Posts posted by jpalmer1970
It looks like you are off to a good start. I hope the fairing is going well. I'm just starting the rigging on my model and I have enjoyed every minute of the construction so far - it is a great kit👍
Absolutely awesome.
- druxey, Ryland Craze, Edwardkenway and 2 others
5
Welcome! 😃
- Dave_E, MangoFox, Edwardkenway and 2 others
5
Hello and welcome. Hobbytools.com.au sell some Model Shipway kits so it might be worth checking them out. They are based in Victoria. There is also modellerscentral.com an online store based in NSW. They have a wide range of kits and accessories from a good selection of different overseas companies so getting an kit from a store based here might be an easier way around the international postage and customs thing? It may not be the cheapest way though...?
- Peanut6, Fernando E, mtaylor and 1 other
4
Looking very good Thukydides. I also bought the serving machine to use on this build so I'll be interested to see how you go with it. 👍
- Obormotov and Thukydides
2
The hull painting looks great to me 👍I hope mine turns out so well!
2
Hi Thukydides,
Looking forward to hearing more about the painting process. I have seen that some people on the forum don't apply WOP to hulls before painting and others do..... what are the pros and cons of either way? I guess the WOP seals the wood to an extent??
Thanks
- Thukydides and Obormotov
2
That is great looking work PhillH and a useful detailed explanation of your thinking and processes.
1 hour ago, Thukydides said:
Maybe my problem with the bending was I was using a wider stock because I was thinking I needed it to go under the inner bulworks.
That could be it. I was only using the kit supplied planks and so the margin planks wouldn't be deep enough to cut the joggles in easily if I had had tucked them under the bulwarks - at least that was my thinking.
2
Hi Thukydides,
Great painting! I planked the inner bulwarks and painted them before installing my margin planks. The bulwarks may need a bit of a paint touch up when the deck is finally finished but that will hopefully be easier than painting the whole lot later. I am also considering adding a line of spirketting too if I can source some suitable wood.
2
This is incredibly fantastic work and very inspirational ! I look forward to following the rest of your build 👍
3 hours ago, BobG said:
Will you be building your Pen Duick from scratch or from the Artesania Latina kit?
Hi Bob, Yes it is the AL kit. It is this year's Xmas present but it will be a while before I get started on it. I'll be borrowing heavily from your build log and those others on here given how sparse the AL instructions are. I'll get a copy of the rigging book by John Leather and maybe Leo will even have more helpful information about the TallyHo in his rebuild videos.
- BobG, mtaylor and Keith Black
3
That was great. I'll certainly have a look at the other videos on that channel as I think they may be very helpful in understanding a lot more about my next build, the Pen Duick
Thanks for the link.
- Keith Black and mtaylor
2
It is looking very good - some ingenious work constructing the transom there.
- ct mike, Obormotov and Thukydides
3
No I didn't see the extra pieces, and they will be even less noticeable once everything is painted. You can always call them 'port linings' if anyone does quibble about them 😀
1
1
This looks great Thukydides. The transom does seem to be a very tricky area of the build. Even if the counter is positioned at the correct height, the transom does seem to need a little more area at the base to bring the bottoms of the ports above the deck planking level. I think my counter is too low anyway so I will need to fill a gap at the bottom of the transom. Your scratch built transom is looking great and I look forward to seeing the next steps.
2
1 hour ago, glbarlow said:
Not sure where I’d get one here anyway. I just blow and brush them off from time to time.
I found a fairly local to me plastics / acrylic fabricator. They make the perspex sneeze guards etc we see all around us now post covid, but they can also do other items and shapes including display cases. I had them make me a perspex case but without a base and then found my own piece of wood to use as a base. A lot cheaper, better and quicker than me making the whole thing myself!
I look forward to seeing the rest of your log 👍
That's a great build, and a great log describing it too.
- chris watton and glbarlow
2
HMS Sphinx 1775 by Blue Ensign - FINISHED - Vanguard Models - 1:64 scale
Congratulations. A great model and a wonderfully inspiring build log.
