king derelict
Members-
Everything posted by king derelict
Absolutely beautiful work. Its a stunning model. The crew makes it stand out but I think the wonderfully realistic sails make this a spectacular boat. Congratulations Alan
- 206 replies
- Vanguard Models
- Brixham trawler
US 6” gun by RGL - FINISHED - Panzer Concepts
king derelict replied to RGL's topic in Non-ship/categorised builds
I really like a lot of the subjects that Rosen produce and I have build some of their 1/72 kits. Some detail is excellent but in other areas flash is horrible and swamps the part Alan -
Sorry for the dolorous progress. Real like has been intruding badly these last days. Partly its self inflicted. I was asked to come back and consult for a couple of engine tests and I (possibly foolishly) agreed. It will keep the wolf a few paces away from the door and doubtless improve sales at Sprue brothers et al. Its also good to hear the howl of an F135 at full throttle again Anyway, in quiet hours some progress has been made and the outer faces of the walls have been finished Now I have to turn it around and do it all over again on the inside. Some of the blockwork on the inside of the towers is going to be interesting.. I had planned to take a break at this point but I'm enjoying it too much and playing with engines will provide enough diversion so I'll try to keep going. Its going to be slow though so get comfy and lay in plenty of snacks and adult beverages Thanks for all the support, likes and comments Alan
Gators Grip and the similar product from Mig Ammo have similar properties. They give you time to get a good placement of the PE. They also dry with some flexibility which means the part doesn't break off as easily as when glued with .CA which is brittle. I like the GG thin version best. Alan
In my flow of build I end up painting the main deck before painting the superstructure so I tend to 1 assemble hull, deck and main structure elements 2 Prime 3 paint the main deck 4 Mask the main deck 5 paint hull and structures if they are the same colour 6 Mask hull and paint structures if they are different 7 Add details and touch up. I'm not claiming this is the most efficient way but it works for me Alan
This is going to be spectacular Alan -
I still slowly grinding (literally) away at the outer walls. As usual nothing much got done at the weekend but I got some useful time in today. It still moves along fairly slowly because I think its worth letting a tier set before trying to sand back level and risking knocking off a couple of blocks and having to do it all over again. I turned the last corner and am on the last tower and section of wall This is where the hill will climb up the wall And the panorama showing the completed work so far. Our nice post lady brought a package from the UK this morning The 10mm Pendraken medieval figures. They are really beautiful and I think they will work well. Thank you @Old Collingwood for the suggestion. They have a medieval cannon set too so I am considering a couple. I'm still a bit concerned about @Egilmanhowitzer Painting them is going to be interesting I think we will be going for *overall effect* Does anyone know how to prime metal figures? I have the Mr Metal Primer for PE so I am planning on using that Some thought is going to have to be given to adding them to the model. They are too small to really remove from their bases so maybe I can thin the base down. Thanks for looking in, all the likes and comments. Alan .
I never got on well with my Tamiya PE pliers. The jaws quickly went out of alignment. Possibly it was just a dud pair. The magnifiers with light are a big help to me. I tend to stick the hull to something that I can hold to minimise handling of the model. I use a piece of plastic packing material liberated from work and double sided tape. Others use paint bottle tops and blu tack. There is a big deep hole of tools that you can throw money into Alan
Wonderfully busy decks. Great stuff Alan
- 200 replies
- Transport No. 103
- Hasegawa
(and 4 more)
Sorry. Autocorrect insists that PE should be OR and I missed a couple in my reply. For me the key to PE is planning the sequence of bends so you can access the area to bend as needed Good luck Alan
