Ras Ambrioso
Everything posted by Ras Ambrioso
  1. A little more progress. Currently finishing the mechanical room aft. A few shots with the roof removed. It is amazing how much detail, that we for so long labored, gets lost once the model is put together. Again the black paint kills details in the boiler. And the first passenger is checking out his cabin.
  2. Being a little lazy lately. The Admiral has kept me busy elsewhere. But, I still had some time to test my micro soldering. Still not very happy with the results but at least I found a good technique to use. Following are the photos of my set up and the result on micro door handle. Also, some progress on the boiler. Hinges and latches come next. Wife gone on a safari in Borneo. That will give me a little more time to play. LOL
  3. I have been working on the valves with some success and finally fabricated an acceptable mini valve. Started with a much larger rod then ordered the right size (3/16") but had difficulty with the cutters in the lathe. Decided to fabricate the valves in a mass production cutting each valve in series so I would cut the body leaving the thickness of the flange and the cut another body etc. The result was a with a series of flange-body-flange-body-flange........... Unfortunately I didn't take a picture. When I finished the series I took it off the lathe and went to cut each valve apart. Guess what, the distance between bodies was only one flange thickness. I had forgotten to make the series as "flange-space flange-body- flange-space.....". So I started again and this time I did it correctly. I used tacks for the stem and handle and this how the unpainted valves look. Thanks for following.
  4. Wefalk, you never cease to amaze me with your micro work. Thanks for being such an example to us plebes.
  5. Thanks Glen and Keith for your comments. The lathe is a Unimat. It is an old model but works like a charm even though is not totally watchmakers accurate. It also converts into a mini milling machine. To the rest of the guys thanks for the likes🙂
  6. I was itching to start work with the lathe and, I was also figuring out the piping of the boiler/engine system. Right at the start I noticed the large number of valves that would be required. I counted a minimum of 15. So, I am going to bring up the lathe and start making these tiny valves. The fun starts now. Lathe setup. Drilled the stock to the pipe size, and then machined the body. Then I will cut a disc and attached it to the body with a proper size stem. On this valve I started with some old 3/8" rod stock. But now I found the 3/32" rod that will make the machining easier. Stay tuned.
  7. Valeriy, I used brass mini nails that are sold by Micromark in the US. These nails are sold to temporally fasten planking strakes in the model frames. I have a supply of them. They have round heads and I set them on holes filled in the door but leave a little of the stem out. I also used other sizes using sewing pins. Now I am trying to figure out how to made the lever type door knobs to use on the other doors of the model. Thanks for your comments and likes. Any ideas?
  8. Outstanding work. Olympia is one of my favorite ships. You have done a splendid job. Congratulations
  9. Completed the rest of the superstructure. A few little details were left out since I am anxious to start building the propulsion system. Dry fitting all the parts, I assembled the ship. Then, started work on the boiler. First, the smoke box. Then the stack. Followed by the boiler. And this is the dry fitted boiler. I have also been following Cathead's build of the Peerless. Very interesting and informative. As a mechanical engineer, whose work was mainly in the energy systems, I enjoy the debates about insulation, expansion loops, superheaters and steam traps on the piping. But at the scale I am working it is hard to include all the minuscule parts that would make the piping correct. Thanks for watching and I enjoy your comments.
  10. calt4, welcome to my build. It is a lot of fun to scratch-build a model. In addition to figure out how to fabricate a piece you also have to figure the right sequence for the assembly is also important. For instance, in this model, I assembled the walls of the cabins and then have to open the windows on the finished cabin. It would have been easier to build each wall independently and then assemble when completed.
  11. Little more progress. I didn't like the way the passenger cabins came out while using plain walnut strips as shown in my previous post. According with the information I had from the article in Model Boats, these cabins were built in mahogany; so, I bought already scribed basswood boards and fabricated the new cabins. I used a mahogany stain and the results can be seen in the photo, shown here on top of the planked boiler deck. I used the same type of pre-scribed board to do the main deck and the boiler deck planking. I also developed a method to make the windows. Basically, I drew the them in card stock and glued the minute frames to the cardboard and then cut the opening. The window was cut oversize from the card and glued to the opening in the walls of the cabin. You can see the the card stock in the inside walls of the cabin above. The window glass (acrylic) will be attached to the inside of the frame. I used a similar method to make the varios doors. The finished doors will be glued to the outside planking in the cabin. Forgot the scale match but the window is 12 mm wide. The doors had a similar treatment. Completed the planking in the main deck. Have already finished the roof but have no pictures yet. Getting closer to the mechanicals.
  12. Just for your information I am showing the way the main cabin looked with my improvise planking. your comments will be appreciated.
  13. A little more progress. Painted the hull and completed the lower cabins. Getting ready to start the main deck planking. Had a little trouble with the main cabin in the boiler deck. Have tried several methods to display the mahogany planked walls using very thin strips. The results don't look good since the grain shown is so apparently out of scale. Decided then to fabricate the cabin using striped basswood pieces.
  14. Being quite busy with the upcoming holidays but managed to add a little progress to the build. I have been trying to fabricate all the superstructure prior to starting the metal work on the boiler, piping and engines. Following is some of the progress to date. Boiler deck planking dry fit. Thanks for following.
  15. I agree with Keith. I had a lot of rough spots on my first planked hull (Emma Berry) but it made boat look like it was built on a short budget. It added to the looks of the finished boat.
  16. Keith, I just found your post and I am hooked. These yachts represent the best looking boats of the transition between sail and steam. I will be following you and wish the best on your surgery. Ras
  17. Happy to see you starting another masterpiece. I used the half hull method on Amapá. Will follow your progress.
  18. Being a little busy these last weeks with not much time to work on Zulu. But, a little progress has been done. This is the crew cabin Started the roof structure. If you notice the dirty surface in the roof blame it on one of my buddies in the shop. While I was out he came in an used the sander but forgot to turn on the vacuum system. When I came back there was a layers of microscopic black walnut dust all over the benches. Took us a whole day to clean the mess. I tried cussing at him but he is a preacher. The roof skylight gave me headaches. The sky light has seven ports 3/16" diameter on the 3/8" wide on each side. Started using basswood only to break the strip while drilling. Then I used some cherry leftover but the grain was perpendicular to the strip so during the drilling several holes broke. So I made another strip using poplar with the grain properly align and success. Thanks for following.
  19. Made a jig to determine the height of the cabins in the main deck. Presented the boiler deck and located the holes for the deck's posts. Mechanical room is also dry fitted. Discovered another booboo. The opening cut on the deck for the hold does not allow sufficient space from the boiler's front to the galley cabin. Since I intend to have the the the hatch covered, I closed the open space and moved the hatch location aft. The photo also shows the mechanical room. There is very little data about this type of vessel but, based on the year it was built, I have assumed the they had electricity aboard. This cabin houses the electric generator and the mechanical shop. The steering gear is located above on the boiler. Following is is view with the boiler deck and the roof. The ribs on top of the roof will create the camber once installed on the bottom. Following is the main deck with the fabricated cabins. Next will be the detailing of the cabin windows and doors and the covering of the hold hatch. Then the priming of the hull and the installation of the deck planking. After the main deck is completed I will start metal fabrication of boiler, engines, tanks and piping so that the equipment gets installed on deck before proceeding to the upper levels. The fun continues and thanks for following.
  20. Chris I still have the Spitfire kit and your instructional V-108 but haven't have the resolve to get started in this new phase of our hobby. Following you will help me build enough confidence to carry on. Your card models are exceptional.
  21. Beautiful application of modern technology. I feel sorry that now I am past this kind of tooling to pursue our hobby. Congrats.
