LEGION 12
Posts posted by LEGION 12
1 minute ago, lmagna said:
I would think given the time period that it was possibly a local gun control range finder for either that turret or possibly both of them.
Given the way the two turrets are aimed it looks like it is not working all that well either.
Lol...
- mtaylor, popeye the sailor and Canute
- 3
- Canute, mtaylor, Old Collingwood and 1 other
- 4
- Roger Pellett, mtaylor, thibaultron and 1 other
- 4
- cog, Old Collingwood, lmagna and 3 others
- 6
Thanks guys very helpful .
- mtaylor, Canute and popeye the sailor
- 3
10 minutes ago, cog said:
How many rudders, 2 .. 3
I would expect the rudders' positions would be in line with axle/shaft of the respective propellors, or the number of rudders is less than the number of props ...
P.s. I tend to forget picies too, but then I edit the post so it doesn't show
- popeye the sailor, Canute, lmagna and 2 others
- 5
Have little filling and sanding to do yet to do in hindsight should have dry fitted the prop housings before I glued them . I would like to drill the holes for the rudders before I prime and paint , the instructions are no help any advice ? 😟
- popeye the sailor, Canute, lmagna and 1 other
- 4
11 hours ago, RGL said:
Are you going to scribe the hull?
Yes sir I will be doing that soon .
- Canute, cog, Old Collingwood and 2 others
- 5
- cog, mtaylor, Old Collingwood and 3 others
- 6
Just now, cog said:
get a thin quick drying, and a thicker slightly sower drying CA. Gorilla, Zap CA, BSI insta-cure/maxi-cure. For the kit's parts I use a glue for plastic. Personally I prefer a brush as applicator for the latter, and use a metal rod for the CA
I already have some gorilla glue I will gave it a shot.
5 minutes ago, cog said:
Interesting ... as RGL, Canute, and I are going to build the SMS Seydlitz as a kind of group build, it's older but smaller sister.
If you want to add detail to her, I would certainly try the PE. It also gives you a lot more building time. These ships do not have the numerous AA gun's which are hard to build when starting with PE ,so it should be a good starting point for your first encounter with it. I'll be following along with your endeavours to recreate her
Ordered the PE kit today now to choose a glue .
- mtaylor, Canute, popeye the sailor and 2 others
- 5
SMS Markgraf by LEGION 12 - ICM Models - 1/350 Scale - PLASTIC
Shading ? They are painted mounts are next .
