LEGION 12
Posts posted by LEGION 12
8 minutes ago, Gregory said:
The only thing you could do besides doing it over, would be to add some shim material to the bulkheads..
Thanks for the quick reply , I was thinking the same thing the first plank is glued to the stringers , if I sand the bulkheads wouldn't that throw everything off even more ? Not really sure how this even happened .
Building the Dumas sub chaser , for some reason the planks aren't contacting the last two bulkheads at the transom . Was told I should of faired the frames but it's only the last two . Any way to fix this without removing the planks ?
Just now, DARIVS ARCHITECTVS said:
I think he may be talking about balsa filling blocks, not planking. Blocks of balsa glued between the frames and shaped to the hull form. Planking over the top of all that makes for smooth curves and no hard bends (creating a fold line at a frame) or flat spots.
Oh the stringers are basswood still kinda new to all this .
- mtaylor and Chuck Seiler
- 2
1 hour ago, Chuck Seiler said:
I will try the balsa that came with the kit if I have any problems with it I will try and find some basswood . The pic you posted would leave no room for the stuffing box that has to go through the keel .
- Chuck Seiler and mtaylor
- 2
Finished keel and frames .
- Keithbrad80, amateur and mtaylor
- 3
I figured it out guess I just froze .
I have to cut the rear keel section to fit the front perhaps ?
Hi all building the Dumas sub chaser didn't get very far before I ran into a little problem , not sure how the rear center keel and the forward keel section go together ? All it says in the instructions is , cut and shape the necessary ends of each strip shown on the full size drawing where the stuffing box will go .
- Jack12477, Old Collingwood, mtaylor and 2 others
- 5
- Old Collingwood, mtaylor, lmagna and 3 others
- 6
59 minutes ago, Jack12477 said:
Toms ModelWorks makes a PE kit for The Sullivans, MegaHobbies carries them
Sadly it's already half built or I would of bought one.
- mtaylor, Canute, popeye the sailor and 1 other
- 4
Holy smokes I have the model The Sullivans by Trumpeter same scale but with no PE parts sure it won't hold a candle to yours .
- mtaylor, popeye the sailor, Piet and 3 others
- 6
- Canute, popeye the sailor, ScottRC and 7 others
- 10
- Canute, BETAQDAVE, thibaultron and 1 other
- 4
SC-1 by LEGION 12 - Dumas - 1/35 Scale - Sub Chaser
This is my first wood build I've only built plastic ships before , I have already built the keel and the bulkheads and in the process of planking which is where I started having problems .
