Everything posted by Egilman
Tiger 1 by marktiedens - FINISHED - Dragon - 1/35 scale
Egilman replied to marktiedens's topic in Non-ship/categorised builds
I believe Kurt that back in medieval times when the builders had a situation where a stone couldn't be cut to fit, they made up their own... The ancient egyptians were familiar with concrete and sun dried clay bricks.... I don't see why someone can't make up their own sculpy bricks and build themselves a brick building... We make stone faces out of sculpy for model railroad scenery, outside of the expense why not make bricks out of sculpy of even fired clay for that matter...
I empathise on the decal situation... I used to suffer from the same problem... A suggestion, if I may? When you drop the decal into the water, wait for it to completely separate from the backing before you take it out, it will separate completely eventually. The white glue that is between the paper and decal isn't needed for adhesion to the model. Yes, that is the important point, the white glue isn't needed for adhesion to the model.... My technique is to allow the decal to separate, the small ones get picked up with a soft brush and placed on the model with a drop of water. I then take a napkin and using a corner draw off most of the water and use the brush to push the decal into position. Then, I take another dry corner and draw off the rest of the water.... Then you lightly press the decal down onto the surface with a dry part of the napkin looking for bubbles which of course using the point of a pin you pop and drain... the idea is to get it to lay as flat as you can without putting a lot of pressure on it.... Then pick up a drop of decal set and drop it onto the decal, and leave it there, let it dry all by itself..... The decal set is what sucks the film down onto the model as it dries... Larger decals is exactly the same way. My experience doing it the way the kits instructions say usually wound up with at least a few destroyed decals before your finished..... Just a suggestion.... EG
All good writers, but there are even better writers... Tolstoy, Remarque, Hemingway, Hershey, Sebald, Heller, Trumbo, Norman Mailer, Graham Greene, Khaled Hosseini..... There are more, less well known writers like WEB Griffin......... Then there are the well written personal histories and memoirs, Eisenhower, Guderian, Kennedy, etc, etc.... Too many to read them all unfortunately, but it helps to understand the society that brought on the wars and how they dealt with it...... and can highlight the errors and repetitions of history that are coming cause others aren't readers or weren't taught the importance of knowing where we were before deciding where we are going.......
I don't know, I started reading books when I was very very young and have been reading ever since..... the first book I remember ws Incredible Victory by Walter Lord... (It's how Winston churchill described the outcome of the Battle of Midway, he used it for the title) and "Sink the Bismarck", then there was "The Caine Mutiny" by Wouk, and I've been hooked ever since. I extended my study of facts by reading well researched historical novels like "From Here to Eternity" and "Once an Eagle" I've found that the historical novels although a fiction woven through real life events, give great context to the facts, explaining how all the facts interact in a human perspective, so when I go on to read Toland I can understand what he's writing about... The facts just stick that way, it's easier to remember the story than the cold hard facts, the story becomes a kind of memory index to the facts if you do it long enough...... Anyway, that's my story and I'm sticking to it... EG
I'm here Jack... I'll have you know that I seldom come in from shore leave, so If I start bumping into things or asking dumb questions it's cause I'm seldom at work in the shipyard...... I"ll try not to make a fool of myself.. I promise.... {chuckle} Sorry for derailing the other. (it wasn't intentional) EG Where's the popcorn....
That my friend would be a WAAF, stands for Women's Auxiliary Air Force.... Your mossie dates this to '43-'44 correct? which means by the uniform she is wearing she is either a warrant officer or a flight officer. The skirt sets it off as an officer uniform. If she was an enlisted rank like a flight sergeant she would be wearing dungarees at the field... So at the very least she is the driver for the officer, a section officer or assistant sec.off...... With the clipboard I would say assistant section officer, (rank equivalent to an acting pilot officer in the RAF) and she was driving the jeep......
kit review USS Missouri (or any Iowa class) 1/350 by Joy Yard
Egilman replied to Tigerdvr's topic in REVIEWS: Model kits
Personally, I would like to see a build log, but that being said with the scale of the individual parts, pics might be problematic unless you have a high quality setup...... I"m looking at what has been presented and it confirms my first thought when first seeing it... An injection molded monster.... and I thought the Tamiya Missouri was a lot of parts.... For complexity, This beats that hands down....- 51 replies
Yep she was a Sloop of War, never a Frigate. She didn't have the bones to be a frigate and when they rebuilt her they almost sealed her fate... within 30 years she was hogging so bad from the weight they put on her that they needed pumps 24/7 just to keep her afloat. Eventually, the muck built up around her hull where they didn't need to pump her anymore. but she started rotting.... An archeological survey told them to fix her now or scrap her, their last chance. This time, they called in the professionals Wood ship builders with a sense of history and the historians got to work digging thru the archives based upon others research and uncovered the only plausible history after eliminating all the other possibilities. Then the smoking gun document was found, an invoice for timbers from the original Constellation, (whose partially burned/buried hulk was still laying across the bay being broken at that point for salvage, and someone got the bright idea of using what was left of the old ships useable timbers in the new ship... That is how she got her name and the only connection to the old ship.... At least that is what I heard about it.... Surprisingly, she hasn't had one single problem remaining afloat since they rebuilt her into a proper sloop of war.... Seals the deal for me....
F-86F-30 Sabre by Javlin - FINISHED - Kinetic - 1/32
Egilman replied to Javlin's topic in Non-ship/categorised builds
Yeah, I'm going to have to do the same thing in the future, take a break from plastic for wood and glass... Probably after the Bandit is done.... Definitely need the space...... -
It would be Panzer Grey either way with or without the turret "bustle" I've seen that pic that Backer has posted also... it was obviously mounted before the whitewash...... An issue tank before it saw combat, that's cool and how I like to do mine.... -
Yeah, that was definitely a convoluted conservation history there.... Full of personal ideals and politics... Along the way they forgot about actual history in trying to preserve history.... Or any semblance to factual historical research.... A perfect example of what agendas do to facts...... The real sad and unfortunate part, is the need to repair what was done to build a false narrative no matter the motivations once the real historians finally get their evidence recognized... But it is a beautiful period ship as best as it can be restored into one.... and the only example representing an important part of naval history......
If it did actually exist on a combat vehicle, it's a major rarity for sure.... The rear storage bin was a fairly common field adaptation taken from worn out Pz III's, but the side "wing" bins were not..... -
Yeah I saw that when Mark posted the pics and said "What the heck???" but not being sure I didn't mention it, but it is what brought out the idea for me that the manufacturer might not have his accuracy quite up there where we would like it... -
Hi Patrick, Got the makings of a pretty good armored battalion there my friend... Ready for parade... My german armor interests died down a couple of decades ago... but before that I had every Accurate Armor Panzer Truppen kit in my stash..... Never got to build a single one of them though... For a while I dropped off the modeling scene and there's a huge gap in my studies.. lost time... but it gives me more to learn now, I only remembered that bit about the DunkleGrau and Tiger tanks from a very memorable argument a gent an I had over just such... you like grey PZ IV'S there are a ton of examples same with Pz III's, but Panthers and Tigers... that's another story... I knew they had painted them but until today never thought one actually went into combat... Personally I thought the troops serving them would have been smarter..... Citadel took everything as far as armor.. that is one thing about the german forces they were moving tanks around so much that many broke down before they could ever get to a battle... I read about one example of a Tiger that was mustered up battle four times but never fired a shot in anger... it would break before they got to the assembly point..... It's why the Russians put a premium on destroying railways..... Now I'm into American Armor.... which has as many devoted followers as German armor does...... But from building interests, I"m modeling anything that strikes me fancy at this point..... Got a few things I want to do and focusing on one small part won't get that done... Nice collection...... Nice to actually converse with someone who likes the history as well as I... I'm not alone.... EG
