Everything posted by iMustBeCrazy
Just a minor update, planking continues slowly. Although I've decided that the originals hull was most likely painted white I'm going leave mine natural with a coating of shellac, the timber is quite pale so it's 'close' to white and it will show off my work. And a better visualisation of Allan's project
Haven't we all? Taking a stab at it, from the comment about being short of white (paint) for the small cutter I'd guess all the boats were painted white (impress the natives) with the sheer probably painted in a colour that somehow matched the Bounty. Sometime before leaving Tahiti the bottom of the launch was painted with half pitch half tar (probably coal pitch (black) and pine (or Stockholm) tar (anything from light amber to dark brown)). The effect was probably a brown/black wash over the white leaving the launch rather dirty/shabby in appearance which would do little to impress the natives and may have increased the chance of being attacked. Model Shipways kit (green) v ZAZ7361 the drawing from the books:
Lapwing 1816 Revenue Cutter
iMustBeCrazy replied to iMustBeCrazy's topic in CAD and 3D Modelling/Drafting Plans with Software
Sorry to say, no. I realised I didn't know enough about the construction of ships (or their drawings) so I started working on drawings of boats and am working my my back up. I am learning and expect to come back to Lapwing sometime. -
I have to agree, without giving Tim too bigger a head, I have seen worse from people on their second or third kit. Well done. Of course there are issues (just to keep that head from swelling too much), the gaps, the bows, the transom, but I have no doubt that the next one will be even better. Tim, make up a brace to hold the sides in until you have fitted the thwarts (see my small cutter #27). Inwale (4x1mm strip running along the inside of the frames at the top of the sheer), breasthook and transom knees. All this adds strength. Then work from the bottom up. Don't get too obsessed with tools, it really doesn't take much with a kit and you can buy or build them as you go. Please do start a build log when you get the Launch, there are a few tricks and traps you will want to avoid.
A bit of a weird update. 1st a collage of some of the steps of making a plank. 1/ Using tape to mark edge. 2/ Stinking tape on board. 3/ VERY roughly marking the other edge. 4/ roughly cut out. 5/ Roughly sanded and test fitted, high points (between arrows) marked. 6/ High points lightly sanded, test fitted again, new high points marked. After that I got more serious, took the tape off and marked in pencil, added a VERY important alignment mark. After I fitted that pair of strakes It was time for some checking. First I found a new use for calipers, you can use them to compare both sides of the keel, I found the third strake starboard side had crept forwards about 0.5mm. Not bad but fixed anyway. I then redid the plank width calculations for the area remaining, the worst was at frame 'D' where the remaining strakes needed to be 0.3mm narrower which is pretty good.
My take on the masking tape method. A piece of tape is placed on the model overlapping the preceding plank. It should lie flat simulating the plank you are going to make and not have any edge set, just laying naturally not forced. I then mark the edge of the preceding plank, the transom, the frames, especially frame 0, and the stem rabbet. Note that I marked the rabbet wrong in the following picture, it should be a curve. I then transfer the tape to a board and cut the shape of the preceding plank and the the opposite edge slightly oversize (say 2mm). I test fit the new plank on the model against the preceding plank and sand away any high points, rinse and repeat until the plank fits. I should then be able to use this plank as a template for the other side of the hull. (I will use the one below as a template for both sides while correction my 'rabbet' error). I then use the measurements (previous post) to shape the opposite edge.
This post is a copy of something I posted in Tim's ( @oakheart ) build log, I'm repeating it here as I'm going to continue it a bit in the next post. ------------------------------------------------------------------------------ Right or wrong, this is what I do. First determine the maximum height up the stem of the garboard. This varies with the breadth of the plank. Cut a piece of plank the same breadth as the garboard short enough to sit in a straight section of the keel rabbet, use this as a spacer for a straight piece of balsa which reaches to the stem rabbet. That point is the maximum height up the stem of the garboard. At this point you can take measurements to get the curve of the garboard in the stem rabbet (put tick marks on the balsa and note measurements) but I tend to 'wing it'. Fit the garboard strakes. Now some maths, working out the breadth of the 'normal' strakes. Measure the distance from the garboard to the top of the sheer strake and subtract any 'abnormal' strakes, in the case of this launch remember to measure the outside of the planks not just along the frames as the planks will be narrower on the inside of the curve. Divide by the number of 'normal' strakes. If the result at the stem (or transom) is less than half the maximum breadth (at station 0) consider adding another strake. Note that at the stem the number is the length along the stem rather than the breadth of the plank. Repeat the calculations for each frame. And you should re-check your calculations after each strake. I then use the masking tape method to get the abutting shape of the next strake. I then shape and test, shape and test, shape and test, shape and test, shape and test the next plank. I then use the calculated widths to shape the other edge of the plank. (note the measurements noted on the plank in pic 3 above). Rinse and repeat.
I think that's a note to everyone. Right or wrong, this is what I do. First determine the maximum height up the stem of the garboard. This varies with the breadth of the plank. Cut a piece of plank the same breadth as the garboard short enough to sit in a straight section of the keel rabbet, use this as a spacer for a straight piece of balsa which reaches to the stem rabbet. That point is the maximum height up the stem of the garboard. At this point you can take measurements to get the curve of the garboard in the stem rabbet (put tick marks on the balsa and note measurements) but I tend to 'wing it'. Fit the garboard strakes. Now some maths, working out the breadth of the 'normal' strakes. Measure the distance from the garboard to the top of the sheer strake and subtract any 'abnormal' strakes, in the case of this launch remember to measure the outside of the planks not just along the frames as the planks will be narrower on the inside of the curve. Divide by the number of 'normal' strakes. If the result at the stem (or transom) is less than half the maximum breadth (at station 0) consider adding another strake. Note that at the stem the number is the length along the stem rather than the breadth of the plank. Repeat the calculations for each frame. And you should re-check your calculations after each strake. I then use the masking tape method to get the abutting shape of the next strake. I then shape and test, shape and test, shape and test, shape and test, shape and test the next plank. I then use the calculated widths to shape the other edge of the plank. (note the measurements noted on the plank in pic 3 above). Rinse and repeat.
There's a few things you can try. First off, in a full size boat you can facet the frames as you have but this leaves a faceted interior, you can hollow out the inside of the planks to match the frames or you can use more skinnier planks. In a model you have the additional option of bending the plank around the frame either dry or wet. Clamping with rubber bands helps and using hollowed out balsa blocks helps more. Only clamp on or close to the frames.
Well, she probably doesn't look much different but the jig has been modified and glued, the transom rough shaped and the rabbet cut. Something went wrong with the printout of the notched strips for the jig and I finished up having to correct all the notches with a file which was a bummer as I was going to use them to square the moulds. Either the paper was too thin and slipped or it had excessive moisture.
