jfhealey
About jfhealey
2,300 profile views
  1. I did exactly the same thing. I was able to prise the offending part away with a sharp blade without causing any damage - or at least any damage that was not easily repaired. I had glued the part with CA onto a previously painted surface so I guess there was more limited adhesion than might have been the case had I glued to unpainted wood. I don't think you can leave it in the wrong place - it will surely always bug you and, I suspect, cause more problems down the line. Good luck whatever choice you make.
  2. Fascinaing - and a great deal of thoughtful engineering. I'm following with keen interest. Fred
  3. Fantastic! And please post pictures of the construction of the cover and base. Fred
  4. Welcome back indeed. Have you tried the Syren cap locks on the gub carriages? If not, I highly recommend them. Fred
  5. This is all coming together beautifully. A lovely model of whch you should be very proud. Fred
  6. Faultless work beautifully photographed. The work of a real craftsman. Fred
  7. Your photo sequence suggests its an easy stage - or at least you found it so. I'm with Glenn but with an added helping of hair torn out. Super work. Best wishes Fred
  8. "Bit of a perfectionist" doesn't quite cut the mustard Erik. Superb! Best wishes Fred
  9. Thanks chaps. JJ - it's perhaps not for me to say but a lot of us are following Portland with a keen and anticipatory eye. Perhaps you could alternate - 2 weeks on Portland and a week on Winnie or something like that. Fred
  10. Good afternoon all. Here is an update on my Winnie build. It feels like a significant milestone because at last the bowsprit - that I made such a long time ago - is in. I had to fix it in permanently as I wanted to both glue and peg it to the gundeck and I could not plank the centre of the fo'c'sle until that was done. Here she is in the garden on a rare day when the sun has shone. Two things in the picture below. First I placed railings around the headwork. I guesss there must have been railings. Using the heads without would have been a very precarious occupation - certainly not a place to skive off work for a cigarette break. But should the railing extend all the way back to the main rail I wonder? Secondly I placed a little chock on the outboard end under the boomkin. I appreciate the contemporary model does not have one but had I been the builder (of the real thing) I'd have put one there for support and stability, so my model is getting one. I turned the boomkins incidentally and the bent them with heat. I thought that easier than shaping the Syren parts. Cutting the fancy rail was not a job I looked forward to - but it went ok. I used pins and epoxy for a relly secure fix. I can see my gammoning chocks are too big but I can live with them. One, I suspect, of a litany of historical errors that I shall make with the masting/rigging. Lovely lines fore and aft. I think I will finish up the fo'c'sle area/bow end and then work my way back. In fact there are only a few detail bit and pieces to go. The end of the Syren bit is in sight - the masts are largely made so I hope to see real progress by the year end. Best wishes Fred
