king derelict
Members-
Everything posted by king derelict
Absolutely beautiful work on the masts. alan
- 127 replies
- Mikasa
- Merit International
Nice modification and it came out really well. I always get nervous cutting into stuff like that. alan
I found a little courage this morning and cut the plastic supports off two of the platforms and added the tiny photo etch parts. It took all day to build them up with a few diversions to find the little triangles after they flicked off the tweezers. Oh and a three hour power cut. At the end of the day they came out okay but I’m not sure it justifies the work. There is one more to do but I’m thinking of passing on it and moving forward with some primer. Thanks for looking in, the likes and comments. alan
Slow progress but plenty going on. I completed all the barbette doors and added the barbettes. In hindsight I should have installed the barbettes first and then added the photo etch doors over the top. Doing it the other way around meant it was difficult to line up the gun barrel and the locating features of the barbettes. However, given that the doors completely mask the barbettes the gun barrels can just be poked through the hole in the door and glued in place without bothering with the barbettes. So far I haven’t found a downside to this thought. You have to use the brass barrels with the doors, the plastic ones are too thick. With the guns sorted out I glued the roof in place and this bit is ready for some primer. one reason things are moving slowly is the need to keep assessing how far to go before priming and painting. I started building some of the superstructure subassemblies. Photo etch needs to be added, some like railings, ladders are a good thing but other bits really don’t add much detail and feel like PE for PE sake. I’m brooding over whether to replace the plastic support for the platforms with the PE. These are parts 38 on the fret. The plastic supports are over scale but are probably neater than I can achieve and I don’t see anyone turning up with calipers to get difficult about it. I’ll decide in the morning. Thanks for looking in, the likes and comments Alan
This has seemed a massively complex model from the start and it’s been inspiring watching you knock down the challenges one by one. I know that feeling when dry fitting damages stuff you already did. I usually find having successfully dry fitted a part as soon as I apply glue somehow everything changes and it won’t fit. I think MFH will go on the list of kits to admire watching others build but stay well clear of myself. I class you as one of the heroes of this site. I’m the kid in the corner eating the glue. alan
The first hesitant steps into the build. The hull halves have been fitted to the waterline base. It took a bit of fiddling to get the two halves lined up properly on the base but by gluing the bows together and then inserting the base and gluing it up a short length at a time it went together fine and everything fitted together without gaps. I’ve spent a fair amount of time working out the most effective build sequence. While I have been pondering I decided to tackle the metal gun barrels. I always get a bit nervous about this step. I find it hard to get the barrels correctly aligned after adding the metal ones. The plastic ones look quite good until you look at the brass ones so I took a deep breath and started snipping off the plastic ones. The 13.5 inch guns went quite well. A plastic barrel is shown for comparison So I contemplated the barbette guns. Again the metal does look better so I did some irretrievable snipping I used a dressmakers pin to mark the spot to drill and stop the drill skipping and after a few pin pricks I got them done. There are six flavors of barbette guns hence the numbered spots on the double sided tape. The brass barrel and the plastic ones are shown by the knife blade. I decided that was the limit of my skill for this and decided to leave the 3 pounders well alone. They are tiny. The plastic parts are numbers 4 and 5 on the sprue and the brass barrels are in the plastic bag. The triangle at top left is the tip of a #11 blade. first photo etch has been added. The doors for the barbettes are provided in two versions. I’m not sure quite what the difference is between them but the first one was duly added Both sides are now complete and I added the first barbette It does look nice enough to justify the extra work. Slowly forward is going to be the nature of this build. Thanks for looking in, the likes and all the kind comments. Alan
Thank you OC. I think this will be quite a long build so I hope you enjoy it. The plastic details are lovely. The judgement will be with using the PE, the plastic is already quite good. At least this kit has the option to drop back to the plastic if the PE gets too difficult. With Derfflinger there was no alternative to the PE. So this kit has the PE instructions separately so you have to read two sets of instructions in parallel. I think I’m going to build up as much PE as I can before assembling the major elements. alan
The potential for another brush with insanity. Another wonderful Flyhawk kit with lots of tiny details and extensive photo etch. The kit comes with photo etch, metal gun barrels and some brass rod for the masts and some resin bollards. The box is nicely packed with a lot of material and an illustrated card with a summary of the ship’s career. I added the wooden deck but I think I will see if I can pull off a decent painted version first. It removes the long term worry about the wooden decks lifting at a later stage. The photo etch is comprehensive and intricate. I’m not sure how much I will use. Some of the plastic pieces are well detailed and delicate and also have a better sense of three dimensions. Similarly the metal gun barrels. The metal barrels for the 13.5 inch and the 6 inch will definitely be used. I’m not so sure about the 3 inch and 3 pounder ones. There looks like there will be plenty of areas to work on. The plastic is the usual Flyhawk crisply molded dark grey plastic. This should be a lot of fun. Thanks for looking in. Alan
I’m finding it challenging to build and display my larger kits. Initially I thought I would settle on 1/350 ships but I find them unwieldy on the workbench and my vision problems make it hard to work on the model without damaging other parts of it. So, ive decided to sell off my collection of 1/350 kits and other model kits that are going to pose a problem for me. All kits are not started with parts still bagged. The box has be opened to check condition Trumpeter 1/350 HMS Queen Elizabeth 1943 #05324. Comes with White Ensign PE #3510 and Art Wox wooden deck #10055. Total price $130 Trumpeter 1/350 USS Forrest Sherman DDG-98 #04528 $30 Trumpeter 1/350 HMS Dreadnought 1907 #05328 with Eduard PE railings # 53094 $50 Amodel 1/72 Be-10 Mallow #72329 $50 Modelsvit 1/72 Tu-22KDP #72046 $65 Buyer is to pay via Paypal goods and services. Shipping costs will be actual USPS cost. If you want this deal, PM me your complete mailing address so I can quote you the shipping price. I can ship to the continental USA only. If we agree on a sale, I will send you a Paypal invoice.
