mcb
Everything posted by mcb
  1. Hello everyone, Its time for another update. Thanks Keith, for your nice comments, and thanks everyone for the likes. Most of the engine house work is done. I will now have to make some doors and another batch of windows. I have received some etched brass railing stanchions in 1/192, they look as if they might not be so bad. I will have to use some fine (36 gauge) Ni-Cr wire to fit in the holes. May be frustrating. We'll see. First pic should show how the engine house walls were wrapped around temporary formers. Last pic shows the beginnings of the boom pedestal. Thanks for looking, mcb
  2. The covered boats are great, the open boat is incredible. Soon I will have to read this entire thread from the top again. Thanks for posting this, mcb
  3. Hi, Assuming your super glue is CA there is a product, CA accelerator, in an aerosol spray can, that will almost instantly cure the glue joint with just a slight squirt. I think the one I use (not often) is called Zip Kicker. I would test it on some expendable painted parts before hitting your model with it just to be safe. Of course, you may still need three hands to hold everything together and give it a shot. That's a nice looking ship btw. Good Luck, mcb
  4. Nice photo Feathermerchant, I suppose that having the starboard side of the hull bashed in may have interrupted loading; doesn't seem to interfere with washday though. Sorry to go off track in your thread Roger, mcb
  5. Hello All, Thanks for the likes. I have a little progress on this model. I have gotten a lot of the windows done but it looks as if I may have to make a few more. The 'winch' house and pilot house are joined up with the pilot house on top. I had to pack out the walls somewhat to at least have the appearance that the windows can slide down into pockets. The top of the main deck house, engine house and pilot house roofs need to be enclosed with railings and I wanted to try to improve on my last soldered together railings by using stanchions and wire rails. So far, my homemade stanchions have been pretty dismal. I have ordered some etched brass in 1/ 192 scale. We'll see how they look. While waiting for the stanchions I made some more furniture for the pilot house roof and started on the drawing for the engine house. When the engine house is ready, I will paint all the 'houses'. I found some Floquil paint for it. They are in primer now. Thanks, mcb
  6. Hello All, Thanks for all the likes. I am still working on this project, about half-way through the pilot house and winch control room windows. I made a lot of 'furniture' not all of which will fit in the winch house and pilot house, but I should be able to use some of it elsewhere. Most of it seems to need a little more work as well. Here are a couple of 'work in progress' pics. Thanks for looking, mcb
  7. Hello All, Thanks to wefalck and Roger for the comments and thanks to everyone for the likes. In response to welfack I intend to use clear sheet for the windows. My windows will be flat, I think that Roger is correct in that the windows themselves were flat and the frames in which they slid up and down were fitted to the curve of the pilot house walls. I will probably have a few of my windows at least partially (faked) down. In order to put off, for a while, the tedium making these windows I have started to fabricate some 'furniture' for the pilot house and winch control room. At least the wheel should be visible through the windows, but I can't stop there. Thanks for looking, mcb
  8. Hello everyone, Sorry to have not kept this log up to date lately. I had some long-deferred maintenance to attend to at home. Thanks everyone for the comments and likes. Thanks Al S for bringing that info to my attention. I never had any idea. It is still somewhat amazing to me that anyone else has ever heard of this obscure subject. The stairs/ladders have been installed in the deckhouse, though in the pictures they look a little clunky. I may have to build a new fixture with a lesser tread spacing. I have begun the pilot house assembly which will be on top of the winch control room. The pilot house was raised at some point (after the photos at the beginning of this thread) above what became the winch control station. I will probably put in some sort of interior details in the pilot house and winch room. The pics show the attempt at window layout and the fancy? wood siding that goes on the pilot house. I think I will have to build windows next. Not my favorite job. Thanks for looking, mcb
  9. Looks great. You really get a nice square cut using your method. mcb
  10. I have to agree with the posts above. Well done, thanks for posting. mcb
  11. Hello all, Thanks for the comments, Keith Black, Canute, wefalck, and Roger Pellett. And thanks to everyone for the likes. I have the deckhouse almost ready for primer. I drilled locating pins down into the hull so that I can easily remove and replace it on the deck when needed. The openings in the upper deck are for a ladder way or stair well down to the main deck. I will have to make stairs for those as the commercially available stairs are not steep enough. The layout of the doors is very odd as the doors on the lower level are short and there is a rather large step from the upper door. Under the upper door there appears to be a smaller access door with steps on it. Behind this door is a grill which will be shown in the view of the port side. Any way here is how it stands now, a little rough. Thanks, mcb
  12. Thanks for that Roger. It looks like there are a lot of useful items there. Good news.
  13. Hello again everyone, Thanks for the comments Keith Black, Jim Lad, Canute and Wefalck. and thanks for the likes. I am sorry it has been so long since I have done anything on this model. I had begun to build the forward /main deckhouse and foolishly cut the openings in the wrong places (short attention span). I put the model aside and decided to finish rigging the old AL Blue Nose II model I had started not long ago. Well, when I started with the rigging I couldn't stop and so I finished that Bluenose II case and all. Anyway, I intend to get this Blairstown up to the point of the derrick and booms before the next break. (That would be a MS Kate Cory 1:64 and I will start a build log when I go back to it). First pic shows the deck house on the hull (reject hull in background), the second pic is the current state, needs a little clean-up. Thanks for looking, mcb
  14. Hello Schaye, Its funny, I recently completed the same old kit. I had fun with it. I am pretty sure that I disposed of the cloth sails that came with the kit but I will look again. I agree with what Alan said above about silkspan. I would get more than you think you need as it is relatively inexpensive. I made about 20 silkspan sails to get 8 that I liked. The thing does look nice with sails though. Just don't look too closely. Good Luck. mcb
  15. Nice, neat work, As for roof paper, I have, in the past, used facial tissue AKA 'Kleenex' cut into 3' wide strips (or whichever width is appropriate for your era) and simply painted it on the roof surface with, usually, flat black. it should have more a slightly pronounced texture than silkspan. This works out in 1:160 scale for my eyes. I think it would work in 1:48. Good Luck, mcb
  16. Hello again everyone, I thought I would post an update of progress on this, such as it is. I am working on the hull while trying to make drawings of the superstructure. The last picture should be as it sits today. I have to touch up some damage which was caused by the masking. Thanks for looking, mcb
  17. Hi Everyone, Thanks for the comments Keith Black, Canute, Roger Plett and Richard R. Thanks everyone for the likes. I remain puzzled by the 'clean' stacks. It is amazing to me that someone (Richard R) turns up with a connection to this vessel. There is an encyclopedia of knowledge on this forum. I would appreciate any info or photos of Blairstown as my sources are few. The build has slowed down lately due to the climate in my basement. I may post a couple of photos of the hull ready for paint soon though. Thanks again, mcb
  18. Welcome, Pretty sure I met you at a train show, probably a few train shows. You'll like this place. mcb
  19. Thanks for the tip, I will have to remember that one though I am usually cutting plastic on the Chopper II. mb
  20. Hi, The color of the water looks perfect and the joint where the hull meets the water is not noticeable. Well Done mcb
