Everything posted by RGL
Next, the flag lockers. Pontos does not address these at all, but Flyhawk supplies 5 open boxes. A few open source photos from the net show the details.. I considered getting individual cotton threads of different colours to represent the flags, but it would be just a bit too much. I used WEM grills cut and folded into the open boxes and some painted foils to represent the covers. I already added several belaying points for when I rig her out for flag halyards.
- 342 replies
- dreadnought
- zvezda
Next is the fore 12 pdrs, search light screen covers and ammunition hand up hatches. Then the 4 search lights on the Admiral's walk. 2 are electronically controlled and 2 are manual, so I placed flywheels on the manual ones.
- 342 replies
- dreadnought
- zvezda
Now the belaying is done, I can add the Admirals walk and Cabin.I used the Flyhawk one as it fits better and looks a bit more natural than the Pontos one whichrequires you to use the kit supplied roof which would be problematic fitting under the lip of the fore funnel.
- 342 replies
- dreadnought
- zvezda
Moving right along, now the boat deck. I attached and rigged the funnels. Some of the lines belay to the towers so will have to come after.
- 342 replies
- dreadnought
- zvezda
Gunther, I can only assume it is to diffuse the heat plume from the stacks. A bit of research on Dr Goigle seems to indicate this but I'm sure there are a few engineers here that could elaborate on this.
- 342 replies
- dreadnought
- zvezda
It certainly is David, I think all of us are OCD to a point, why would we bother otherwise with this hobby?
- 342 replies
- dreadnought
- zvezda
Now the funnels which will go on the boat deck. The funnels grill is very intricate and in many pieces which I had to make up a little jig and cut off and replace all the vent pipes and fabricate the pipes for and the horns. Also making up a funnel band and eyelets for rigging later. Came up nicely.
- 342 replies
- dreadnought
- zvezda
There are a myriad of deck hatches, and Pontos and Flyhawk both have some gaps in their plans. In particular the engine vents that Pontos just chose to ignore. There is a LOT more detail to go on top the decks but this will do for now to save snags.
- 342 replies
- dreadnought
- zvezda
No, didn't need to, it sits perfectly flush.
- 342 replies
- dreadnought
- zvezda
The deck has an adhesive backing, so it "should" just stick on. When I placed it on it stuck, then a couple of hours later it popped up in places, which I rubbed down thinking it needed heat, and a few hours after it kept popping up, thus the thin CA as anything else would leave bulges
- 342 replies
- dreadnought
- zvezda
The wood deck comes with the pontos upgrade kit, and it is just lovely, just not very adhesive.
- 342 replies
- dreadnought
- zvezda
A bit of a re think and the deck has to go down so as not to catch on stuff. A simple exercise? No, after laying the thing down painstakingly, after a few hours the thing keeps popping up in sections. Using a sliver of PE and thin CA over the last few days I have been making running repairs to get the thing to sit properly. Still looks good and makes me happy with the guesstimate of the paint colour. I have now down up all the boat deck and funnels but will now not paint or attach anything until I have done up the deck hatches.
- 342 replies
- dreadnought
- zvezda
Mate, looks great. I knew it would get to you!
- 517 replies
- Endeavour
- Artesania Latina
I'm in. There are a few Russian sites with these builds which is why they invented Google translate. Massive undertaking.
- 244 replies
- borodino
- dom bumagi
Yes mate, I will be, but it will be a while off yet, I want to work from the centreline outwards. There is a heap of work to go yet. I'm looking forward to the contrast.
- 342 replies
- dreadnought
- zvezda
As this part of the kit is fairly well covered up by the boat deck, not a great deal of detail was included. I replaced the search lights, added a front grill, cut off and replaced the winches, added fairleads and ladders. Grey is such a boring colour after the other kits.
- 342 replies
- dreadnought
- zvezda
Next is off to the flying bridge . The first of the guns have to be added, namely 10 12 pounders. The unpainted bits are, from left to right, North Star with the Pontos barrels, then the kit supplied with the Flyhawk barrels (which are 3mm longer, then just the kit one. The kit one is not bad, but just not detailed. The photo shows the real thing and the upper area of the barrel is almost silver, I tried gunmetal but it was just too dark.
- 342 replies
- dreadnought
- zvezda
Ok, a heap of photo etch cut and painted off hull, .then added today. The brackets for the torpedo net booms, multiple side hatches (which for some reason Pontos chose to ignore) and a bit of dry brushing
- 342 replies
- dreadnought
- zvezda
I had a look at the AOTS, and whilst it is there, it does not say what it is, but I would expect it is a strengthening piece maybe for ramming subs or if it went aground.
