Posts posted by jpalmer1970
I sometimes use a fly tying vise for some rigging procedures. It looks like this vise has an adjustment nut that will rotate in and out. This allows you to use larger or smaller hooks- if you are tying flies. Depending upon where you have the nut set, when you lock the lever in place the jaws will either close or be slightly open or wider open. You therefore control how closed the jaws are by rotating the nut to the appropriate place - with a bit of trial and error.
Hope that helps.
Great work Thukydides. I've still got 6 planks left to add each side in my second planking so you have moved ahead of where I am now. I look forward to following in your footsteps.
Hi Bob,
Drilling pilot holes of a slightly smaller diameter than the pin just makes it easier to insert the pins and minimises the risk of me pushing too hard and breaking things 🙂
- Thukydides, Peanut6, Rik Thistle and 5 others
8
I just use some map pins with an offcut of the first planking skewered on it to provide a bit protection against the second layer. I drill a run of holes in the first planking so that the pins then hold down the second layer.
I just wouldn't trust myself to get the plank in the correct place with CA and not make a mess. It sounds like you are doing well now though.
- Obormotov, BobG, GrandpaPhil and 3 others
6
Thukydides and Phill, I'm also working on the 2nd planking and had planned to thin down part 76 to match the thickness of the wale.
- Obormotov, PhillH and Thukydides
3
It's looking really good Phill.
1 hour ago, Thukydides said:
However I suppose it doesn't really matter, just will result in more sanding :).
I guess that is one of the benefits of working with wood - it easy easy to adapt things 😀
- Obormotov and Thukydides
2
When you get down to the keel area I would suggest you leave your run of planking short of the deadwood area. I planked all the way to the stern and even though I had thinned the false keel originally I basically had to sand the ends of the planks away to get them to be thin enough once the second layer is added. It doesn't say it in the manual but if you look carefully at the top left picture on p20 you can see where the run of planks in the first layer ends short of the stern.
2
Well done. Good fairing is key for making the planking go as easily as possible. I spent a lot more time fairing this model than I did on my first build and it made a big difference with the planking process.
- Chuck Seiler, Thukydides and Obormotov
3
32 minutes ago, Thukydides said:
Do you have a build log going?
No sorry. I'm not sure I'm competent enough at either the building of the model or the writing about it to tackle a build log yet!
- Obormotov and killickthere
2
Good luck with the build. I'm in the middle of making mine and have found the instruction manual to be very very helpful!
- Obormotov, Eurus and Thukydides
2
1
Well done. Awesome work and a great build log for us just starting out to follow!
Thanks for this log - it is going to be really helpful for me in the future.
- VTHokiEE and Old Collingwood
2
HMB Endeavour's Longboat by Fallguy - Artesania Latina - 1:50 - first build
Welcome ! This was my choice for a first build as well. It is a nice little model and will allow you to pick up some skills. Just be aware that because it is an open boat you can see the inside of your planking so make sure you take your time to make it as neat as you can.
