Bill97
Posts posted by Bill97
Decided to plank the deck with individual boards instead of using the long deck planking strips as the instructions direct. The layout included in the kit shows the deck boards being around 6.5mm long. I started the process of cutting all the strips into pieces that length. I also am covering the 4 sides of each small strip with pencil graphite that will ultimately resemble plank caulk when sanded, stained, and top coated.
- ERS Rich, jpalmer1970 and flutlo6180
- 3
Veszett I am loving your ideas! 😊
Veszett you commented above that if I planned to display my Victory and Soleil Royal together I should also put the Victory in an ocean diorama. I thought that was a great idea and began to plan the diorama. Then I realized the water line on my Victory is the same line where the copper plating stops. While building my Victory I spent many hours adding copper to the hull including nail impressions. If I were to now out the Victory in a diorama all that copper work would be covered and no longer visible. 🥲
Very inviting work space Henry. No doubt it will open your mind to many creative adventures.
So I gather from my research and reading that it is absolutely imperative at the onset of this build that the two sections of the false keel be perfectly straight when glued together. Even off by a millimeter would result in further problems in the build. After glueing the two sections together and adding the reinforcement pieces I pressed the keel up against a metal ruler to insure it is perfectly straight. Knowing how important this is I am not rushing this step. After gluing it up I am letting it set overnight for the wood glue to dry. The next step will be to add the 10 frame pieces. In preparation I have cut these pieces loose, sanded them, and numbered them in order.
- ERS Rich, wvdhee and Hubac's Historian
- 3
Had to get my finished HMS Victory out of the case and do a big correction. Doing this before I start my next project the OcCre Endeavour. I have no idea why I did it, but it was pointed out to me during the time I was building the Le Soleil Royal that I incorrectly rigged white ratlines on both ships. Again I have no idea why I thought that was correct when it is obviously not. I made the correction on the Soleil Royal as I continued the build. Now that is is finished I am going back to my Victory and making the same correction by carefully painting each ratline with a small brush and black Panel Line Accent Color.
I must admit now that I have it out of the case I am tempted to design a diorama for it since it will be displayed with the Soleil Royal that is in a diorama. 🤔
Thanks Chris. Appreciate it.
Jeff at your convenience would you move and retitle this to member build log? No matter what I do I can’t seem to delete content and restart the topic in the correct category. I think I have created a mess. I tried to start a new log a member build but concerned I may have two now.
https://modelshipworld.com/topic/36221-endeavour-by-bill97-occre-154/
Thanks Marc. I really appreciate your comments. Putting it in a diorama was a last minute decision but, as you said, does present a beautiful display.
Hopefully with my woodworking experience the Endeavour is an enjoyable task. I do understand there will a bit more sawdust my wife will want me to control.
Thanks Veszett. I really like your “silly tale”. In fact that is the one I am going to tell when I explain the diorama 😌.
Really enjoyed your following me.
Jeff I just now added this new build I am starting. However when I started the “New Topic” I could not get kit build log to register in the topic line. I could only get “how to use MSW forum” to post. Could you fix that for me?
Thanks
Bill
https://modelshipworld.com/topic/36221-endeavour-occre-154-by-bill97/
Gentlemen she is FINISHED!! Crew on board and a few diorama liberties taken. It has truly been a complete joy to build this beautiful model. A build I would have been at a loss to tackle without the advice, encouragement, and help of all my MSW friends. A special thanks, but in no way limited to, Marc, Ian, and Henry. You guys have always been there for my numerous questions, regardless of how ridiculous. A very big thanks to you.
I have a certain since of pride knowing that I have now successfully completed both of Heller’s beautiful models of the HMS Victory and Le Soleil Royal. During these builds I have learned so much.
The OcCre Endeavour is my next quest. Hope you will come along with me.
Gentlemen would you please add my Le Soleil Royal build to the index? I have posted updates to it since October 2022 but it is not in the index. Would like to make it available to find for anyone interested. Thanks
https://modelshipworld.com/topic/33097-le-soleil-royal-by-bill97-heller-1100-finished/
Ok my fine modeling friends here is my diorama. There is most likely not a thing nautically correct about a ship taking on supplies while moving, but what the heck this may have been under duress. Crew needed to quickly take on water and food from shore while avoiding combat. Still need to add some crewmen here and there and my Soleil Royal will be ready for a display case!
Thanks again Ian. I will give that some thought. Having the sails set has changed my composition idea for my diorama. My original idea, once I decided to do it, was to have the 2nd boat loaded with barrels to be loaded on the ship since I already have three in the tackle pendant. Maybe also have an officer ready to board since the steps on the hull or right there. In the boat on the stern I was going to have a couple crewmen tending to some necessary functions. However with the sails set, which I obviously did not consider, I understand this idea will not be nautically accurate. This is a learning experience to make decisions about long term plans during the build, not after.
Endeavour by Bill97 - OcCre - 1/54
Posted · Edited by Bill97
Completed the decking on the starboard half of the lower deck. Plan to stain the two halves a weathered gray. OcCre instructions have the planks at 65mm in length and alternating planks for the butt joints. AOTS shows a length that the scale would be better around 140mm and a 3 or 4 alternating board butt. Used the lower deck to get experience since not much of it will be seen. Will change the layout on the upper decks.
