Everything posted by CPDDET
Welcome to MSW. Start a build log so we can all follow along.
Thanks for moving your notes to this build log. I will be following it closely
- 96 replies
- model shipways
- bluenose
If you go the route of the cradles as I did, let me know. Using the contour gauge for this purpose is a bit tricky. I'll pass along some tips.
- 389 replies
- bluenose
- model shipways
Welcome! You will find friendly people here and lots of help.
The first challenge was to figure out how to flip the ship over so I could design the cradle. Luckily I had a piece of balsa wood that was spongy enough to friction fit in the mast mounts. Then just mounted the ship upside down in the keel vice. Since I made the error of not prepping the keel/hull for mounting bolts I decided to use dowels to strengthen the cradle assembly. Using a profile gauge, I managed to copy the hull in two places and make cradles out of basswood. Then test fit the cradles on the hull. Using double stick tape, I mounted the basswood cradles on the walnut base and double checked the fit. Picked up a piece of walnut and used the basswood pieces as a pattern to mark the walnut and cut them on the scroll saw. Then drilled holes in both the base and cradle pieces I glued wood dowels into the base and glued the cradle pieces to these Then drilled holes in the base of the cradle pieces to accept dowels that I glued into the keel Then put 3 coats of wipe on poly on the finished piece. Now it’s on to the bow sprit.
- 389 replies
- bluenose
- model shipways
Looking for a good "starter" pin vise set
CPDDET replied to Capella's topic in Modeling tools and Workshop Equipment
If your going to stay with this hobby don't buy tools till you need them and then buy the best you can afford. This is the advice I got years ago and it's done well by me. -
Repainting the hull went pretty smoothly. I used larger pieces of tracing paper and blue painters tape for masking. Then used my airbrush to repaint. I decided not to extend the yellow stripe over the chainplates as I wanted this detail to stand out a bit. Did a little brush work on the chainplates to finish them up, so that part of the build is now finished. I had planned on moving to the bow sprit next but decided that now was the time to get the ship mounted to a base. I already had a nice walnut base and brass standoffs but, do to ANOTHER beginners error, I neve prepped the keel / hull for mounting nuts / screws. So I've decided to build some type of cradle for the model. Going to have to get creative here as I need to secure the ship upside down to work on this step. Ill keep you all posted as that progresses.
- 389 replies
- bluenose
- model shipways
I will add that Sherline customer service is very good. But again, I'm not familiar with Proxxon so can't comment on theirs. It may be just as good.
You might want to compare the available accessories from Sherline and Proxxon. Don't know much about Proxxon but Sherline has a wide range of accessories for it's mill. I find the Sherline sensitive drilling attachment very useful, among others.
I have a Sherline and have been very pleased with both the quality of the mill, variety of available add-ons and great customer service.
Installed the starboard side chainplates today. I used the 3 tools pictured here: a 1/32 drill bit mounted in a pin vice, a #11 knife and a 1/32 PCB drill bit. I received a set of the PCB drill bits for Christmas but haven't used them much as they seem to screw themselves into material rather than drilling a hole and clearing the shavings as a regular drill bit does. If you look closely your can see the difference between the bit in the pin vice and the PCB bit. While I'm not familiar with the correct names of drill bit parts, the PCB bit is more like a screw. But I found it works rather well when used as a file in this application to elongate the drilled holes. I started out by drilling 1/32 holes for each of the 5 chainplates and then used the PCB bit and #11 blade to elongate them. Wanting a strong bond to the hull, I sanded off a section of paint so that the chainplates would adhere directly to the wood instead of the paint. I used CA to attach the chainplates to the hull and added some small nails to simulate bolts. These small nail heads probable won't be very visible once painted but I thought they were a nice detail, even if only I know that they are there. This is the forward starboard side. This is the aft starboard side where I had to be a bit more precise with my drilling. The slot for the chainplate needed to go through the monkey rail, stay on the outboard side of the the monkey board and then through the main rail. Once I finish up the port side I will re-paint the hull.
- 389 replies
- bluenose
- model shipways
Took forever but all the chainplates are finished and ready to install. Now just have to work up the courage to mark the locations and start drilling the holes for them.
- 389 replies
- bluenose
- model shipways
You will often hear most people on this site say, "Buy the best tools you can afford". And I agree. If this is going to be a long time hobby for you, I can recommend a pin vice set by Starrett. Not cheap but very well made and sould last you a lifetime. -
I find a good bourbon worked wonders. 🤪
- 389 replies
- bluenose
- model shipways
