Everything posted by RGL
If you are so inclined, you can use a very fine pencil (like a clutch pencil) to put treenails in. I did it on mine and it came up quite well.
I reckon if you've spent the $ on the upgrades you should. Not a biggie, and run an LED through the baseboard up through the supports (use some hollow brass rod) into the hull. There is a lot of imagination you could use there, even if you make the flight deck removable.
Go to the Northstar models website (Dr Google it), they are in the Ukraine and have some very useful stuff. Their eyelets and turnbuckles are very nice, I suggest you get 2, 1 to blacken and 1 to paint.
- 342 replies
- dreadnought
- zvezda
- 342 replies
- dreadnought
- zvezda
It's only about 1mm wide, so it does take much of a change of camera angle to miss it, so you did well to pick it anyway. Work is in the road at the moment anyway. Dayshift kills me.
- 342 replies
- dreadnought
- zvezda
It may just be the fit of the stick on deck, as it does not align perfectly at the bow and stern. The handrails have not yet been added in this photo and may conceal this? I must admit I have not noticed.
- 342 replies
- dreadnought
- zvezda
I think you mean the torpedo net shelves? They have been added, this photo is just to show how they jut out from the hull. If not, there is a good chance I've missed something!
- 342 replies
- dreadnought
- zvezda
Bugger, this is a whole new world. I reckon I've got about a month to go on this one, then a whole garden to weed and mulch plus my sideline of rowing coaching in summer. The next build will be a lot slower but bigger. I want to get this airbrush thingy sorted plus figuring out a compressor too.
- 342 replies
- dreadnought
- zvezda
So, considering a poor airbrush ruins work, what's the verdict?
- 342 replies
- dreadnought
- zvezda
I have no idea where to start, internet research I expect, then shop for the cheapest price.
- 342 replies
- dreadnought
- zvezda
Thanks gents, I'll leave the talented to the scratch builders, I have several of Jean Boudriot's books (who recently passed), that is talent. I use Tamiya rattle cans mostly for the big stuff, then washes and drybrushing. My next project is huge and I think the time has come to buy an airbrush.
- 342 replies
- dreadnought
- zvezda
- 342 replies
- dreadnought
- zvezda
As a massive exercise in futility, I have commenced rigging the inboard parts of the torpedo net booms. I have completed the port side using tiny eyelets as rigging blocks (they don't Kate them this small), running as described in the AOTS to the deck winches. I have not found anyone else stupid enough to do this method yet at this scale. I have lines running everywhere down the sides of the ship that will eventually be attached to the torpedo nets. Running alongside the hull you will notice a wire, rigged through eyelets, there are two turnbuckles attached for each boom to the wire. I had to use wire as the elastic rope will stretch away from the hull and look silly (or uneven, same thing). When the nets finally go on there is more rigging required which I just can't do yet. Photos to follow.
- 342 replies
- dreadnought
- zvezda
Looking at the collection of paints you have in the background, I reckon you know what you're doing. 30cm at 1/700 is massive, I've seen some of the detail kits for this ship at 1/350 and it's very complex so you've got some work ahead of you.
Amazingly I've had to add lots of extras as well, both the pontos & Flyhawk upgrade sets, extra doors, rigging pieces, spares from other frets. I'm not good enough to scratch build at this scale.
- 342 replies
- dreadnought
- zvezda
The answer is a really good set of tweezers. And a back roller.
- 342 replies
- dreadnought
- zvezda
Moving along, Pontos has a fairly elaborate set up for the torpedo nets. The AOTS book shows the rigging lines for them, which I shall now have to interpret to get correct. The shelves on the gunwales hold the nets when stowed, but as they will be deployed, they stand out and are frustrating to place. I have added the eyelets for the booms and the boat booms. Finally the net davits, from which I will run the onboard rigging first before I set the booms and nets, again working inboard to outboard, then I can add the awning stanchions, the davits the last of the rigging and the flags, and the ships cats, before the final stage of adding the booms and nets.
- 342 replies
- dreadnought
- zvezda
The Pontos rails were very nice, so why not, as they have very nice braces. The next one will be individual stanchions again. So, what should it be? Borindino? Mikasa? Yamato?
- 342 replies
- dreadnought
- zvezda
Things should move along quickly now. This is the first time I've actually used rails for a ship, as I usually do individual stanchions.
- 342 replies
- dreadnought
- zvezda
Now, I have finally placed the old girl on its Jarra Base, (which I have wrapped in plastic to save drips.. Next is the flagstaff's, which I have to add next as the rest of the rigging requires doing before the railings. After the placing of lots of turnbuckles for belaying points, I have added the awning and hammock lines. I also rigged the coaling derricks on the main mast. Finally, in the back ground to my desk is a photo I took at dawn back last century from the HMAS Bendigo of a tramp ship that had just deposited 300Kg's of Heroin on our fair shores. It didn't get away.
- 342 replies
- dreadnought
- zvezda
Bad typing, put a drop of glue onto a piece of hard plastic, dip a pin in it, then place said drop onto the piece you want to stick together?
- 342 replies
- dreadnought
- zvezda
Puddles of glue on a hard plastic surface, dip a pin in or an off it of brass etch the apply to either the piece I'm using or the place it's going (if that makes sense?). If it's load bearing I'll put a tiny drop on top of the piece that bears weight. The pins get a build up of hard glue after a while which I burn off then sand back to a clean surface. Less is more with CA. Like a tall ship, it's lots of pre prep, as one something has been painted off kit it will not fit as the tolerances are so small, if you paint something that fitted into a slot pre painted, it won't fit post painted, or it won't fit flush. CA works best on unpainted etch or plastic but the result is usually crap after painting as the detail is lost, especially if you're going to have differing colours, so I try and do everything as piece work, and use a tiny bit of matte coat by hand on glossy bits of CA. I'm not a proponent of over spraying with a matte coat as at this scale it loses detail to my eye (I have very good close vision and it upsets my OCD). I like to pre drill required holes then add eyelets afterwards otherwise the hole fills up with paint and you can't rig without having to risk major breakages clearing holes. I hope this makes sense?
- 342 replies
- dreadnought
- zvezda
