king derelict
Members-
Everything posted by king derelict
Thank you very much OC. I think I can see holes in the curtain wall that may have held the inner ends of beams supporting wooden galleries. I had thought about trying to make some up but I'm not sure I can make the detail fine enough for 1/200. Maybe wire ladders painted to look like wood. I'll see how things look as I get to teh finish line. Alan
Thank you very much EG. There is some great reading material there and a lot of good ideas and techniques. I think this is going to end up as a mix of techniques. I think I will use foam board as the basic structure (and to help out those cardboard piers) and mesh and hydrocal. I think I may invest in a hot wire cutter for the foam board shaping. I'm thinking about ground cover too. The green flock provided in the kit will be ditched along with the blue (not even any water in this one). The landscape is more arid and needs to be yellow green anyway. I'm wondering about static grass but would that be too tall for a 1/200 landscape.? I liked the Woodlands Scenic shaker of grass that I used with the WW1 diorama so I may get another in a yellow colour. Thanks again Alan
This is a nice video of Loarre Castle which illustrates some of the simplifications of the kit. The base should really be sloping over its entirety but I think its a reasonable interpretation. There are a few elements about the castle itself that I'm curious about. The outer wall and turrets don't have battlements of walkways. I wonder if they originally had wooden galleries with ladders and platforms within the towers. The other curiosity is that the outer walls don't fully enclose the towers yet the ground on one side seems to be easy terrain for the enemy to wander around the end of the wall I may have to try modelling the two rock pinnacles as part of the base
I brushed on matte craft varnish which seals the blocks and the mortar mix. It also seems to bring out the colours of the blocks and suddenly the whole thing seems rather better than in its raw state. Suddenly I'm quite pleased with it although the camera picks out a few places that need a bit of further attention. I built up the cardboard piers that the towers will stand on. I've added them to the baseboard but I'm thinking of adding some more support. Aedes Ars have a lot more confidence in the loadbearing capability of cardboard than I do. I might stack a few heavy books on the piers and see how they do for a few days. I added the cardboard formers for the main towers and the keep to get some idea of what is still to do. Some way to go but its getting time to plan the lighting and start thinking about the appropriate media for the landscaping. I'm thinking foam blocks roughly shaped and then covered with hydrocal or Sculptamold as a start. Embed some plaster cast rocks to get the cliff faces. Thanks for looking in and the likes and comments Alan
So here we are. A milestone. The last blocks have been added to the outer walls and some preliminary shaping has started. I think I am going to leave a little roughness in the walls rather than sand them to a completely smooth finish. Looking at photos and videos shows some texture to the walls. Smoothing the inside of the towers is not easy even with the "Socket Sanders" (tm). Luckily they will not be easy to view once the model is complete. At this point I think I'm 2/3 of the way through the blocks so that's 5500 blocks shaped and glued onto the formers. I had a full bottle of Weldbond with a broken nozzle that needed using so that was my initial adhesive. That is now exhausted and I'm halfway down the first bottle of the kit adhesive which I like better. It is a thinner consistency and dries faster than the Weldbond. It seemed a bit like Elmers so I made a small trial with a few blocks and it seems to work well so I may move to that when the kit glue runs out. I may be a bit heavy handed with the glue but AA don't really seem to give you enough. I ran out early in the Rochelle Towers build too. The only other flaw (at least to me and I may be missing something) is the concept of building on a cardboard base. Maybe if you don't move it all around during the build then the completed model has enough integral strength to hold itself together but that seems a risky prospect especially with this one where the parts are distributed over a large area. There are few builds out there to reference so I am happier using a sheet of plywood. I hope to finish the shaping tomorrow and add a coat of matte sealant to bring up the colour a little and seal the block surfaces. I am going to take a short break after that and work on a couple of short plastic builds which means I can move out of the garage and back under air conditioning. I was miserable out there this afternoon. That may be an issue with airbrushing out there too. Thank you all for teh support and the likes and comments Alan
Thank you very much OC. Your Waterloo build is an inspiration. The stone look is one of the strong points of the Aedes Ars models even is some of the details are simplified and the blocks are really too big for the scale. Once finished I don't think it will be too obvious and this one doesn't have fiddly battlements which would look out of scale. I think figures are going to be a must. To add colour and a sense of scale. I have enough figures from Pendraken so a skirmish is definitely possible. I'm looking at a lot of photos trying to get a sense of how it looked in the medieval period. Alan
I've managed to spend a bit more time adding blacks and suddenly I seem to be getting close to the end of the outer walls. I've really only got the upper half of the last tower and the wall to be done - and then lots of sanding and filing to get final shapes and smooth the walls down. I'm trying to decide how rough to leave the walls. It's an 11th century construction so a perfect smooth finish seems inappropriate. I had a peek at the instructions (well more of a simple guide really) and it shows the last wall covered in blocks all the way to the base. I had already started on mirroring the outside by then and I confirmed the hill contours are the same on the inside of the walls as the outside so it just seems a waste of blocks. Maybe it adds a bit of stability to the card former but I had been thinking of adding a support along the bottom of the wall from scrap wood or foam anyway. I hope the next photos will show the finished walls and then a clean up of the bench is in order. The remaining stock of blocks is looking a bit better than I thought so I'm hopeful I'm not going to run out. Thanks for looking in and the comments and likes Have a great weekend all Alan
Thanks Craig Crawling down the aluminium inlet ducts in the afternoon dressed in a Tyvek bunny suit to do fan inspections has been a bit of a trial lately. It will be great to not be doing it in August. I'm definitely enjoying being back at the work bench and with the end of the walls in sight the enthusiasm is high. Alan
A bit of backward progress first. The camera has a great knack of pointing out defects. After looking at the photos I wasn't happy with the walls to the left of the gate. I hadn't set a block down carefully enough and it had caused the tiers of the wall to sag down in the middle and the wall on the far left had a block on the bottom row that I hadn't smoothed enough and that was affecting the subsequent layers. So it has all been torn down and rebuilt and I think looks better. The glue holds well but does allow painless disassembly; just need to remove the glue residue. After sorting all that out work progressed pretty well. I have started building up the last tower above the template that indicates the level the landscape will come up to. There are a few more sessions needed but the end feels like its in sight and enthusiasm is still high. I'm starting to think that I will take a break once the outer walls are complete. Maybe work on a couple of small 1/72 aircraft as a change in pace and then come back to the towers and landscape. That feels like a natural breakpoint and a chance to clean toe garage work bench up from all the dust that's been made so far Thanks for all the support and likes. Hopefully some steady progress this week. Alan
Yesterday P+W authorised pulling the engine for a couple of months maintenance so apart from a few hours here and there tying up loose ends I'm resigning from the real world for a while. Today felt like that first day of the long summer school holiday. Scrub the shower? Weed the garden? Wash the car? No, I decided that it was time to spend a while with Castillo Loarre. I managed to lay don a decent number of blocks and the towers are slowly filling up. I've found its actually quicker to file the blocks for the round sections by hand instead of using the angled piece of the shooting board. There's quite a bit of sanding and tidying up ahead and the pictures look a bit ugly because I've painted on a mortar mix from the sanding dust in some places A little thinking ahead would have been helpful. I should have photocopied the printed formers for the section of the walls that will be disappearing into the landscape and used it as a guide on the inside of the wall. Instead I used the outside wall as a guide and created a set of patterns They don't really need to be exact because the landscape will cover the first row of blocks. I made the patterns out of thin card and I hope the edge will help locate the first rows of blocks in place somewhat positively. The patterns were glued in place and it is a bit of a morale boost to realise that only about half the last wall need to be covered. Shame that last tower is so high Thanks for looking in and all the support. Some fun stuff around the corner. Lighting the main tower should be interesting. I have never done anything like that and will be looking for tips. I plan to use yellow flickering leds but have to work out how to mount them and route the wiring off the model. I hope everyone has a great weekend Alan
