king derelict
Members-
Everything posted by king derelict
Thanks for hanging around for this one Edward. Yes, once a section is finished it will get a pretty vigorous sanding. That will smooth the walls, clean up the corners and make the round towers circular. The blocks sand easily and there is a lot of depth to go at with these 5mm blocks. If there are still gaps a mix of diluted white glue and the sanding dust will sort out most problems. The last resort is some artfully placed ivy The blocks are somewhat irregular and the guide recommends squaring up each block. Given that there are 8600 blocks and I have a limited ability to true up anything I use them as is. I find that selecting adjacent blocks and rotating them to get the best fit gives a good result generally. I do sand each layer to make sure the following layer doesn't start to slope or meet steps between the blocks. Alan
The formers for the outer walls were completed So now the brickwork begins> this is probably the first hundred - only 8500 to go. The flat and right angled sections of wall should go fairly quickly but the circular towers will need each block to be filed to shaped and fitted. The photo shows a couple of dodgy blocks on the top tier at left which have been removed and refitted properly. I do need some better lights for working on the work bench in the garage so off to Amazon next. Thank you all for looking in and for supporting this build Alan
Thank you Mark These builds can be a bit of a grind and its easy to get discouraged. There are few builds out on the internet full stop, but Aedes Ars seem to be flourishing and have been increasing their range of models. Some very impressive models in their catalogue. They are a bit of an oddity in some ways. The blocks are not scale for a lot of the overall model scales and windows and doors are often out of scale because of the limitations of the block sizes. Having said that the magnificent work done by @Ekis shows what can be done Alan
Thank you very much OC. That is really very handy. The instructions are more of a guide and do not show images all the way round the model. The formers at the one edge of the outer wall suggest that the brickwork only covers the upper section of the wall I'm guessing that the hillside rises there to join the inner walls and structures but there are no pictures of that side of the model. It may become more apparent as the other structures are added but I will be looking at a lot of pictures of the real thing too Thanks again Alan
Beautiful work. The detail, nets, fish boxes really pop Alan
- 206 replies
- Vanguard Models
- Brixham trawler
Magnificent work. The hoist rigging is so very good and the deck is much nicer after the wash Alan
- 200 replies
- Transport No. 103
- Hasegawa
(and 4 more)
Well, possibly an ill judged foray into something different. This is the Aedes Ars kit to build the Castle Loarre in Spain out of individual ceramic blocks. All 8600 of them. I built the Towers of Rochelle by the same kit manufacturer a while ago and although there were some caveats about the scale of some elements it looked decent when I finished it. A great friend of mine sent me this kit (and paid postage all the way from Spain) a couple of years ago and I am ashamed to say it has languished. I found I got bogged down in the Rochelle build. In that kit there is a large multi-curved tower that used about 80 blocks per tier and it seemed like in spite of the hours working on it, it felt like it was going nowhere, I'm hoping that this one might go better having a widen array of smaller elements but 2000 more blocks. I suspect there will be regular breaks to play with something less demanding. Inside the box, plans and general guides. Some basic landscape elements which will be ditched in favour of the Woodlands Scenics investment for the howitzer diorama. Lots and Lots of blocks The kit is built on a printed cardboard base which I decided to glue to a piece of 3/4 plywood. The finished kit is going to be heavy and a piece of cardboard as a base is not going to do it. The structures are created by building up the walls against card formers. These are die cut and just need easing out of the frames The kit provides lengths of scored card strips to create tabs to glue the formers together and to the base. The kit provides two bottles of glue which is unlikely to be enough. I switch to Weldbond when it runs out. A syringe is an efficient way to dispense the glue The curved sections of walls and towers require the formers to be curved. ts easy to crease and ditort the card but using the PE rollers produced decent results A variety of heavy things are used to hold the sections down until the glue sets up. And the first section of wall formers are up This may get very boring so I will only update at intervals when there is discernable progress. I'm hoping that with a bit of community spirit I can complete this without getting overburdened. I hope you enjoy watching it come together. There is one outstanding question - where will the completed model go. The base is 26 inches by 22 inches. Oh dear! Thanks for looking in Alan
Thats a great question. I am finishing off a few small models and experiments which probably don't warrant showing here - unless they are tremendously good of course, ! have a long-term project I want to start in the next few days that will be in this forum. In parallel I want to do something a bit shorter but can't decide between the Vampire, Typhoon, a 1/35 AFV, a 120mm figure or a 1/700 ship. I have a 1/350 Flower corvette that I want to make into a diorama but That might depend on the current experiments Alan
