Everything posted by garyshipwright
Thanks Albert. We do have a long way to go to catch up to you but thank you for the kind remark's. Gary
Hi Frolick. Thanks for the information on the Montague, didn't know this. Thank you for the kind words and glad that you like her.
Hi Tobias and thank you for the compliments. Yes I drafted the plans of her, the half breadth plan and then her frames from that. I also drafted the lay out of her deck lines from the shear plans. One does have to be very careful because after many years the plans have enlarge, grown and redrafting this parts, help's straighten this out. Makes her easier to build. I do thank you for your kind words.
Thanks guys. Guy your right about that, have been busy that's for sure. Thanks druxey, thought that might add a little detail to her. If you look close at the top of the capstan. I installed some pin's and chain's for holding the bar's in place. Still a lot to do on her, just need to spend a lot more time on her. Once I get the beams installed I may just have some fun and install the stove that I built a couple of years ago.
Hello every one. It's been awhile since I posted any thing on Montague/Alfred but wanted to get the the planking done on the Winchelsea and after 6 month's or so of building the bulkhead's and planking her in boxwood I finally went back to work on Montague/Alfred. Been slowly working on adding more beams to the upper deck. I added a few photo's of the Winchelasea and do hope you enjoy the photo's. Sorry about the delay on getting back to her. Gary
Hi Johann. Looking outstanding as usually. Have a question for you. You showed in post 2079 your soldering station and was wondering where you got the to tall clamp looking items in the white board for soldering. I have been looking for a set of these but as of yet have not found them. Keep up the great work and thank you. Gary
Hi Stevinne. It really depends on what scale you working on. Am sure if you give that bit of infomation a few of us could let you know what size you may need. Gary
HMS Euryalus 1803 by rlb - 1:48 scale
garyshipwright replied to rlb's topic in - Build logs for subjects built 1801 - 1850
Looking good Ron. Believe it or not some of us our still learning. It still takes me a couple of tries to get it to the point that I like it. Keep up the good work. Will be watching your build. Gary- 122 replies
- Euryalus
- Plank-on-frame
(and 4 more)
Well good folks I couldn't find a finish that Iiked so I used the one I put on Alfred. I have been using a mixture of bee wax and thinner, brings out the wood nicely and will add a nice golden color to the planking and not change the color of the wood. Once it's dry I take a rag and wipe it down, and use a bit of steel wool that will bring out a nice sheen to her. Gary
EURYALUS 1803 by Peter6172 - 1:48
garyshipwright replied to Peter6172's topic in - Build logs for subjects built 1801 - 1850
Hi Peter. When I installed Alfred's cant frames , along with clamps and glue I also pined them in place. Once they was good and dry the pin's were removed and tree nail's were installed. Helped keep every thing good and tight. Nice build so far. Gary -
Looking good Siggi. Have always enjoy your build's and enjoy the crew who are building it. Outstanding job. Gary
