Posts posted by Blighty
4 hours ago, Mike Dowling said:
Len, it looks smashing, well done. Are you going to swap the little out house you made for the battery for the chicken coop? Then no one would know your secret inside !
Crikey Mike, are you suggesting I fill the outhouse with BATTERY HENS?
I'm super stoked tonight, I just lit up the Ole' riverboat for the first time with all the lights in place including the Texas and pilot house, all yellow LEDs. Very pleased with the brightness and balance of luminance. I have to clean the wiring up tomorrow and glue down the pilot house. So pleased I went ahead and lit her up.
I had to make a outhouse to house the 9V battery but it looks ok, still requires a splash of rust but I don't think it is out of place.
Len
- Tigersteve, mtaylor, Canute and 8 others
- 11
37 minutes ago, chborgm said:
Thnaks Bob Up close it has it's faults.
Blighty
I picked the Monroe plans because It looked like a typical riverboat . I have changed a fair amount of it. I enlarged the engine room to include what i think would be a kitchen, I converted it to wood because I like the piles of logs, and moved some things around to cover my mistakes. The one thing I learned in this first scratch build is once you start to improvise you creaet a lot of downstream problems that the kit builders solved. It adds to the enjoyment though, and it uses up a lot of the inventory of wood I had accumulated over the years.
I built the Chaperon and that started by love for steam power, and also I am getting to old to tie a lot of lines
I like your thought process, I am travelling down a similar road, my eyesight prevents me from lottsa rigging.
Hi Clarence, I think scratch built models hold a certain fascination, at least for me they do. I definitely plan to do one some time down the road but I'm not ready yet. A few more kit builds first.
A couple of questions for you though:-
Is it has much fun for you as a kit build? (it seems to be)!
Would the Monroe still be the scratch build of choice now you're more informed?
Looking in it appears you aced your choices, I think she's an absolute beauty, and I love the freedom to modify for the better you are achieving.
Keep up the good work, an envious admirer.
Len
33 minutes ago, Rossi46 said:
Starting to look really good Em. Congrats on progress so far.
- mtaylor, Rossi46, billocrates and 2 others
- 5
On 2017-02-15 at 8:06 PM, Worldway said:
I went down to my shop tonight to grab something really quick, and well, one thing led to another.......
So, from reading other logs I knew that the aft section of the false keel was delicate. I still managed to break it. Luckily it didn't snap off, it was just a fracture, so I applied a bit of CA and was back in the game again.
After that, I figured it was safer to sand the laser char with the keel on edge.
While sanding the middle keel, I guess I got too aggressive and, once again, I fractured the part
More CA and everything was fine. I think I was lucky that nothing completely broke off.
I wan't happy with the fit between the aft and middle bulkheads so did additional sanding (carefully) to get them better in line.
I then used a generous amount of carpenters glue to attach the three sections and added some weights. I'll let them cook over night.
Hi Derek, I notice you do not lay wax paper over the top of your joints asyou do below. I found this useful when I wanted to apply weight directly over the joint.
Bet of luck with this build, also on my short list.
A beautiful day here in Windsor.
Len
Thx for the comments above, I'm looking forward to getting the final couple of decks down now, the end is in sight.
I have to now paint the brass components, any advise as to best way of doing this and which type of paint to use? They are all still attached to the blank except for one piece. Thx in advance.
- Mike Dowling, Cathead, coxswain and 6 others
- 9
Great looking model Mike, I can picture Oloff the 'orrible sitting up front with his mighty hammer ready to knock Adrian's Wall into the North Sea.
- mtaylor and Mike Dowling
- 2
1 hour ago, Canute said:
Len, coming along nicely. The washes work well, don't they?
Thx Ken,
Yep, the vinegar wash is great but a few draw backs with it too.
The pros:-
It looks exactly like real aged/weathered wood, no mixing colors or skilled art techniques required.
The stain is permanent and the penetration is deep into the surface, this allows rubbing down after paint, for example, vinegar wash, allow to dry, thin coat of paint and then sand off areas where excessive ware is required, I did this on the deck in fairly large patches.
Easy to paint over, I really like putting a thin coat over the top as on the pilot house, so the stained surface shows through. Much more pleasing than seeing virgin wood showing through the paint.
Another thing I did on the deck that I forgot to mention, after final red oxide spray, a few patch ups with a mixed red/black to get close to the spray color, put a bit of variation into the finish. So when that was done I still thought it was a little bright compared to the aging on the walls so I put a brushed coat of vinegar mix on top of the paint. I think that looks stella, may be a bit over the top for most tastes but I was well pleased. Dulled it right down.
The cons:-
Warpage, hard to avoid on thin stock wood, this could be a downer for the pro modeller. For me, I'm just having fun with the build, a few flaws in the tolerances and joints though I try to avoid them, it doesn't detract from my enjoyment of the build.
Different species of wood stain differently. I don't know the woods used but if you are considering the vinegar solution, try some on scrap pieces. Some of the wood I tried to stain barely changed, however same types seem to be consistent. (This can be seen on the wall I created rear of the boiler, I used some scrap wood from my previous build, (Emma C Berry) along with some Chaperon kit wood. Stained it afte it was built.
My next build is the Picket Boat from MS, I'm thinking of painting all the wood with the vinegar before starting and keep the painting to a minimum except the outside of the hull which will definitely be black. I'm already looking forward to that.
Beautiful detail, this scale is crazy.
- Omega1234 and FriedClams
- 2
I have the pilot house constructed, just have to add light and some furniture. I purchased the wheel from M/S it is very nicely finished.
The interior of the pilot house deck has had the vinegar wash treatment, I am liking that finish more and more, especially when the solution has aged.
I've been working on my hobby room so the Chaperon will have a better dry dock for her refit.
Note, for the modified frt panel of the pilot house I used 1/32" stock, I'm pleased with the scaled appearance.
Excuse the quality of the modelling,
my close up shots will expose my considerable shortcomings, 'practice makes
perfect!',sawdust in my case.The walls were also washed with vinegar and then a thin coat of white was applied ensuring the weathered surface still showed through.
- Rossi46, Mike Dowling, Cathead and 6 others
- 9
TIgoe, your kind comment has made my day, thanks so much. I'm certainly no expert and have learned things doing this build. Good luck with your weathering efforts. Anything you want additional detail on, let me know and I'll help where I can, just don't expect expert advise!.
Len
If I dare make a suggestion why not have the battery outside of the boat? I think it will show a lot if you put it in the pilothouse. Also tricky when you have to change it. I would have thought a tiny hole either through the hull or between decks for the wires would hardly show.
Mike,
I thought about putting the battery on top of the Texas or Skylight deck but I have it from good authority the Captain is storing some crates of wine under tarpaulin sheets on one of these decks which leaves little room for wine and battery. Now if a few of those wine cases were to 'be left off' your plan would work!!!! ummmmm.
- Canute and Mike Dowling
- 2
Clarence,
Using your ships for night lights must look awesome, great idea, however I think that commits you too house power source.
That was not a consideration for me, the only time we will be in darkness in my display room will be to look at the Chaperon lit up, a matter of minutes only. I have not calculated the battery life, nor am I likely too but when the installation is complete I will definitely run a fresh battery to failure and add info to this log. Actually running a test is the best real world method in my opinion.
Battery power does make life easy for a clean self contained installation in most cases, I was originally going to mount the battery in the hull but I was on again, off again with the lights, (no pun intended)! so my options kept diminishing as the decks got built up. So now, the battery will be mounted in or around the pilot house, exact location tbd. another wing and a prayer design change.
Thx for following.
Chaperon by Blighty - FINISHED - Model Shipways - Weathered and aged - My first build log
in - Kit build logs for subjects built from 1851 - 1900
Thx Doc!
