svein erik
Everything posted by svein erik
  1. Hi, thanks for the likes 😊 Am finish the hull planking and I also painted the hull black where the water line is, wel a little bit down the inner bulwarks is Soon coming on board😊 Svein.erik
  2. Hi again, yust another task has been dunn the cap rails , for this I used 1/4×1/16 castello boxvood it was wery easy task , soak it in warm water for about 90 minuts and started to lay the strip on top,strig it and bend it around The boxwood strip is in exelent condison 😊
  3. Thanks for the liks everyone 😄 Am keeping on running, A have know faring the inner bulwarks and some planking at the stern, I will wait with the rest planks so I can make the hole for the rudder. I do have also the 7 last planks on portside to finish To faring the inner hull I used 3 pises of tools , easy peasy 😊 Svein.erik
  4. Thanks everyone for the likes I did finish the starboard hull planking , I did some mistakes here erlier my tappering was not enuff at the start, so I got a problem with the last 7 planks but I did get the 7 planks inn tappering to half a with I have to take the garboard plank more aft then I was thinking so its not perfekt but close and the hull is getting copper plates later 😊 Svein.erik
  5. Thanks Thomas I do Not know how it wil look wen painted I yust resive it to day, I also noted that the slegde is to wide back and a little to long (ref.plans) I have mail them and sendt photo of the items and the plans, they are already responding so I have to see wat the wil do with this problem☺ Svein.erik
  6. Its a beauty 😄 I May have to do this my self😲 Svein.erik
  7. Hi everyone, I did resive corronades from shapeways to use on the syren, but I did order the hole set with the sledge in 1:64 scale but it Seems to me that the sledge is to big but the corronades is in scale so I need to send a mail☺ price is 54 dollar vs 181 from cornwall Svein.erik
  8. Thanks again for all the likes 😊 am know making the " chuck jig" for stamping copper plates this is my first 😲 but am not happy with it, so I plased an maby order to a stamping company to make this in metal 😊 metal stamp
  9. Hi Peter Take a look at chuck passaro's jigg for copper plates (istruksjon manual for brig syren) Svein.erik
  10. Thanks for the coment , as I did this hum#**/&%+...... 😲 am thinking of using a drop plank to do the task here and take this with me on the nex build as the syren get's the copper plates it vil not been seen Svein.erik
  11. Thanks for the liks but Huston, I have a problem😲 I think I did some wrong with the planking, its Seems to me it going to get to narrow there is 7 planks to fitt in there (about 2mm at the stem) So do I take all the basswood strip off ore just leave it? Svein.erik
  12. Thanks for the likes and kind works, am moving my way down to the keel using the crapy basswood I just started to form the garboard plank before the last planks get on board Svein.erik
  13. Yust got this from ME and am going to glue some sandpaper in the side of the notches then run true the basswood so it is even 1/8 before I glue it to the model Svein.erik
  14. Thanks for all the likes again, it keeps me going😆 but I did need some more lights so I Whent to IKEA to get some stuff and built it know I have 3500 LM all over the model good light is half work😊 Svein.erik
  15. Is going to be a grait model, I got the longboat still in the box I love the innboard replace wood it make the model devine Svein.erik
  16. Hi again and thanks for the liks the summer is here So I have work to do outside the shipyard (yust to keep my wife happy😉) But I did finish the 2 belts with boxvood and its time to get over to use basswood am over the critical point at the stern, The black paint wil have castello boxvood, I my have overdue this but Wats fun in that 😆 Svein.erik
  17. Wat glue to use on complex wood/metal work
  18. Thanks for all the likes 😊 am still planking my way down to the keel on portside and starboard I have about 3 more planks before I go over to the basswood strips so I can paint the hole stern post black using boxvood Svein.erik
  19. Its a beauty, cant wait for it I need know deside if I want to build the winni first or the cheerful I have I stock 😲 Svein.erik
  20. Hi am back from my trip in Berlin an did some history movment, thanks for the liks and kind works am also back in the Shipyard and working on some more planks so in a day ore 2,3,4 The best from svein.erik
  21. Sitting in Berlin airport back to Norway fond a little hollydays I did some more planking (before the trip) am using the boxwood plank on the 2 belts so I can have all this plank all over the lower canyter Svein.erik
