Everything posted by Ondras71
Roter Löwe 1597 by Ondras71
Ondras71 replied to Ondras71's topic in - Build logs for subjects built 1501 - 1750
Working with paper plans isn't exactly easy, but in the days before computers it was as well the only way.. The paper ribs really needed adjusting, making the radius accurate.. I transfered the modified shapes back onto the ribs. I transfered the heights and the shape of the deck and then deducted future planking.. I thought about a way of gluing the body of the galeon's hull, so that it wouldn't twist. I decided for a reversed variant, where the ribs stand in exact height on removable parts.. Finished paper ribs and keel are now ready for gluing on 6mm plywood and carving it.. -
Hello. Golden Hind is my favorite galeon, but Roter Lowe has won, because it is bigger .. I'm looking forward to building and watching all the similar buildings, including yours .. Only the Holad boat is a bit different from English, which attracts me .. -
Thank you for your welcome here. I have books ready to support the construction : Wolfram zu Mondfeld - Historic Ship Models Rolf Hoeckel - Risse von Schiffen des 16. und 17. Jahrhunderts Herman Ketting - Prins Willem Wolfgang Quinger - Wappen von Hamburg Beginning "from scratch" is a bit different than a modular one, there is a lot to save and spoil.. As I said, I first created a paper half of the hull.. When laying a rail, some ribs really do not fit.. So I varnished the edges of the rib and there will be more grinding and adjusting . So treated ribs will be a template for plywood ones .. -
My previous construction of a kit.. ..is coming to an end, so it's time to start with a new one... Another construction I'm starting is scratch build, I've decided for a ship from the 16th century, a galleon, which I always liked, specifically 1597 Roter Lowe.. I've had the 1:60 plan at home for many years, it's a copy of a well-known German plan.. The scale is close to fifty, still very detailed and mainly the ship hasn't got much decoration, which I do not dare make yet. I'm leaving 3D aside, I hope paper plans will do.. Right from the first comparison of copies of the two side elevations, I came across different front ligament shapes.. That's also why I decided to create a cardboard half of the hull and check the crossing of the ribs, and then do the plywood frame..
I clamped the last control ropes of the mizen mast sails and the main yards tackle .. Again I have to pause over the functionality of the rigging. Everything works and after tying, "it" doesn't move a bit... Further measurements with harder currency ..
I'm finishing the rigging, most of the control ropes of Mizzen mast sails already tied.. And other ties and rope roles .. A little coin measurement..
Placed Mizzen topgallant sail .. The construction will soon be over, I'm stretching the last ropes and only the stern lantern is to be done..
Congratulations! A beautiful build. Ondras71
- 1,051 replies
- cheerful
- Syren Ship Model Company
Pandora by marsalv - FINISHED - 1:52
Ondras71 replied to marsalv's topic in - Build logs for subjects built 1751 - 1800
Great job of marsalv is badly looking for competition here .. O -
Greetings. Your ship looks beautiful. I inclined to place the yard on the masts equipped with all the blocks, ropes and sails as if they were a real ship, then everything can be adjusted as needed. And I would still think about the strength of the ropes used, the first on your ship are visibly weak .. !! There are tables here, like here: http://www.goldenhind.ru/calc.php
Sails placed on the main mast .. Halyards of the courses .. The last flags to make, the finished heads of roller masts .. Template for the production of snap ..
Thank you Mirabell61. The pursuit of realistic rendering on this scale is really challenging, it doesn't always work out ... The sail control ropes tied to the fasteners, the rope sticks will be placed later.. Placed staysails between the front and the main mast..
Thank you very much S.Coleman, I'd also like to rebuild parts from the beginning of the construction, but a new model will be better ... I used the node to tie the rope according to the Royal Caroline monograph...
Thank you very much Thunder... Blocks to tie the yards to the deck .. Hanged Fore course and fore topsail .. Parral ... Halyards of the courses.. Against the plan I've added additional binding places on the shrouds - cleats..
