot of work to get the lower hull plate measurements correct, then when you do the holes for the booms it all comes together
So, already knocking two pulleys off, the forward 88mm gun doors which the kit makes no reference to but every photo existing shows.
So, about 4 hours work and the port side is done. Brackets, hull fittings, rings, ladders, pulleys etc.
HMCSS Victoria 1855 by BANYAN - 1:72
RGL replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Happy Xmas Pat- 993 replies
- gun dispatch vessel
- victoria
