rwiederrich
Posts posted by rwiederrich
  1. 22 hours ago, ClipperFan said:
    @rwiederrich that will be quite a lively model depiction! Did you ever resolve the outer fore width of Stag Hound's rear poop deck? Since the central apartment width was 13 feet and fore starboard captain's cabin was 12 feet, I naturally calculated the starboard was an equal 12 feet. That makes the total forward width 27 feet. Does that look right on your deck?
    I think some fudging will need to take place.  My initial measurments.....made the premade fixtures appear too large...but Staghound was a much smaller and sharper vessel then was Glory of the Seas...which I still have rattling around my brain.   Further evaluations will happen after I get the hull planked.
    Rob
  2. On 4/7/2025 at 3:39 AM, ClipperFan said:
    @Rick310 I was able to download all images from the link I shared to my laptop. Since the museum has a policy about not publishing their images without permission, I didn't upload them.
    As with Glory of the Seas...I will be using an image to model my likeness....and I chose this painting.  I plan on modeling her exactly as depicted in the painting,
    How fun.
    Rob
  3. On 4/3/2025 at 11:05 AM, hof00 said:
    Hi All,
    Update:
    Moving on with the build....
    Bowsprit, Chain Stays and Shrouds installed. (I must thank @rwiederrich once again for his input and photos, assisting with placement of Shroud/Stay termination points on the Hull..) (Kit plans were very confusing and not at all logical.)
    This took me two attempts, the first I just could not live with. The Rake of the Bowsprit/Jibboom was not in any way enough.
    I removed everything and started over, reaming out the Bowsprit mounting hole with a rotary tool.
    Second attempt I think much improved. ((The only downside, my grubby fingers on the Copper, not a huge issue, another polish will fix this.
    I have not quite completed this, I have left the Deadeye Lanyards loose at the mo. to enable further tensioning and Jibboom Guys are yet to be installed.
    I can now continue with installing the remainder of various Blocks/Eyebolts on the Deck followed by the remainder of Deck Furniture.
    Cheers....HOF.
    Photos:
    Harry...fine work, however, I don't mean to be a Debbie downer, but your chain guys, port and starboard are too long.  They should terminate on the hull, just in front of the catheads.  Otherwise, the anchor would become fouled in them.  They are behind the Catheads and cross right under the catheads.  Making raising and lowering the anchors very problematic.  Do you see?  Sorry.
    Rob
  4. It's a safe bet to keep this *running* rigging black...to represent the tarring.  It had to be preserved or it would rot. Lanyards were extremely susceptible to rot...being soaked in sea water and generally tightly fit...preventing good air circulation.  When the USS Constitution was recently rerigged...her naval architects chose black rigging for the lanyards , foot ropes and ratlines.  If they concluded it was appropriate...you can too.
    All my clipper builds are rigged with black rigging for these standing fixtures.
    Rob
  5. On 3/21/2025 at 7:31 PM, hof00 said:
    @rwiederrich
    Hi Rob,
    I found the following:
    Flying_Cloud_Bradner_rigging-side-view.graffle
    I think this goes some way to solving my issues.
    Onward and upward perhaps.... 🙂
    Thank you for your continued assistance and awesome photo references!!
    Cheers and Regards,
    Harry.
    Just remember....there are no photos of Flying cloud....just models and speculation.  Duncan McLean describes her hull and deck furniture the best.....however.  The photos I provided of Glory of the Seas...McKay's last clipper
    Must be your best option.  I cannot assume he would have done things differently.  These images are *EVIDENCE*.
    Will you be correcting the kits cutwater and stem to replicate as she was originally built.  Utilizing McKay's secret *Naval Hood* design? Contemporary paintings and models clearly get her bow wrong...simply sticking the figurehead on the stem.  This photograph of Glory of the Seas....depicts McKay's famous *Naval Hood*.  Note the location of the figurehead...on the Hood under the bowsprit!
    Drawing by Clipperfan.
    Rob
  6. 2 hours ago, paul ron said:
    my problem is i have  no sails at all but im including all the rigging as if sails are coming. so all my bunts are in place, but i dont know what to do with the free ends on the spars. do i leave the bunt ropes dangeling, and how do i keep them from droping back? what do they do in real life? the ships ive seen docked without sails have no bunts or blocks on the yards.
    im figuring each bunt must have a couple feet of line dangeling to be hooked to the sails when they get fitted... so in this state with no sails, i plan to make coiled hanks hanging at each block. this will also prevent the ropes from falling back.
    what da ya think?
    Paul...it is acceptable to simple knot the bunt at the block. (blocks are secured to the jackstays, or simply tied off at the yard)  When the bunt line is in use, it is fed down the course of the sail and affixed to the rope edge of the foot of the sail.  When sails are removed...you can simply knot the bunt line at the block...then finish running the line back through the top block and down to its belay point.  You retain the bunt detail without the sail.   Same with the clue lines.  What I did once....to make it easy, was to tie the bunt off to the block eye....then wrap it around the yard, running the bunt back through the sheeve of the block snugging it up against itself and then running the line up to the top blocks
    Hope this helps?
  7. On 3/7/2025 at 5:12 AM, paul ron said:
    it sure does get crowded with a full complement of rigging. ive got a similar problem with bunt lines on a clipper, flying fish 1851 1:96.
    im not putting sails on, but i am trying to put her in a state of readyness, with no sails. i can belay the bunts to their pins, but what to do with the lines at the blocks on the yards? i decided on a solution of putting a bundle at each block so if sails were to be put up, the bunts are ready to be tied on.
    so im watching for your solution because ill be where you are soon with the same question.  🤔
    When I built my Glory of the Seas...I wanted all the rigging to be visible.  Nothing was left off...cept the stunsail booms and their rigging....since they were not present during the period I was basing my build on.
  8. A little bump to the thread. I'm sorry I have been very inactive on this build as of late.....My daughters house purchase fell through....so she and her's are back home. I've been tackling the new roof install on my garage....so that too has held me up. And now its getting to spring...which means loads of yard work and outdoor activities. I hope to get back into the shop and organize my modeling thoughts...once again....soon.
    I hope everyone is having a smooth new year and coming spring.
    Rob
  9. On 1/18/2025 at 1:33 PM, Jared said:
    I am well fixed with all the small tools for rigging.   Thanks.  Having fragile spars being evenly supported is a must when fitting them with eye bolts and the like.  More importantly knowing where both hands are at all times in relation to the pertruding mounted spars is key.
    Sorry for the vary long absence .  family and moving stuff around...takes time.  I'm not all back together again...but getting there.
    I see what you are talking about.  when you drill a hole through a thin mast or yard...the point where you drilled becomes vary thin and fragile.  especially along the edges on either side of the new drilled hole.  this hole make the remaining material very weak and apt to breakage.  What I do in this case is drill the hole.....then...fill the hole with CA glue.  letting it set hard by using an accelerator.  I then redrill out the hole.  The Cured CA strengthens the fibers of the wood on either side of the hole by soaking into the wood fibers and aids in preventing the wood from fracturing again at this point.
    Rob
