AlanDavison
Everything posted by AlanDavison
  1. I note that the union flag includes the cross of St. Patrick which was added to the flag in 1801. Is this appropriate for Surprise which I believe was sold out of service in 1802?
  2. Another thing as well. Most ships boats had masts and sails as well as oars. But masts and sales are seldom included in kit form. Something to be considered in future kits?
  3. When a sea and not in action, all gun ports would be closed, gun quoins would be removed and canon and carriage lashed securely to the bulwark to prevent movement. Models are nearly always shown with canons run out as this enhances the appearance of the model. As an aside ships boats were often towed, especially when the ship was in action as it reduced the possibility of desertion or splinter injuries.
  4. The manger, as the name suggests, is where the live animals were kept
  5. There is a full size pattern on one of the plans showing the Checker pattern in black and white. I just cut it out, trimmed it a bit and stuck it over the engraved patten! Ever so easy
  6. Hi Allen, my best suggestion is for you to google “carronade” on Wikipedia, you will find all that you need to know, including plans & pictures. Also on this site you can find a very long (500+pages) on smooth bore canons. Happy researching
  7. Cor blimey what a tidy work station. I’ve just declutter mine and it’s still a mess!
  8. The long bolt at the front (muzzle) is the pivot, the gun can be moved left or right aided by the wheels at the back. the short bolt, ties the spacer,(middle timber) to the base. The gun is elevated/ depressed using the rear screw device. I this instance the bed would have extended out over the gun port cill and fixed to it. This is not shown in the diagram.
  9. Chris, From something I recently read, these gun brigs were rowed when inshore in shallow water. Perhaps the tiller was used to steer when rowing? The wheel being used when under sail in deeper water and using the drop boards. You might consider providing a set of oars in the kit, as this would make an interesting display, what do you think?
  10. A intriguing layout. The 24 pounders look as though they would be difficult to control, especially as the breaching ropes either side of the gun would have to be of such different lengths. I can see the gun slewing all over the place when recoiling. Might not the guns be mounted on rails or sledges to stop this?
  11. I read somewhere that the breaching rope should be three times the length of the gun. Seems right to me!
  12. You may be interested in a Seaforth publication called ‘German Naval Camouflage’ published in two volumes, volume one looks at the period 1939-1941 and includes detailed colour schemes for Bismarck. Volume two covers the period 1942-1945. The books are an excellent reference and study of German warship colours and camouflage and are well worth reading. Incidentally, in response to Joe100’s comment about grey boot strips, according to the Seacraft authors, Bismarcks boot topping was actually black at the time of its sinking (see p9 of vol 1)
  13. Always best to prime before applying top coat as it (a) shows any imperfections in surface finish which can be remedied and (b) gives a good foundation for your top coat. There are lots of surface primers out there mostly in spray rattle cans.
  14. But most importantly we’re here for the enjoyment and fulfillment of our hobby, be it plastic, wood, metal, ship, aircraft, tank or vehicle
  15. You might find what you are looking for from David J Parkin who is in the Uk. He does a range of 1/72 scale fillings for the Revell Flower class corvette in a range called Great Little Ships. Among the range are sets of 3 & 4 rail stanchions in white metal, they can be a little fragile but are nevertheless quite usable. Hattons on line mail order model shop also stock the range. hope this helps
  16. You can order with confidence from them. Also look at the Safeway site, they have a range of sailing ship fixtures & fittings from various 3D printers which you may find useful
  17. In response to James H’s earlier post, I thought one of the points of this site was for Chis to discuss the future and existing development of his range with member and to gauge their responses, that will inevitably end up something of a ‘wish list’, but it does help Chris to take into account modelers likes and dislikes and that in turn helps him to plan future projects which he can be confident in selling.
  18. Obviously you are a highly skilled model maker as you finishing is of the highest standard. It’s just a pity that you have chosen such a poor example of a an eighteen century warship. Would love to see what you could do with one of the kits in the new Vanguard models range👏👏
  19. Looking very good. Regarding decals, it is usual practice to apply a coat of gloss varnish over the whole model as this means you can slide the decals around for fine adjustment before final fixing . Johnson’s clear (yes the floor polish) or it’s equivalent is often used. Also consider using a Decal softener and fixative so that the decals follow the surface contours. After all that you then apply your final coat of Matt or semi-Matt varnish to tone down the gloss. Weathering using powders, oils and so can also be added if you want a ‘used’ look
  20. Lightest colour first, darkest colour last is my mantra. So brown, green, black
  21. I align the steps both horizontally and vertically using fine pencil guide lines then glue with PVA wood glue or Super-‘Phaltic glue. For the channels I drill and pin the channel, offer the channel to the hull, mark the pin positions then drill and glue with PVA. I can’t use superglue as an allergic to it, but apart from that I think superglue dries too hard and is not able to accommodate any slight movement in the wood and ends up cracking. I also use Super-Phaltic for attaching PE parts to the model Alan
